Old 11-25-2012, 04:38 PM   #1
bob393 OP
bob393's Avatar
Oddometer: 389
Just dies for a second and restarts
So I'm riding down the road at night just chill-in and the bike shuts off the dash and headlight go out and just as quickly, like less than one second later, everything comes back on and scared to death I ride back home. It has done this twice in the last 500 miles and never before. And the bike runs perfectly otherwise. Both time this has happened I was using a brand new ignition key and had my aux driving lights on. I'm ready to switch back to my old key and not use the aux lights and see if it does it again but I really don't see why that would do it.
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 11-25-2012, 06:55 PM   #2
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,447
Recall the same issue you described a year back on someone's 07. I maybe all wrong but.....
Sounds like the security ring in the switch.
Soon, it will just not start.
Wolfgang55 is offline   Reply With Quote
Old 11-25-2012, 07:10 PM   #3
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,295
Not the same bike but my 08 KLR used to do that before I replaced the wiring harness. It happened so quickly I wouldn't even be sure it had happened. Weirdest thing I'd ever experienced. Even seemed to lose power for less than a split second. KHI finally had a factory recall on the harnesses. I never found a problem with my old harness but the new one solved the problem.
PMR
PineyMountainRacing is offline   Reply With Quote
Old 11-27-2012, 12:01 AM   #4
funinthesun
funinthesun's Avatar
Oddometer: 249
The signal in the key ring wont kill the bike it only prevents starting(according to the dealer I talked to). sounds like something else is killing the bike. could be as simple as the key, If there are other keys or something on it causing the switch to have a bad connection on the plug or inside. Id use that key and try to get it to fali in the garage. center stand and start wiggling stuff until it dies. good luck
If you didn't crash at lease once, you were not having enough fun!
funinthesun is offline   Reply With Quote
Old 11-28-2012, 04:40 PM   #5
bob393 OP
bob393's Avatar
Oddometer: 389
Like I said it's so intermittent is scary.
I have switched back to the old key just to see what happens.
Old 11-30-2012, 06:10 PM   #6
bob393 OP
bob393's Avatar
Oddometer: 389
So far so good about 500 miles.
I did find a loose wire under the seat but that was for the driving lights and was wired directly to the battery and shouldn't have anything to do with it.
Old 12-01-2012, 02:48 AM   #7
Zoef zoef
Oddometer: 372
Sir,
It could be the wiring to and from the ignition switch. After a while, these wires can have some internal breaks.
Zoef zoef is offline   Reply With Quote
Old 12-04-2012, 05:07 PM   #8
bob393 OP
bob393's Avatar
Oddometer: 389
Originally Posted by Zoef zoef View Post
Sir,
This could be it. It wouldn't power up this morning and out of desperation I wiggled the harness into the ignition switch and it came to life. Now to fix it the dam thing
Times are GMT -7.   It's 03:33 AM.
