Go Back   ADVrider > Riding > Regional forums > Europe
Old 11-27-2012, 01:16 PM   #1
muddymatt OP
muddymatt's Avatar
Oddometer: 150
KTM 690 R Error Code 90
After a couple of months lay up I started my KTM 690 up with no issues and let it slowly warm up. I then took it on a test ride but only got 100m before it started over revving on tickover and misfiring.
Back in the garage I noticed the FI light blinking and sure enough every time I switch it on it comes up with a code 90 with is Throttle position circuit failure.
The bike will start but wants to over rev holding the throttle shut against the stop alleviates this a bit.
Doesn't seem to be any caught cable and throttle operates fine.
Should I get it checked out on a diagnostic machine at a dealership or attempt to strip down where the cables go into the throttle position sensor on the right hand side of the FI unit.
All opinions gratefully received.
Matt
muddymatt is offline   Reply With Quote
Old 11-27-2012, 03:39 PM   #2
TelfordKnobby
TelfordKnobby's Avatar
Oddometer: 222
Ebay it Quick, before she blows
TelfordKnobby is offline   Reply With Quote
Old 11-28-2012, 05:04 AM   #3
Pumpy
Exiled Pumpernickel
Pumpy's Avatar
Oddometer: 1,107
You may get a better response if you post your question in the Orange Crush section, Matt.
www.pumpernickelontour.com - Four months through South America on a DRZ - Ride Report: One day... you have to live your dream
Pumpy is offline   Reply With Quote
Old 11-28-2012, 10:27 AM   #4
Chrisbarnes1
Oddometer: 494
690 error code
Good advice on the error code. My friendly dealer mechanic at Gear 4 may be able to spare a few minutes to chat--or I could ask him personally if you are stuck. It may be something simple like turning on the ignition and operating the throttle to the stop a couple of times, and then trying a start--could have lost a setting if the battery has died or been removed?
Regards, CB
Chrisbarnes1 is offline   Reply With Quote
Old 11-28-2012, 11:22 AM   #5
shipwrek12001
Shipwrek
shipwrek12001's Avatar
Oddometer: 2,092
post in thumpers... new and improved ktm690 wunderfest
http://www.advrider.com/forums/showthread.php?t=722987
lots of wisdom there
shipwrek12001 is offline   Reply With Quote
Old 11-28-2012, 11:25 AM   #6
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,221
Matt
Matt,
I thought Error Code 90 referred to Porr Riding ability or so Clive tells me?
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 11-28-2012, 12:09 PM   #7
muddymatt OP
muddymatt's Avatar
Oddometer: 150
Originally Posted by Possu View Post
Matt,
Tell him it can't be that Steve otherwise all my other bikes would be exhibiting the same symptoms.
I was going to ask Clive as he has experience of 690 issues.
On second thoughts maybe not !
Old 11-28-2012, 12:32 PM   #8
strobingred
strobingred's Avatar
Oddometer: 163
throttle reset
Hi mat, Check out the throttle resrt by running it for 15 minutes or something like that. I am sure it is on the forums somewhere
http://www.monomaniacs.nl/tnt/KTM-69...hrottle-issues
try here
clive
Onwards and upwards
strobingred is offline   Reply With Quote
Old 11-28-2012, 03:06 PM   #9
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,108
Ready to rice.......Japan is returning real soon.
The Rave Generator......
Timpo is offline   Reply With Quote
Old 11-28-2012, 10:16 PM   #10
CrazyIvan
Vonkentrekker
CrazyIvan's Avatar
Oddometer: 152
You have been riding quite a bit together with Clive, so probably your bullshit filter is clogged.
CrazyIvan is offline   Reply With Quote
Old 11-28-2012, 11:19 PM   #11
LOZ
Oddometer: 1,206
try the 15 min idle,start bike from cold without touching the throttle and let it run for 15 min,also try with ignition on but engine off slowly twist the throttle wide open then slowly close it,both things re-set sensors
look in new and improved ktm690 wunderfest
loz
LOZ is offline   Reply With Quote
Old 12-03-2012, 07:13 AM   #12
Tim
Tim's Avatar
Oddometer: 2,362
What? No swearing and/or piss taking from Loz? - Must be shom mishtake!
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Times are GMT -7.   It's 07:53 PM.
