Old 11-26-2012, 03:25 AM   #1
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
Bluhduh Drop in Master Clutch Cylinder replacement ?
Hello,
i have a master cylinder that leaks (went through 2 rebuild kits so far). Is there another option for a drop-in replacement besides a new KTM Master Cylinder ? I'll probably get the OEM one but I'm guessing that it will fail also at some point ... so... maybe there are better options out there.
An alternative would be to get the current MC bore re-sleeved but... i haven't been able to locate someone that's willing to do that. If you have any suggestions, please pipe in.
Thank you, Alex
Alex_RO is offline   Reply With Quote
Old 11-26-2012, 03:45 AM   #2
wildehond
wildehond
wildehond's Avatar
Oddometer: 334
It is a magura master. So if you can find someone that sells magura parts to the public you might be able to get it a bit cheaper. It is the 10.5mm if I remember correctly. But have a look at the microfiche. I think KTMtwins have the microfiche online.
Wussy Namibia solo ride
wildehond is offline   Reply With Quote
Old 11-26-2012, 03:49 AM   #3
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
Thought about it
I've read a couple of threads and apparently it doesn't clear the left hand switch pod. I could get one but i would have to replace the standard switch pod also... i think (it might have been the Magura 9.5mm mc though).
Edit: According to this from this thread, the 10.5 one doesn't clear it either and i'd be losing the clutch safety switch also (I tend to like safety switches on bikes. Sometimes I'm not in the "zone" and having one of them go off tends to yank me back to reality and focus).
I guess re-sleeving the bore of the original one with a harder jacket might be the best way to approach this.
Alex_RO screwed with this post 11-26-2012 at 04:03 AM
Old 11-26-2012, 08:18 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,998
I did resleeving in two MCs
They both operate. The first one I went down to 9.0mm dia and installed it on a friend's bike. After a year he has some clutch dragging. I did the second one with 9.5mm dia. I have no dragging and believe it is not the reason the clutch drags. I also enjoy a lighter clutch pull.
So I would recommend resleeving.
Cheers.
Times are GMT -7.   It's 12:48 PM.
