Old 11-27-2012, 03:26 PM   #31
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,856
Originally Posted by Dan-M View Post
Hide from yourself? Alzheimer's going on too?
Very likely but I forgot, I think?
Anybody like the new avitar? I'm thinking of producing a calendar.
def is offline   Reply With Quote
Old 11-27-2012, 05:13 PM   #32
pcwirepro OP
Aspiring Adventurer
Oddometer: 282
I preferred the old one.
What was it? A flower?
pcwirepro is offline   Reply With Quote
Old 11-27-2012, 11:32 PM   #33
def
def's Avatar
Oddometer: 10,856
Yes. Yellow daffodils, King Alfreds to be specific....growing in my front yard.
I'm thinking of installing a bud vase on the GS similar to the one found on the VW Bug.
Old 11-28-2012, 11:55 AM   #34
little foot
Scratch and Sniff
little foot's Avatar
Oddometer: 7,007
I use Heli coil on aluminum intake for a small block chevy requiring 30 foot pounds of torque. no issues ever.
A little wear and tear is expected.
little foot is offline   Reply With Quote
Old 11-29-2012, 11:59 AM   #35
Steveman
Steveman's Avatar
Oddometer: 471
Originally Posted by bwprice100 View Post
IMHO helicoils work well when the bolt is left in place but can cause problems when the bolt has to be removed on a regular basis, so I would go for the TimeCert.
Brian
+1 fully agree. And yes I worked on McDonell as well as Boeing planes as technician and engineer for more than a decade, mention that cause not all aircraft specialists are in love with HeliCoil
Well, for the low torque bolts in question it does not play a role if you use HC or TC or whatever ...
Steveman is offline   Reply With Quote
Old 11-29-2012, 06:26 PM   #36
def
def's Avatar
Oddometer: 10,856
Then there were those who were promoting glue or JB Weld for the repair...
Ya might as well use bubble gum.
Old 11-29-2012, 10:15 PM   #37
Beezer
Oddometer: 5,949
OK.... some of you are saying that if the bolt is removed often, the Helicoil can have "problems"..... please explain.
Beezer is offline   Reply With Quote
Old 11-30-2012, 02:58 AM   #38
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,077
Gonna luv to see how this one gets spun !
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 11-30-2012, 09:23 AM   #39
Steveman
Steveman's Avatar
Oddometer: 471
Yep, may work well too
Old 11-30-2012, 12:15 PM   #40
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,623
Some think the heli-coil will beck out with the screw, but experience tells this is simply not the case.
Jim
JimVonBaden screwed with this post 11-30-2012 at 04:18 PM Reason: spelling
Old 11-30-2012, 01:20 PM   #41
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,796
Originally Posted by JimVonBaden View Post
Some thing the heli-coil will beck out with the screw, but experience tells this is simply not the case.
Jim
The only time I saw this happen was with a stainless screw in a stainless helicoil without any lubricant, a condition the Helicoil documentation will tell you to avoid.
The screw galled and welded itself to the helicoil. This would not have happened had the screw been lubed.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Times are GMT -7.   It's 12:00 AM.
