11-24-2012, 07:55 AM
#1 |
Have Fun, Don't Die!
Oddometer: 1,833
Klim Powerxross Pullover
Looking for opinions on the klim powerxross pullover. Can it be worn over a pressure suit with a Leatt brace? Also is it a cold weather only jacket? I would be wearing it over pressure and jersey.
Roaming Rally 2011Roaming Rally 2012 Roaming Rally 2013 "I don't hate people...I just feel better when they are not around." - Henry Chinaski |
11-24-2012, 09:35 AM
#2 |
Go Outside
Oddometer: 2,387
They are basically a Gore-Tex shell. - It will fit over a pressure suit if you pick the correct size. Probably one size up, depending on the suit. - They are not specifically designed for a neck brace.
Here is a video from RevZilla. http://www.youtube.com/user/RevZillaTV?v=jj-qREsgZ8M . |
11-24-2012, 10:56 AM
#3 |
Making new friends
Oddometer: 696
It is just a light weight shell. You will need to add layers for cold weather.
I would think it would make a nice enduro jacket for cold/nasty weather. Not sure how it would fare in warm weather? It might be just fine for that as well. It should fit over armor if you size it right. I wear a KLIM Tomahawk jacket for ADV touring riding. I wear a pressure suit under it.
2010 KTM 530 XC-W / 2009 KTM 950SE I don't know everything, but what I don't know, I lie about |
11-27-2012, 01:54 PM
#4 |
Oddometer: 1,833
That is what I'm looking for, a summer wet/cool weather enduro that will fit over a pressure suit. Would it be possible to still wear the leatt on top of it?
11-28-2012, 12:56 PM
#5 |
Oddometer: 5
Powerxross pullover
Yes you can wear the brace on the outside, might need to adjust the brace a little depending on how loose you wear it. Several US riders wore that jacket at last years Dakar Rally.
11-28-2012, 01:02 PM
#6 |
Oddometer: 16,034
Dont' know if they're neck-brace-compatible or not... kinda doubt it.
But ... it's more of a shell, a wind-/water-proof layer, than a "jacket". As far as armor compatibility, yep. Almost every sledder I know wears a Tekvest underneath. Unless your armor's really bulky it'll fit. Round the size up if you're inbetween and it'll work fine.
Spewer of the poignant non sequitur |
11-28-2012, 01:13 PM
#7 |
Oddometer: 1,833
Awesome thanks!
11-28-2012, 04:09 PM
#8 | |
Go Outside
Oddometer: 2,387
![]() http://www.adventure-spec.com/defaul...t-chooses-klim . |
