Go Back   ADVrider > Riding > Regional forums > The Rockies It's all downhill from here...
Old 11-26-2012, 08:17 PM   #1
Skeeter1981 OP
Finding myself
Oddometer: 29
DRZ 250 jetting for Denver
Just purchased a 2001 DRZ-250 from a seller in Dallas. The bike does not have any airbox mods but the previous owner did remove the exhaust tip and says it is "full flow exhaust". Picking it up in 2 weeks on my next business trip but wondering what carb adjustments will need to be done so it will run here at a mile high?
[/IMG]
Skeeter1981 is offline   Reply With Quote
Old 11-26-2012, 08:40 PM   #2
Olas
the darkness
Olas's Avatar
Oddometer: 3,975
Stock jetting with stock exhaust works pretty good. If I were you, I'd buy the exhaust tip and return the jetting to stock if it was changed at all. That simple. It should run great from 5k up to 12k, that's about the range we tested the one we had in.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 11-27-2012, 07:33 AM   #3
oldmanb777
Just say NO to socialism!
oldmanb777's Avatar
Oddometer: 3,862
Send a note to Eddie AKA "Burned" he is a Mod on Thumpertalk. He is the jetting guru and very helfull in general.
oldmanb777 is offline   Reply With Quote
Old 11-27-2012, 08:06 AM   #4
bobfab
bobfab's Avatar
Oddometer: 1,395
good question... i just picked up one of these bikes myself.
It runs ok throughout the power band but has some idle hesitation and sometimes drops the idle. I debate between the pilot jet being a little clogged or undersized. Its all stock.
In any case, i will be making an appointment with Eddie (Burned) in the near future. Hes local to the front range and has made my DRZ run like never before!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 11-27-2012, 09:52 PM   #5
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,277
ask in the drz250 thread. others ride the same elevations.
you guys have the pumper carb (01-05 & non-cali) or the cv carb (06-07 & cali bikes) on yours?
http://www.advrider.com/forums/showthread.php?t=365959
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 11-27-2012, 09:57 PM   #6
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,277
maybe too rich on the pilot jet? i assume you've runner cleaner through the gas, have a clean air filter (they are very sensitive to dirt filters) and threw a new plug in (iridium prefered)? you know all the easy stuff.
Alaska
Old 11-27-2012, 09:58 PM   #7
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,277
this guy's shop right?
http://www.epicmotosports.com/index.htm
Alaska
Old 11-29-2012, 09:18 AM   #8
bobfab
bobfab's Avatar
Oddometer: 1,395
Originally Posted by eakins View Post
Thats the one! Just put a new filter in, no new plug yet. I am going to pull the carb and clean again... or just drop it off with eddie depending on timing and money...
It runs alright, but hesitates and drops the idle sometimes...
CRF250L | KTM200SX
Old 11-29-2012, 01:49 PM   #9
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,277
try a pine sol soak. i've done that with my DR and thought the carb was clean to start with. i was amazed how much more dirt come out and the bike ran alot better. http://advrider.com/forums/showthread.php?t=560117
if you have not bought a plug yet try out an iridium plug. i've found they ignite fuel mixtures that are too rich or too lean (happens alot in colo changing elevations on a carbed thumper. even more so on a 250 with a pumper carb) somewhat better than copper plugs.
looks like the drz250 takes a NGK CR9E plug which would be a CR9EIX in the iridium
or even better Denso IU27 iridium (Denso came up with the iridium design as has the smaller and better designed tip)
http://www.ebay.com/itm/1-New-DENSO-...4ce508&vxp=mtr
Alaska
eakins screwed with this post 11-29-2012 at 01:59 PM
Old 11-29-2012, 07:06 PM   #10
Skeeter1981 OP
Finding myself
Oddometer: 29
thanks to all responders.
Hoping we have similar heat wave in 2 weeks so I can get some riding in. Any one know of any decent dirt rides in the Texas panhandle?
Old 11-29-2012, 07:11 PM   #11
Skeeter1981 OP
Finding myself
Oddometer: 29
I may take you up on an air filter or two
Skeeter1981 screwed with this post 11-29-2012 at 07:16 PM
Times are GMT -7.   It's 08:15 AM.
