Old 12-01-2012, 11:03 PM   #1
motormo OP
Oddometer: 11
Question noise comes up at around 65 mph
hello my bmw gs 1100 1998 is making a strange noise.
It happens when i speed up to 65 mph and it sounds like a vent , is coming from the front part of the bike , when i slow down it stops. The noise is steady meaning doesn't change intensity if i go faster it just comes on when i get to around 65 mph and then stops when i slow down.
I changed the fuel pump and the fuel filter but that wasn't it because the noise is still there.
Any suggestions?
Thank you.
motormo is offline   Reply With Quote
Old 12-02-2012, 05:00 AM   #2
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,826
Maybe front wheel bearing(s) going bad? How many miles on the bike?
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 12-02-2012, 07:51 AM   #3
motormo OP
Oddometer: 11
Thanks for the replay, the bike has 68k mikes.
Old 12-02-2012, 09:55 AM   #4
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,616
ear plugs? they all do that
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline   Reply With Quote
Old 12-02-2012, 09:58 AM   #5
mitchapalooza
Rider is Air-cooled
mitchapalooza's Avatar
Oddometer: 111
Traditionally a bearing will vary its frequency with speed to a certain point, rather than being on light a light switch then back off. .02c
mitchapalooza is offline   Reply With Quote
Old 12-02-2012, 10:03 AM   #6
motormo OP
Oddometer: 11
I tend to agree a bearing problem would change the intensity of the noise with the change of speed . But unfortunately it is not a sound i think i can ignore with ear plugs.
Old 12-02-2012, 10:37 AM   #7
catweasel67
Oddometer: 8,856
Any chance your tyres are worn? I had a noise, like a low pitch whine, that popped up each time each time I cornered...several people suggested it was the bearings but it turned out to be tyre wear.
catweasel67 is offline   Reply With Quote
Old 12-02-2012, 10:47 AM   #8
motormo OP
Oddometer: 11
the tire are almost new very quiet i have street tires.
Old 12-02-2012, 11:44 AM   #9
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 389
Speedometer?
Not sure what you mean by the noise "sounds like a vent", but you may try disconnecting the speedometer cable at the wheel. After doing so, if the noise is not present, it could be a loose speedo cable connection top or bottom, a worn or poorly lubricated speedo cable, or a speedometer in need of lube.
ElMartillo is online now   Reply With Quote
Old 12-02-2012, 11:50 AM   #10
motormo OP
Oddometer: 11
thanks , i'm gonna check that out.
Old 12-02-2012, 04:58 PM   #11
motormo OP
Oddometer: 11
i think that was it , i disconnected the cable and the noise is gone.
Thank you so much.
Old 12-02-2012, 06:05 PM   #12
ElMartillo
I See Faces...
ElMartillo's Avatar
Oddometer: 389
Happy to help.
Follow this link to see how my similar situation was resolved: http://advrider.com/forums/showthread.php?t=756825
My fix involved removing the speedometer to facilitate lubrication. I left it on the workbench overnight face-down.
Cheers!
Old 12-02-2012, 06:21 PM   #13
motormo OP
Oddometer: 11
Thanks great info , i really appreciate your help!
Times are GMT -7.   It's 08:00 AM.
