Old 12-10-2012, 07:08 AM   #31
cchoc
Outdoor Photographer
cchoc's Avatar
Oddometer: 203
Originally Posted by OFA View Post
What do you mean it has aux mounts?
I'm curious about this too. I have a 2013 and can't find anything on mine that looks like an aux light would mount there.
Charlie...
Stalking Light
'13 F800GS Kalamata Metallic
cchoc is offline   Reply With Quote
Old 12-10-2012, 12:44 PM   #32
TFB43
TFB43's Avatar
Oddometer: 66
Originally Posted by Angryrican View Post
this http://f800depot.com/bmw-aux-lighting-switch.html should allow you to used the harness, it replaces the back cover of the left hand switch assembly and fits both f650/800GS Twins, it is stock on the R1200GS ADV. Now the questions I have is since the plastics are different on the 13's will these brackets work with the older bikes and where do you source the power from?
This will not work on the 13.
TFB43 is offline   Reply With Quote
Old 12-10-2012, 12:46 PM   #33
TFB43
TFB43's Avatar
Oddometer: 66
If you look at the fisch you will see the two brackets that are in the kit. #2 and #3.
Old 12-10-2012, 12:48 PM   #34
TFB43
TFB43's Avatar
Oddometer: 66
What do you mean it has aux mounts? I have a 2013 and have had to mount to the headlight mount. I made a l bracket. Seems to work so far.
It's in the kit. part #2 and #3 on the fisch.
Old 12-10-2012, 01:37 PM   #35
cchoc
cchoc's Avatar
Oddometer: 203
OK, I see that now. Do you have any pictures of them mounted, I'm still not clear on how they would be installed. Thanks.
Charlie...
Stalking Light
Old 12-10-2012, 06:24 PM   #36
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,398
Originally Posted by F800ekelley View Post
13 wieghts about 40lbs more.
40lbs?! Yikes!
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
Camel ADV is online now   Reply With Quote
Old 12-10-2012, 07:00 PM   #37
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 266
It will on a 12 and earlier, my question is whether The brackets will fit the pre-facelift bikes or not.
And I guarantee there is a plug hidden somewhere to plug the lights in on a 2013's
Angryrican is offline   Reply With Quote
Old 12-10-2012, 08:05 PM   #38
ebnelson
Frozen rider
ebnelson's Avatar
Oddometer: 233
Originally Posted by Oso Blanco View Post
40lbs?! Yikes!
That seems high to me
ebnelson is offline   Reply With Quote
Old 12-11-2012, 12:16 AM   #39
TFB43
TFB43's Avatar
Oddometer: 66
Aux lights mounted on 13.
Old 12-11-2012, 06:22 AM   #40
cchoc
cchoc's Avatar
Oddometer: 203
I see, thanks.
Charlie...
Stalking Light
Old 12-11-2012, 06:41 AM   #41
OFA
Adventure Obsession
OFA's Avatar
Oddometer: 118
I have LED lights mounted on small l brackets off the headlight side bolt on my 2013. Works very well, does not interfere with the signals.
Just want to ride.
OFA is offline   Reply With Quote
Old 12-12-2012, 05:37 PM   #42
cchoc
cchoc's Avatar
Oddometer: 203
Interesting. Any chance you can post a picture or two of your setup?
Charlie...
Stalking Light
Old 12-12-2012, 05:39 PM   #43
soph9
Bike Addict
soph9's Avatar
Oddometer: 2,351
I would like to see that also..hard to envision any Aux lights mounted on the head light not interfering with the signals..
soph9 is offline   Reply With Quote
Old 12-14-2012, 04:20 AM   #44
OFA
Adventure Obsession
OFA's Avatar
Oddometer: 118
The mounts keep the lights tucked in and clear the signals.
Just want to ride.
Old 12-15-2012, 05:31 AM   #45
cchoc
cchoc's Avatar
Oddometer: 203
Thanks for the picture.
Is it easy to see the signals flash when the aux lights are on?
Charlie...
Stalking Light
Times are GMT -7.   It's 02:44 PM.
