Old 11-23-2012, 05:00 PM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,603
R90 s
Just brought home the R90S from an inmate here.
Was running before .. but we tried to fire her up this
morning before loading it up in the van.
Had the dash lights go on. Figure it was a weak battery.
Got her home .. put it on a charger. NO LIGHTS at all.. just like when when tried to fire her before. Electrical switch in headlight is two position off or on.
The emergency switch on the on position. ( could this be bad)
Battery shows it has some juice in the battery.
CLUES
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 11-23-2012, 05:20 PM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,927
A load test will tell you if the battery is good but as a general rule it should read 12.5 volts or more to start a vehicle.
The R90S bikes are three years. Those years have differences between them every year. What year is yours?
---Albert Einstein
disston is online now   Reply With Quote
Old 11-23-2012, 05:54 PM   #3
walkingbear OP
Oddometer: 3,603
75 r90s
Mine is a 75 R90S
Old 11-23-2012, 09:11 PM   #4
_cy_
Oddometer: 6,367
CLUES
fuses are located in headlight bucket .. not necessary to remove fairing to get at.... carefully unscrew large band that holds headlight in place. carefully remove bulb assembly.
you will find fuses inside ...
to check out battery ... assuming it's a lead/acid.. charge to full preferably not with a trickle charger, which could take 2+ days to fully charge.
then measure resting voltage of battery with a known to be accurate meter. 12.85v resting indicates a fully charged condition.
to achieve resting battery state ... allow battery to sit overnight...or if you don't have time to wait... place a substantial load on battery for short durations. like honking horn a few times. this will scrub off any surface charge to allow a reasonably accurate volts reading.
after you get R90S back running again... volt reading taken directly at battery should be 13.8-14.2 range with engine at mid range.
wiring diagrams, etc are buried somewhere in my bringing R90S back to life thread. link in sig...
Old 11-24-2012, 04:57 PM   #5
walkingbear OP
Oddometer: 3,603
bad ignition switch
Ok, fully charged the battery. Meter to the inside headlight. Both fuses are good. Red wire has 12.65 volts . The switch I believe is bad. Key will only turn to parking light position and the lights on the dash sometimes go on. Anyone have one for sale?
Old 11-24-2012, 05:47 PM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,927
Before you buy the very expensive ignition switch check the plug to the rear of the instrument pod. This large rubber plug is held in place by a small screw. It is not often a problem but the contacts when they get to the age of our bikes have become dirty for one thing and they have also lost some of their grip. the female part you will see is the rubber plug and the male part is the back of the instrument pod. Clean all of this. Look for any loose pins or holes in the plug that look enlarged. Sometimes they need a little adjusting. It's kinda hard to put contact grease on each pin but if you do just a tiny bit now and again you may avoid making a mess.
Actually all the wires in the bike should have their contacts cleaned and dielectric grease applied as you are working around them.
I'm not sure you have found the problem with the headlight switch. It seems you have jumped to this conclusion a bit. But tell me have you tested the switch to verify that it is the problem? I guess you have to unhook it and test for continuity. That sort of test I think.
Edit; Or do I misunderstand you, is what you are saying is the key does not turn?
---Albert Einstein
Old 11-24-2012, 06:17 PM   #7
_cy_
Oddometer: 6,367
there's a switch built into clutch lever assembly on R90S with early style controls. switch shorted out and kept my R90S from starting.
by passed clutch lever switch .. no problems ever since. never bother to replace that switch.
does your R90S have early or late style controls?
_cy_ screwed with this post 11-24-2012 at 06:32 PM
Old 11-24-2012, 06:52 PM   #8
_cy_
Oddometer: 6,367
one of my fav pictures ... R90S cockpit with 7,300 miles
Old 11-24-2012, 07:26 PM   #9
walkingbear OP
Oddometer: 3,603
options
MY TROUBLE SHOOTING:
I have my 81 R100 next to the R90 and both headlights are off.
The biggest difference are the fuses on the R90 are mound on one of the '
headlight ears.
Checked the battery connection= good and fully charged but can guaranty the life/value of the battery without having it fully tested
Checked the connections to headlight fuses ( not blown and changed out to two new ones)
Checked power to the switch ( 12.65 volts from red lead)
Battery charger on battery while test switch. Light came on for with parking light. Switch will not switch to full open position. Pressed the start button and the whole system died again.
Will test continuity in the morning.
Will change out for a new battery in the morning.
Old 12-03-2012, 07:36 PM   #10
walkingbear OP
Oddometer: 3,603
Magical find!
I was searching Ebay for parts. There was this 75 R90S tank with 8 hours left to bid. I made a bid and a call to the seller. No only he has a pristine tank he also has the cowl, fairing , seat , headlight bucket plus harness and start switch. All in perfect paint except for one spot on the fairing.
He also has mufflers and grab rails. Totally turn key project not. Not worry about painting any longer.
Old 12-03-2012, 08:23 PM   #11
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
Very nice score!
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 12-03-2012, 08:58 PM   #12
_cy_
Oddometer: 6,367
fab score!!
Old 12-04-2012, 03:06 AM   #13
spo123
Man About Town
spo123's Avatar
Oddometer: 815
Cool2 I am jealous
I bet it is (was) EXPENSIVE!...
spo
1973 /5 LWB Toaster
spo123 is offline   Reply With Quote
Old 12-04-2012, 10:24 AM   #14
cas.vanderwoude
Oddometer: 18
try to find CONDUCTIVE grease. Dielectric grease is NON-CONDUCTIVE. Conductive grease is best for promoting a good electrical contact (less is better). A 2 ounce jar of the stuff will last a lifetime. Dielectric grease is like petroleum jelly - best on the outside of the connection to prevent oxidation.
cas.vanderwoude is offline   Reply With Quote
Times are GMT -7.   It's 10:49 AM.
