Old 11-25-2012, 02:14 AM   #1
Fatboy206 OP
Oddometer: 25
Oil Filters
Can anyone tell me if the oil filters used on the 1200GS and on the 800GS are the same thing?
I see that the parts numbers differ but are they structurally different?
Just checking 'cos I just got a new 1200 for myself and an almost new 800 for my wife and I will do my own maintenance.
Thanks.
Fatboy206 is offline   Reply With Quote
Old 11-25-2012, 05:27 AM   #2
Casejeep
Casejeep's Avatar
Oddometer: 739
Thanks.
Im guessing they are different since you are taking about a huge engine size different.
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 11-25-2012, 06:59 AM   #3
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
The Internet probably know...
http://www.knfilters.com/search/appsearch.aspx
Been running K&N on my F800GS for years now.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 11-25-2012, 08:06 AM   #4
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
Simple answer, no they're different.
Long answer, they're almost the same. The F filter has the same diameter and thread as the R but is shorter. The taller filter has more filter capacity and holds more oil. The R filter will go on the F bike just fine so long as the extra height doesn't hit the bash plate and you'll have to add a bit more oil. The K1300 bikes came new with a short filter and could be changed sorta easy. A bulletin changed it to a tall filter and more oil. This meant removing the sidestand in order to change it out.
K&N lists the same filter for both your bikes. If your dealer is fussy then buy the right BMW filter till the warranty runs out.
BTW, it's the same with my mowers. Two Kohler engines and one B&S. I use all tall filters since clearance isn't a problem. Why stock both? (Do they have mowers in the UAE?)
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver screwed with this post 11-25-2012 at 08:12 AM
Reaver is offline   Reply With Quote
Old 11-25-2012, 09:36 PM   #5
Fatboy206 OP
Oddometer: 25
Oil Filters
Thanks guys, got the info I was looking for.
Times are GMT -7.   It's 11:24 AM.
