Old 11-24-2012, 06:10 AM   #1
tunp OP
tunp's Avatar
Oddometer: 284
LED headlight issue
I decided to replace the stock 35 w headlight of my TE610 w/ a 20w max LED. Great light but since i have done this the max battery light flashes indicating overcharge. If i add an addtional 15w or so bulbs to circuit problem solved. So i have researched adding resistors and just have my self more confused.
What would be the recommended way to add 15 or so watt draw to headlight circuit w/o using bulbs.
thanks
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 11-24-2012, 06:59 AM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,651
how about another 20w LED? twice the light.
Or how about running the LED using a mini relay so the headlight circuit on your bike is essentially unconnected.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 11-24-2012, 09:03 AM   #3
victor441
victor441's Avatar
Oddometer: 931
If you do go with a resistor it needs to be about 15 ohms to dump about 15W...a 15W load would pull about one amp at 15 volts... R = V/I = 15/1....resistors are rated for power in watts so a 15 ohm 25W should work OK
A zener diode might be a better solution, that is how the old British bikes regulated voltage....that way your lights could be switched and your battery would not get cooked by excess voltage. If you do get one intended for a British bike make sure it is for a later negative ground model, the PN is 49589
victor441 screwed with this post 11-24-2012 at 09:49 AM
victor441 is offline   Reply With Quote
Old 11-25-2012, 08:40 AM   #4
tunp OP
tunp's Avatar
Oddometer: 284
thanks gents.
Ridin w/ a smile
Tony A
Old 11-25-2012, 12:28 PM   #5
aardschok
Fallout Rider
aardschok's Avatar
Oddometer: 557
that won't confuse him.
"When you have to shoot...Shoot! Don't talk."
MVT
aardschok is offline   Reply With Quote
Old 11-26-2012, 06:58 AM   #6
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,651
I'll explain using pictures and line drawings
Nessmuk
Times are GMT -7.   It's 09:53 AM.
