Old 11-23-2012, 04:15 PM   #1
formulals1 OP
Semi-Adventurer
formulals1's Avatar
Oddometer: 295
Y connector for a RAM systems
I've always wanted a Y connection for my RAM systems setup so I made one for myself. For example a GPS and SPOT can be next to each other with only one handlebar mount. This one is a prototype but seems strong enough for real use and will field test it at some point. I'm hoping all the joints aren't too much for off road use.
Just wondering if other folks out there would also want to make use of a Y connection like this?
Here is a rough setup example:
formulals1 is offline   Reply With Quote
Old 11-23-2012, 04:17 PM   #2
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 2,999
Hell yeah, I could use one of those too. Nice job!
Contevita is offline   Reply With Quote
Old 11-23-2012, 04:26 PM   #3
sdpc2
Just another Rally Rat
sdpc2's Avatar
Oddometer: 1,146
I went look on the RAM web site
about a year or two ago looking for exactly that. I was shocked that they didn't already make one. So HELL YEAH!
'12 R1200GS Rallye Edition, '99 R1100GS,'77 R100S
I lower my passenger pegs for those riders that have gone before me
sdpc2 is online now   Reply With Quote
Old 11-23-2012, 07:22 PM   #4
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
You guys talking about this?
http://www.rammount.com/CatalogResul...5/Default.aspx
It's been around for years.
Flashmo is offline   Reply With Quote
Old 11-23-2012, 08:07 PM   #5
formulals1 OP
Semi-Adventurer
formulals1's Avatar
Oddometer: 295
Kinda' but not really. I'm pretty sure it's not intended as a Y connection. Plus the balls screw in and could unscrew and have the connection slip. It's short of big and clunky for the task too ( for me).
Old 11-24-2012, 04:55 AM   #6
a2ronm
a2ronm's Avatar
Oddometer: 438
That is what I use, I have my smartphone mounted above my GPS off my dash base.
Would be nice if it was smaller 'footprint'.
a2ronm screwed with this post 11-24-2012 at 05:02 AM
a2ronm is offline   Reply With Quote
Old 11-24-2012, 09:44 PM   #7
OldPete2112
OldPete2112's Avatar
Oddometer: 201
Hmm, been using one for years to split my head tube mount on my zx14.
Have the Zumo 665 and radar detector mounted with it, put it in a fore and aft position with short arm low for Zumo and mid arm higher for detector.
Did you make yours from Delrin or something? No compression value to cushion the gear on the mount like a Ram ball. Nice job machining, but wonder haw it will hold up over time. Interesting.
OP
Its better to travel well than to arrive.
Sent from my iPad using Tapatalk HD
OldPete2112 is offline   Reply With Quote
Old 11-25-2012, 04:03 AM   #8
worwig
Oddometer: 1,278
Just replace the bolt in the arm with this:
Attach another arm to that.
Hog mountain Weather
worwig is offline   Reply With Quote
Old 11-25-2012, 05:11 AM   #9
a2ronm
a2ronm's Avatar
Oddometer: 438
I'm going to try that.....thanks!
Old 11-25-2012, 06:02 AM   #10
formulals1 OP
Semi-Adventurer
formulals1's Avatar
Oddometer: 295
Cool, I like the other mountings shown here too. Options are good! I designed this in CAD and had it built of ABS plastic from a 3D printer (the industry I'm in so it was easy for me) to fit my needs. Designed to be compact (small footprint) and and quickly configurable with flexible options. Yes, no rubber on the ball as that might get too close to a Patent issue. Also, too many rubbery joints could add too much flex to the system. That rubber also helps get some bite at the joint at the same time I bet, though.
formulals1 screwed with this post 11-25-2012 at 06:09 AM
Old 11-25-2012, 08:38 AM   #11
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,927
Those are not screw on balls, they're solid. I had one.
HaChayalBoded is offline   Reply With Quote
Old 11-25-2012, 08:42 AM   #12
HaChayalBoded
Brooklyn Bored
Oddometer: 7,927
It's not really rubber, it's vinyl dye. You can dip yours in the liquid rubber used for tool handles. That would give it more grip and a little more vibration control.
Old 12-09-2012, 08:25 PM   #13
mle52
Oddometer: 71
Exactly what i was looking for, spent a lot of time on ram site and and never found this
mle52 is offline   Reply With Quote
Times are GMT -7.   It's 02:28 PM.
