11-25-2012, 04:57 PM
#1 |
Oddometer: 136
Iridium plugs in your Airhead?
Anyone using Iridium plugs? I have had great success with Brit bikes using these plugs. Anyone know the Iridium equivalent to the recommended Bosch plug for the 79 R100RS? Thanks.
11-25-2012, 06:10 PM
#2 | |
Oddometer: 1,028
Ray ABC #12947 '75 R90S |
11-25-2012, 07:54 PM
#3 |
Along for the ride
Oddometer: 914
I have been considering trying the iridium plugs also but they seem to be the resistor type only so it would mean changing the spark plug caps to the no resistance type.
__________________________________________ "There's a fine line between a skinning and a shearing" |
11-25-2012, 10:50 PM
#4 |
Sarah
I always used resistor plugs in my regular (resistor) caps on my GL500 and never had problems. Is there any reason why they wouldn't work in an R100? I'm considering this for my '88 GS.
2012 R1200GS Rallye - Gypsy 2003 R1150GSA with DMC sidecar Ask A Self-Publisher "Good judgement comes from experience, and experience comes from bad judgement." |
11-26-2012, 08:24 AM
#5 | |
Oddometer: 1,410
Can someone post a pic of the difference between resistor wires/non resistor wires and is there a way to ID resistor plugs/non resistor plugs visually?
1974 BMW R90/6 Bettie #1 Quote:
11-26-2012, 08:43 AM
#6 |
Oddometer: 1,256
For me any way, not sure if it's worth the money. Between the carbon build up and oil that invariably gets drawn in through the breather in the air box and finds it way to the left plug.....I just run what's cheap and in spec. Clean them and regap with tune up.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S Save lives. Legalize lane sharing. Cow eyes don't glow. |
11-26-2012, 10:04 AM
#7 |
BigBrowedNeandereer
Oddometer: 1,009
How many manufacturers in the world use WIZBANG spark plugs as factory install?? NONE, ZERO, NADA
Not one of these teams of qualified engineers has found them viable for thousands of motor designs. Any improvements noted are so small as to make them far too expensive in a rational sence. A 2% benefit cannot overcome a doubling or more of the cost. If you are not running good enough with stock plugs, the plugs are not the problem and different plugs will not fix you. |
11-27-2012, 01:44 AM
#8 | |
Loose Pre Unit
Oddometer: 3,977
Iridium ? I don't see the point, but try it and see. I'm using Bosch W78 Plus 4's. Doubled my HP and halved the fuel consumption. |
11-27-2012, 02:00 AM
#9 |
Oddometer: 740
For airheads, there isn't a big advantage (or any) for using exotic multi electrode plugs. The combustion chamber is designed for normal plugs. However, the iridium has to do with the electrode. It allows it to be smaller and last longer. In that regard, it shouldn't matter. The plugs will last longer, and spark well longer, but will cost more. So its a matter of choice.
11-27-2012, 04:53 AM
#10 |
Oddometer: 77
my two running airheads have standard Bosch plugs but I tend to use
fancy plugs on some of my cars and bikes, silver plated in my cb750 (very short life) and platinum in my gt turbo, can't remember what I have in the others Anything that helps a bit is good in my book but I doubt I'll bother on the airheads |
11-27-2012, 08:28 AM
#11 |
Oddometer: 1,026
Wizbang spark plugs are to give extended service life in todays vehicles, think replacement @ 25-35kmiles rather than the normal 5k miles on our bikes.
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
11-27-2012, 09:27 AM
#12 |
Oddometer: 740
11-28-2012, 10:47 AM
#13 | |
Oddometer: 41
Exactly, whizzbang plugs are meant for a engine with high efficiency I.E. a very tightly controlled combustion process. These old aircooled tractor motors (while very reliable) have too much variation in combustion chamber temps with minimal fuel control. Modern fuel injection has maps to match the fuel delivery rate precisely to internal temp, atmospheric temp, engine speed and load (and other stuff). An old motor with carburetors will not keep the Wizzbang plugs clean enough to take advantage of the extended service intervals and the wizzbangs do very very very little, if nothing at all to promote combustion efficiency. You would not put iridium plugs in a 1972 Ford with a 300 6cyl and expect them to last 80k-90-100k miles even if the motor was fresh. On these antique motors save yourself some money, buy a quality "normal" plug and inspect them at the correct intervals. |
11-28-2012, 01:12 PM
#14 |
BigBrowedNeandereer
Oddometer: 1,009
11-28-2012, 01:25 PM
#15 |
Oddometer: 1,028
+ 1 . Iridium plugs provide no advantage over standard plugs.
