Old 11-24-2012, 03:30 PM   #1
WPRider OP
Colorado Adventurer
WPRider's Avatar
Oddometer: 62
Cry 950 Adv Coolant in Oil ... Blown Engine?
KTM 950 Adv appears to be leaking coolant into the engine oil system. I fill the coolant reservoir, and the oil level goes up as the coolant level drops. Oil pressure warning light just came on, so no longer running the bike.
Is this an indication of a blown gasket, or worse?
Any advice greatly appreciated!
The naked adventurer
WPRider is offline   Reply With Quote
Old 11-24-2012, 03:33 PM   #2
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,100
Might be a water pump seal. Post this in Orange Crush for a better answer.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
JAB is offline   Reply With Quote
Old 11-24-2012, 06:05 PM   #3
triplenickel
triplenickel's Avatar
Oddometer: 2,200
WP seal and shaft are standard wear items and often treated as PM, post or search Orange Crush for about 6000 of these threads. The paper in the filter swells and restricts oil flow hence the light, many have gotten out of the bush by laying the bike on the right side to contain the oil and removing the filter. Short term fix but good to keep in the back of your mind just in case.
Read here;
http://www.ktm950.info/
Shop here for a kit with an aftermarket hardened shaft and forget about it;
http://www.dualsportwarehouse.com/CJ...JD-ODH-KIT.htm
Don't sweat it though, it's fuck all to fix.
07 SE
PG007
Old 11-24-2012, 10:24 PM   #4
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,157
1. Water Pump seal
2. Main Clutch cover gasket
3. Head gasket
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is online now   Reply With Quote
Old 11-24-2012, 10:46 PM   #5
Deepc
Oddometer: 267
What year & how many miles? Sounds like water pump shaft/seal. Look for a wavy oil filter or spooge on your clutch cover. I replaced mine with the cj designs shaft and updated "grey" seal. My bearings looked new so I left them alone. Don't forget to pick up a new gasket because the old one will come apart in pieces. Its an easy fix. Good luck.
Deepc is offline   Reply With Quote
Old 11-25-2012, 02:49 PM   #6
Orange Toaster
Orange Toaster's Avatar
Oddometer: 107
Head gasket check
If you can run the engine try this check. http://advrider.com/forums/showpost....71&postcount=7
It worked for me, and after replacing head gaskets things are fine.
But note, there is no guarantee that it IS the gaskets or that it is ONLY the gaskets. I also had to replace waterpump at some stage.
/OT
'03 KTM 950 Adventure
Orange Toaster is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
