Old 11-24-2012, 09:33 PM   #1
ktm55 OP
ktm55's Avatar
Oddometer: 22
990 Adv with SM wheels - who's got a 2nd set
I am very close to buying a 990 Adv. I am thinking I'll want a 2nd wheel set with street oriented tires and on the stock 21/18" wheels I run dirt oriented tires.
Who's got a similar set up ? What tires do you run? Does it freaking rail on the paved twisty stuff?
What size rims for the 2nd street oriented set? 17" for both or 17" rear + 19" front?
Going to the 19" front I discovered that the tire OD will 1" smaller so the front will drop 1/2". I need to look at suitable tires in 17" and see what OD change there will be compared to the stock 150 x 18" tire.
ktm55 is offline   Reply With Quote
Old 11-25-2012, 02:04 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,032
I run 17/19 with Michelin Anakee2 tyres.
Fantastic :)
Handles perfect with no other changes....
Peanuts is offline   Reply With Quote
Old 11-25-2012, 02:30 PM   #3
bigkuri
bigkuri's Avatar
Oddometer: 514
It's not what you ask, but for what it is worth I considered smaller road SM wheels too.
But I ended up using the stock OEM wheels with road tyres (Conti Attacks) and getting a spare dirt set with a SE rear rim.
I never notice the larger wheels on the road - the front brake is the first weakness in aggressive road riding that you will hit, not the larger 21" size...
---------- Current Bike (number 66!!): 2008 KTM SE 950 R ------------
http://950SuperEnduro.com
bigkuri is offline   Reply With Quote
Old 11-25-2012, 04:18 PM   #4
rossguzzi
Oddometer: 243
I would also like to get some road wheels with smaller front. My thinking is that then my wife could reach the ground and be able to ride it.
She use to have a Guzzi NTX 650. Fully loaded panniers/30 lt fueled up no probs. (not off road)
rossguzzi is offline   Reply With Quote
Old 11-25-2012, 06:15 PM   #5
Supahflid
Wheelieless
Oddometer: 2,904
I have a 19"/17" wheelset with Conti Road Attacks on them. I spoke with the guys at Woody's Wheel Works and they helped me make the decision not to go with 17"/17". I like the smaller wheelset on the road; I dunno if it's just a "power of suggestion" thing, but I feel a lot more confident and I think I am a bit quicker through the turns. I am certainly no expert rider.
One thing I hadn't considered is the smaller wheel sizes making the bike so much closer to the ground; I usually park the bike on the centerstand. I haven't altered the stock height in any way. I don't intend to add any length to the sidestand as I probably won't have the smaller wheelset on very often.
Supahflid is online now   Reply With Quote
Old 11-25-2012, 06:56 PM   #6
rossguzzi
Oddometer: 243
I was wondering if a shorter side stand would be needed.
Old 11-26-2012, 05:13 AM   #7
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 262
I'm running 17/5.00 rear 17/3.5 front with talon hubs (crush drive rear) on a2011 990r drops into corners nicely and just add throttle to lift it out started with this to save on tire wear so much fun that i find that I Lost 30years when I Put on the 17" to do it again think I would try to use a 5.5 on the rear for a better profile with the Dunlap sport max Q2 180/55 The industry stopped using the 19" fronts 10/15 years ago Yes the leading axle is not found on road bikes but they dont have 10"of travel we raced 6 years of AMA supermoto with leading axles went 10mm offset and and 15mm off the swing arm to get them to turn Quicker
slidewayes screwed with this post 11-26-2012 at 05:28 AM
slidewayes is offline   Reply With Quote
Old 11-26-2012, 05:33 AM   #8
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 262
side stand is iffy at best Use the center and it dos take a little more effort to git it up that's when that 30yrs comes back
Old 11-26-2012, 08:43 AM   #9
wpbarlow
Oddometer: 7,889
Originally Posted by ktm55 View Post
...Who's got a similar set up ? What tires do you run? Does it freaking rail on the paved twisty stuff?
What size rims for the 2nd street oriented set? 17" for both or 17" rear + 19" front?...
I prefer the 19/17 to 17/17-- imho the 19/17 is pretty much perfect and the 17/17 just doesn't look right on the SE or Adv.. I've ridden similar geometry bikes that were made with 21/18 stock and they were twitchy/unstable with the 17/17.
I've run Conti Road and Trail Attacks- and prefer the Trails because they don't give up much on pavement and are better off it.
I have a CJ Designs adjustable sidestand which works very well.
Walter Barlow
wpbarlow is online now   Reply With Quote
Old 11-26-2012, 06:22 PM   #10
ktm55 OP
ktm55's Avatar
Oddometer: 22
Thanks for the input guys. Looks like 19/17 is the way to go when doing an all street ride. I'm putting that into my Adventure bike budget
Old 11-26-2012, 06:34 PM   #11
ktm55 OP
ktm55's Avatar
Oddometer: 22
Just checked out Woody's Wheel Works. For the best set up 19/17 sealed wheel set before brake rotors and a sprocket it like $2000
I guess it's just money or maybe eBay
Old 11-26-2012, 07:45 PM   #12
wpbarlow
Oddometer: 7,889
Just checked out Woody's Wheel Works. For the best set up 19/17 sealed wheel set before brake rotors and a sprocket it like $2000 I guess it's just money or maybe eBay
There's a full setup in the FM with Capo rims (best setup imo) and an extra set of fresh tires for a great price. No connection with the seller.
Walter Barlow
Old 11-26-2012, 08:40 PM   #13
brents347
KOTW 2010 Finisher
brents347's Avatar
Oddometer: 2,999
I'll add another opinione here. I have owned 19/17's and 17/17's on 3 different bikes.
The 19/17 is a great all-around wheel set. If you don't ride or ride very little dirt, I think this is a great full-time wheel set for the Adv. However, if you keep a dirt set of wheels and want an aggressive street wheel set, the 17/17 is the ticket. I does change the geometry and I makes some suspension changes when I mount them, but then they work great.
I now have a 950 SE and am in the process of building a 17/17 set of 950 SM wheels for it. They're that good.
http://173.74.246.28/ktmtalk/photoga...rs/ACF177C.jpg
Brents347 Truckee, CA.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
brents347 is offline   Reply With Quote
Old 11-26-2012, 08:51 PM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,866
Same thoughts as above. If you are going street, GO all the way. 17" are so much fun and do work. Think 990 SMR with a larger tank.
And a 950 SE with 17"s is a blast. IMO.
It feels like a big 560SMR.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer is offline   Reply With Quote
Old 11-27-2012, 05:46 AM   #15
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 262
Try DUBYA USA or build your own for haft the cost
Times are GMT -7.   It's 12:56 PM.
