11-26-2012, 02:11 PM
#1 |
Oddometer: 56
De drowning a 990 ADV
hey gang..
I have drowned many an older dirt bike over the years.. painful process to get going again.. But.. what's the deal if you drown your KTM 990 Adv .. ? has anyone done it, any good articles or video's . I did a bit of searching but didn't find much. Not that it's ever intended.. but, it happens!
e-mail : Ian@gilian.net Mobile : 0408 52 88 00 Spot : http://tracker.gilian.net Rides : KTM990ADV, BMW K1600GT |
11-26-2012, 05:30 PM
#2 |
KOTW 2010 Finisher
Oddometer: 2,980
I've done it. It sucked.
I was able to field strip the bike with my KTM tool kit, pull the plugs and crank the water out of the motor using the starter. Also, pull the plug in the exhaust (near the heads) to drain the pipe of water. I also swapped my battery for my buddies (from his 950) back and forth while cranking my bike to get it running. It took alot of cranking and I didn't want to kill the battery so when it sounded weak we would put it in his bike and idle/charge it while cranking with his battery. Total took about an hour.
Brents347 Truckee, CA. 07 Yamaha R6 07 KTM 950 Super Enduro 04 KTM 250exc- plated two-stroke |
11-26-2012, 05:52 PM
#3 |
KOTW 2010 Finisher
Oddometer: 2,980
Also, remember, if your air filter is saturated, it will continue to push new water into the motor so remove the filter if necessary.
11-26-2012, 06:37 PM
#4 |
Oddometer: 56
wow, what fun.. I do recall it taking ages even on simple old bikes though..
did the spark plug work ok after just simple air drying..? I'm guessing with the fuel injection it makes things a lot easier as Carby's used to be a nightmare.. hmm, a bit worried about the battery issue.. if you were alone I wonder how on earth you'd get by that issue.. perhaps carry some aerostat..? if you pull the air filter, remove the plug from the exhaust.. then there can only be water in the actual motor and inlet/exhaust valves - correct..? On the XR you would pull the decamp lever which lifted a valve.. as water doesn't compress.. so how do you do it on the 990, if you get water in the piston, given that it doesn't compress.. me no understand! .. I'm thinking you will just get compression lock and that's it.. ahh, you have removed the plugs, yes.. so wouldn't the water be all gone in about 20 seconds worth of cranking.. then dry the plugs, then spray some aerostat.. no air filter.. should go..? Will the engine start without the exhaust bungs in..? hmm.... questions questions.. ! :-)
11-26-2012, 06:46 PM
#5 | |
Mmmm....Orange Kool-aid
Oddometer: 1,532
Those who dance are considered crazy by those who do not hear the music. I am not the same having seen the moon shine on the other side of the world. - Radmacher 5 Cylinders vs. Moab..........My East Tennessee |
11-26-2012, 07:02 PM
#6 |
KOTW 2010 Finisher
Oddometer: 2,980
I ripped off the front of the bike. In the high-desert, in November, at dusk. As I said, it sucked.
11-26-2012, 08:27 PM
#7 |
Darth Kitten
Oddometer: 1,711
From another thread.
Having small mitts helps too!
When in doubt, take it as a compliment. Lost Coast ride report Nevada Desert ride report Campoaventura |
11-26-2012, 08:34 PM
#8 |
Oddometer: 56
can you post a link please..?
11-26-2012, 10:43 PM
#9 |
Oddometer: 280
I'm curious as well....
11-27-2012, 05:31 AM
#10 |
Oddometer: 328
If you have a few buddies lift bike to vertical on it's tail to drain exhaust, ditto rest.
11-27-2012, 05:34 AM
#11 |
Oddometer: 604
To those who understand, no explaination is necessary Too those who don't, none is possible... |
11-27-2012, 07:51 AM
#12 | |
Agnostic Adventurer
Oddometer: 2,108
![]() ![]() Not my bike. Just there to help. Only took 3 people and a suitable tree to get vert. Engine off before going under, but water flowed in the pipes. Fired right up after draining ![]() -M
'05 950ADV '04 525EXC D/S '07 Tiger1050 Will herd cats for beer (... but I rescue puppies for free SmugMug (coupon: bLfv2vBXZicd6) |
11-27-2012, 09:08 AM
#13 | |
KOTW 2010 Finisher
Oddometer: 2,980
I've used this starting technique, and it works, but there is a learning curve. The running bike has to be spinning really fast (as I recall we ended up in 4th gear or so) or the non-running bike just stalls it out. Also, I heard from one member on here who used this technique, got the running bike spun up real fast, and then dropped his bike into first gear which promptly broke the first gear in the bottom end. Much worse than just a stalled bike. Match the gears on the two bikes, and have the stalled bike in gear with the clutch in while spinning it up with the running bike. I was thinking I could have used this technique to quickly pump the water out of my motor (with the spark plugs out) instead of draining my battery with all the cranking...
11-27-2012, 11:28 AM
#14 |
Oddometer: 513
If you are on ground with enough traction you put the bike in 6th and rock it back and forth turning the engine. Also tip the bike up, like pictured above, before and after rocking.
Saves removing plugs :)
---------- Current Bike (number 66!!): 2008 KTM SE 950 R ------------ http://950SuperEnduro.com |
