Old 01-13-2012, 08:52 AM   #1
sstewart OP
sstewart's Avatar
Oddometer: 1,056
Heated Gear
Can I run my heated gear off of my acc. connections? I have a pair of Gerbimgs gloves and a Gerbings jacket liner. I have two 950 ADVs and want to set them both up for the gear. I will be running a dual-temp heat troller.
sstewart is offline   Reply With Quote
Old 01-13-2012, 09:11 AM   #2
spafxer
spafxer's Avatar
Oddometer: 2,633
The acc circuits are rated at 10 amp fuse protection each. Normally 80 % of the circuit can be used or 8 amps times 14 volts = 112 watts per acc circuit.
spafxer is offline   Reply With Quote
Old 01-13-2012, 10:46 AM   #3
slowinfastout
Just Ridin' By....
slowinfastout's Avatar
Oddometer: 1,825
10 Amps is too light. Run an SAE plug direct to the battery (use for battery trickle as well) and tie in there.
slowinfastout is offline   Reply With Quote
Old 01-13-2012, 10:59 AM   #4
ChR1s
Spherical Bastard
ChR1s's Avatar
Oddometer: 336
I run a Gerbing jacket liner & Tourmaster Synergy gloves, connected via Gerbing Temp controller, off the dash socket. Gerbing lists the draw of their liner @ 77 watts, and gloves @ 27 watts. The 10 amp fuse should be good for under 120 watts @ 12v. Theoretically.
Chris
ChR1s is offline   Reply With Quote
Old 01-13-2012, 01:11 PM   #5
BaronVonDarrin
BaronVonDarrin's Avatar
Oddometer: 614
how do you guys like heated gloves vs heated grips? Do gloves work better?
BaronVonDarrin is offline   Reply With Quote
Old 01-13-2012, 01:17 PM   #6
Tangai
Oddometer: 593
I like grips (Oxford) for 45 and above, heated gloves below that.
Tangai is offline   Reply With Quote
Old 01-13-2012, 02:40 PM   #7
ChR1s
Spherical Bastard
ChR1s's Avatar
Oddometer: 336
I've only got heated gloves with my road bike, but the wife's bike (F800GS) has heated grips. For my riding, I'd rather both. The heated grips cool off as soon as you take a hand off them, but they're very convenient. The gloves are more crap to deal with, and the non-heated grips still soak the heat away from my hands (my thumb never feels "warm" with the gloves alone). For temps in the 30-40F range, either alone is okay for me on short rides (less than an hour). But when below 20F, 30 minutes with gloves alone is where the comfort ends for me.
Chris
Old 01-13-2012, 11:03 PM   #8
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,025
The wire gauge on the ACC wires are very small. Suggest using the Gerbing kit directly from the battery.
I like the gloves much better than just heating the grips for many reasons. Add one of the bigger hand guard covers when it gets really cold, less wind=more heat. The Malcom Smith flexible covers work good and are easy on/off.
"Son, you can't do both"
Old 01-15-2012, 02:13 PM   #9
MrSandman818
INaVANdownBYtheRIVER
MrSandman818's Avatar
Oddometer: 850
Run it in your garage and find out the hard way. JK. Check the fuse rating first and make sure the gauge wire can handle the rated amperage/wattage that your looking to run. Im running my dual heat troller through the supplied fuse and wiring harness to the battery. No issues at all and Im running 90w heated jacket, heated gloves, and heated boot insoles. Now when my wife goes to hook into the "Y" that I added to run her heated jacket and gloves then well see if shit hits the fan.
Food for thought. Get the rated power consumption and google "watt to amp calculator" and a link will come up. Thats what I use to know what fuse to run in my setup. Now for proper wire size Ive been lazy and havent checked. But thats what fuses are for right
-Chrome don't getcha home, but carbon fiber sure is fancy
2005 KTM 950 Adventure - back from the dead, Was totaled.
2005 Yamaha YZ250F - low compression, because race bike
1989 Yamaha TW200 - clapped out from a tweaker
1978 Batavus 48 - back from the dead. Parked since 83'
MrSandman818 is offline   Reply With Quote
Old 01-16-2012, 08:53 PM   #10
chrish4ku
chrish4ku's Avatar
Oddometer: 832
Heat
Geez - I gotta ride up the Sierras to the 7,000 foot level to get down in the 30s...I forget how darn COLD it gets in the Midwest, etc. We whine when the temps get in the 40's...ha.
I got heated grips, and the tourmaster synergy vest. For me the key is to keep your core nice and cozy and it appears that the KTM has plenty of power to offer.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 01-17-2012, 02:21 PM   #11
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,162
Gerbings will tell you it's always better to run heated clothing directly off the battery. I'll vouch for that! I believe there are two accessory outlets for the 950/990. One is switched and one is not. I ran my Gerbings non-switched and grips switched. Prolly OK, but I had a failure in AK on my Gerbings. Turns out those connections have to be cleaned a lubed annually.
My other bikes heat my Gerbings off the battery direct.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 11-30-2012, 09:40 AM   #12
the cavalier
adventurer
Oddometer: 22
extension off of ACC wire
Hi.
I was wiring an extension from my ACC wire behind my headlight to my glove box yesterday. I was surprised to see how thin these wires were. Actually, there was a splitter from the ACC wire creating one set of connections for the socket connector on the dash and another set of connections dangling, labeled, and unused. Is this from the factory? This is what i used to run an extension into my glove box for my 90w first gear jacket liner. The wire I used was considerably thicker gauge then then ACC wire I extended from. Will this cause me problems?
Thanks for your knowledge.
the cavalier is offline   Reply With Quote
Times are GMT -7.   It's 01:29 AM.
