Old 11-23-2012, 06:10 PM   #1
pcwirepro OP
Aspiring Adventurer
Oddometer: 282
Helicoil or TimeCert for valve covers?
I need to do five of these things and wasn't sure if one was better than the other. It looks like the helicoil is actually a coil of steel whereas the timecert is an actual threaded barrel of sorts. ~$25 for the helicoil vs ~$60 for the timecert.
Any insight would much appreciated.
pcwirepro is offline   Reply With Quote
Old 11-23-2012, 06:28 PM   #2
sno-where
Oddometer: 60
Timecerts are better then Helicoil, but for a bolt that does not have to hold a lot of torque, you are probably just fine with the Helicoils. Anything that needs to hold more torque, I would rather trust a Timecert.
sno-where is offline   Reply With Quote
Old 11-23-2012, 07:38 PM   #3
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,146
I have Helicoils in one of the caliper mounts on my truck. It's low (ish) torque, at 28 ft / lbs. but has held well.
No experience with TimeSerts or the respective torque they will handle.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Old 11-23-2012, 09:08 PM   #4
BluByU
BluByU's Avatar
Oddometer: 497
I had to repair about 7 holes when i first got my old 1100GS (previous owner was a HACK.)
I used Heli-coils as that was what I had in the tool box at the time, never had a problem, nothing backed out.
Two valve cover bolts on one head and 3 on the other as well as two exhaust holes stripped.
Worked for me
BluByU is offline   Reply With Quote
Old 11-23-2012, 09:27 PM   #5
pcwirepro OP
Aspiring Adventurer
Oddometer: 282
Worked for me
Sweet. I can get them from Amazon pretty cheap.
Old 11-23-2012, 09:40 PM   #6
LaurelPerryOnLand
Oddometer: 3,478
Nice demo video about TimeSerts:
http://www.youtube.com/watch?v=Gxnm8J9WXz8
LaurelPerryOnLand is offline   Reply With Quote
Old 11-23-2012, 10:00 PM   #7
pcwirepro OP
Aspiring Adventurer
Oddometer: 282
Good video
They both look like good options for the valve covers. My left side is currently blowing hot air/oil out the top.
Old 11-23-2012, 10:08 PM   #8
Beezer
Oddometer: 5,737
timecerts are not "better", only different. helicoils have been used on aircraft engines for new installation as well as certified repair for at least 60-70 years. I have 36 years as an aircraft mechanic... never seen a properly installed helicoil fail. to install a timesert you have to drill a bigger hole in the parent metal
Beezer is offline   Reply With Quote
Old 11-23-2012, 10:46 PM   #9
pcwirepro OP
Aspiring Adventurer
Oddometer: 282
Well then they're certainly good enough for my lowly valve covers. Do they require locktite to keep from backing out? I sure don't want to deal with them every time I adjust my valves.
Old 11-24-2012, 04:30 AM   #10
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,042
35 years of tool and die making has let me replaces 1000's of threads that people have stripped. As Beezer says...Helicoil is the King.
But watch the video Laurel perry posted. There is a whole tool kit you need to install a Timesert $$$
IMHO
#1. Helicoil - strong threads and minimal toolkit
2. Keensert(self locking) - installs with a standard tap set. see link http://www.newmantools.com/kee.htm
3. Timset - Good but lotsa tools req'd
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 11-24-2012, 07:00 AM   #11
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,936
Another vote for Timesert. I was told you have to drill a smaller hole then a Heli Coil to install, so is a plus where there is not allot of extra material. Looks much better for a bolt that will see frequent removal as well because it locks in place. If you go for timesert, be sure to get the right length. You need around 5mm of depth past the Timesert to allow the installation tool to travel deep enough to lock the insert in place.
bemiiten is offline   Reply With Quote
Old 11-24-2012, 09:20 AM   #12
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,982
I used Helicoils when repairing the threads on old Brit bike cylinder heads. Never a failure. No special tools just a bit of care.
def is offline   Reply With Quote
Old 11-24-2012, 09:27 AM   #13
def
def's Avatar
Oddometer: 9,982
Agreed. Always consider the advice of an aircraft mechanic. They repair and rebuild engines, airframes and other systems that lives depend on.
Old 11-24-2012, 12:10 PM   #14
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,256
I've repaired dozens of valve cover threads with Helicoils, never an issue. It is simple, easy to do freehand, and holds the minimal 8nm of torque just fine.
I've used Helicoils on head studes and brake calipers with no issues as well.
Jim
JimVonBaden is online now   Reply With Quote
Old 11-24-2012, 01:08 PM   #15
pcwirepro OP
Aspiring Adventurer
Oddometer: 282
Expensive kit
Jim
The kit with tap, tool and 12 inserts is $40. Do I need the tool?
Times are GMT -7.   It's 09:23 PM.
