Old 11-24-2012, 01:58 PM   #1
Noswal OP
Noswal's Avatar
Oddometer: 84
Airhead Centerstand Question
So- I just picked up a 1975 R90S and the centerstand can only be deployed by hand- the little arm thing that you step on to drop the stand is broken off right at the left centerstand arm. I guess my options are:
(a) buy/find a new/used centerstand.
(b) weld a new arm onto the existing stand.
(c) find out if there is some sort of aftermarket bolt on type thing that would restore it's function.
The arm thing that is missing (at least on my old /6) was flimsy at best and sort of grew to become this ugly, twisted piece of metal- there has to be something better...
What do you guys do when that piece twists or breaks?
Noswal is offline   Reply With Quote
Old 11-24-2012, 02:40 PM   #2
JonnyCash
turd polisher
Oddometer: 1,571
The foot tang on the stock setup works fine, as long as you only use it to push the stand down until it hits the ground. Then you put your foot on the foot of the stand and rock the bike up onto the stand. I realize that that might not be as clear as I mean for it to be, but I'll hope you get the point. I'd just weld on, or have someone else weld on a tang and go with it.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 11-24-2012, 04:24 PM   #3
Sic Semper Tyrannis
Oddometer: 600
that tang ONLY lowers it to the ground. It isn't like a japanese bike where it also lever the stand into place.
Place the ball of your right foot on the left foot of the centerstand, shift your weight to the right foot, tug back with your left hand on the bars and lift straight up with your right hand....viola!
Welcome to the BMW cult...
Sic Semper Tyrannis is offline   Reply With Quote
Old 11-25-2012, 08:57 PM   #4
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,636
Some guys weld a piece(threaded rod,etc) on when that tab eventually breaks; even when used correctly, it breaks.
I don't know of an official aftermarket fix.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 11-26-2012, 01:20 AM   #5
ME 109
ME 109's Avatar
Oddometer: 2,730
I welded a piece of 12mm solid round onto my c/stand with a tiny 6mm diametre tit on the end of it.
The little piece of 6mm protrudes just enough for my boot to catch it and deploy.
Been there for years now.
Who cares about the extra weight, it's sprung. Twice.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 11-26-2012, 02:11 PM   #6
CaptDanimal
CaptDanimal's Avatar
Oddometer: 36
got one ... ya want it?
I will gladly sell you my center stand from my 87 R80rt.. I have no clue if it would work or not but they may be interchangeable? You'll have to ask around I bet. cheap cheap.. Its just sitting there
CaptDanimal is offline   Reply With Quote
Old 11-26-2012, 04:23 PM   #7
Ray R
Ray R's Avatar
Oddometer: 688
I believe you can get new ones from the dealer for @ $215. Or $160 plus $35 shipping from ebay user alteteile2003. But the latter takes a long time to ship from Germany.
Too many bikes. Not enough time.
Ray R screwed with this post 11-26-2012 at 04:32 PM
Ray R is offline   Reply With Quote
Old 11-26-2012, 09:52 PM   #8
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
B- It's an easy fix.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 11-26-2012, 10:23 PM   #9
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,548
You might want to check the legs of the center stand for wear as well. If they need patching too, you need to compare the cost of getting it all welded up to buying new. If you have to remove it, might be time to consider new bushings and bolts.
Big Bamboo is online now   Reply With Quote
Times are GMT -7.   It's 10:23 PM.
