Old 11-25-2012, 02:24 AM   #1
Fatboy206 OP
Oddometer: 25
Oil Filters
Can anyone tell me if the oil filters used on the 1200GS and on the 800GS are the same thing?
I see that the parts numbers differ but are they structurally different?
Just checking 'cos I just got a new 1200 as well as an 800 and I will do my own maintenance.
Thanks.
Fatboy206 is offline   Reply With Quote
Old 11-25-2012, 04:22 AM   #2
klondike1
Nobody in particular
klondike1's Avatar
Oddometer: 491
Not sure about the 800 GS but the one on my 800ST and the GSA are the same. There are others you can use for 800 ST from.
Purolator PL 10241?PL25230
Mobil1 M1-102
Bosch 3330
Supertech ST 3614
All these will fit ST You need the lower profile for the GSA due to the skid plate.
Hope this helps some anyways.
The reason for the different numbers is the washer that comes with them for the drain plug are different.
If you don't know where you're going
any road will get you there!
2009 BMW R1200GSA(Grey Boy)
2007 BMW F800ST(Blue Boy)
www.danieljenkins.ca
klondike1 is offline   Reply With Quote
Old 11-25-2012, 07:24 AM   #3
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,041
You can always look it up here: http://www.realoem.com
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 11-26-2012, 05:26 AM   #4
mtrdrms
Oddometer: 434
They are the same filter
Everyday. No excuses.
2007 BMW R1200GS
2013 KTM 450 XC-F
mtrdrms is offline   Reply With Quote
Old 11-26-2012, 11:05 AM   #5
Girthy Knobkers
Girthy Knobkers's Avatar
Oddometer: 552
They are not the same filter, just sayin.
Girthy Knobkers is offline   Reply With Quote
Old 11-26-2012, 06:13 PM   #6
mtrdrms
Oddometer: 434
Hmmm. Well BMW shows different part numbers but they sure do look the same. However, k&n, Mann, hiflo and others list the same number for both. Are you just basing the difference off the BMW number or do you know something I don't?
2007 BMW R1200GS
2013 KTM 450 XC-F
Old 11-26-2012, 07:12 PM   #7
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,620
Same filters fit..no problem..and if'n you use K&N..it would be a 164..
Amsoil would be a Eao51
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 11-27-2012, 03:11 AM   #8
klondike1
klondike1's Avatar
Oddometer: 491
Like i said the different number is due to the plug washer. Filter is the same.
Old 11-27-2012, 11:17 AM   #9
Girthy Knobkers
Oddometer: 552
Not saying you couldnt get the 800 filter to fit but I am holding both in my hand currently at the shop. The 800 is a deeper filter with much more space between the threads and the filter housing than the 1200, and the ridges around the rim for a filter wrench are quite different. Hence why I have two different filter wrenches for the 1200 and 800... different filters.
these are OEM filters I am comparing
Girthy Knobkers screwed with this post 11-27-2012 at 11:19 AM Reason: adding info
Old 11-27-2012, 12:07 PM   #10
Girthy Knobkers
Oddometer: 552
Old 11-27-2012, 12:13 PM   #11
klondike1
klondike1's Avatar
Oddometer: 491
Well i'll be. The 2 i had here were the same. Not sure what to say. I do use them(OEM) but also used Hi flow and the ones i listed from other suppliers. Some are taller but on ST it is no issue. Threads and diameter all match. I change oil often so am not as worried about the filter element. I have not found any that will actually give you their spec's as to filtration particle size etc. Is it a GS/GSA thing?
Old 11-27-2012, 04:21 PM   #12
terryckdbf
Oddometer: 1,110
WIX does and they have a filter for both of your bikes.
Terry
terryckdbf is offline   Reply With Quote
Old 11-27-2012, 05:15 PM   #13
mtrdrms
Oddometer: 434
Curious. I also had two OEM filters and they were identical looking. Oh well.
2007 BMW R1200GS
2013 KTM 450 XC-F
Old 11-29-2012, 02:33 AM   #14
klondike1
klondike1's Avatar
Oddometer: 491
Terry
I'll look them up.Thanks
Old 11-29-2012, 06:38 PM   #15
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Not only were they never the same to begin with, the old stubby F800/650 has been replaced with a longer filter than the original stubby version.
Times are GMT -7.   It's 11:42 AM.
