Old 11-23-2012, 08:24 PM   #1
CHAPIN OP
Oddometer: 166
V-Strom 650 footpeg equivalent
Do any of you smart people that live inside my computer know if a footpeg from another motorcycle would fit my weestrom? I managed to lose the left front footpeg in a little incident and the local dealer doesn't have one in stock. I could order one from a website but would rather look for an alternative if such thing is available.
Thanks for any help.
Hector
My ego has been writing checks my body can no longer cash.
CHAPIN is offline   Reply With Quote
Old 11-23-2012, 09:23 PM   #2
CHAPIN OP
Oddometer: 166
Hmmm
Come on people, you allways fix my problems for me!
Hector
Old 11-24-2012, 01:47 AM   #3
Jamie Z
Jamie Z's Avatar
Oddometer: 7,790
I'm pretty sure you'd have to order any other footpeg too. Might as well get the right one.
There are a handful of aftermarket alternatives. Somewhere I've got a set that I bought a few years ago and used for a short time. I didn't like them so I put the stock pegs back on. I couldn't tell you the brand anymore, it was too long ago.
If I remember, there was talk that KLR pegs fit the bike, too... but I might not be remembering that right.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Old 11-24-2012, 06:30 AM   #4
CHAPIN OP
Oddometer: 166
I'm trying to avoid having to import
In yhe days of click and buy importing stuff into Guatemala is not really a problem, but ut takes about a week to get the stuff ehand I want the pegs ASAP. So I'm thinking if getting an interine set installed while I import the correct ones.
I own a KLR, will check if those pegs work. I have the original KLR pegs, kept them "just in case" when I intalled the aftermarket ones.
Hector
Old 11-24-2012, 07:06 AM   #5
Craneguy
British Hooligan
Craneguy's Avatar
Oddometer: 1,035
You should ask this question of at www.stromtroopers.com
Someone there may have a spare they could send you.
Young enough to think I can. Old enough to know I shouldn't. Stupid enough to do it anyway
'13 Duc Multi GT, '10 Vstrom 1k, '10 705cc KLR
Craneguy screwed with this post 11-24-2012 at 12:42 PM
Craneguy is offline   Reply With Quote
Old 11-24-2012, 08:13 PM   #6
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
either dr650 or klr will
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 11-25-2012, 04:07 AM   #7
CHAPIN OP
Oddometer: 166
I'll try the KLR's. I believe the dealer does have the DR's in stock. Thanks for the advice.
Hector
Old 11-28-2012, 05:22 AM   #8
sierraoffroad
sierraoffroad's Avatar
Oddometer: 1,339
pm me if you want one fairly new. i took mine off and installed fasstway pegs that were meant for a bmw f650gs.
2013 Super Tenere
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 11-28-2012, 07:33 PM   #9
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
Hector
i think the klr has slightly smaller pin holes you need to drill out for the strom or the dr one has slightly larger holes compared to the strom and moves around a little. you can get those $15 ebay IMS knock-offs for off-road grip vrs oem pegs. there are threads on stromtropper or vrsi about that.
Alaska
Old 11-28-2012, 10:03 PM   #10
PeterW
Oddometer: 2,742
Ebay knock-off KLR pegs worked fine on my DL.
Not noticeably loose, no fitting problems.
Actually outlasted my first DL and are now on my second.
Pete
PeterW is offline   Reply With Quote
Old 11-29-2012, 05:38 PM   #11
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,244
Pete
there ya go. then it was the DR pegs that would fit loose as i think the pins are larger and thus the holes in the pegs larger.
http://www.ebay.com/itm/1987-2005-KA...71af74&vxp=mtr
Alaska
Times are GMT -7.   It's 01:56 PM.
