Old 11-28-2012, 05:12 AM   #1
jonz OP
Miles are my mantra
jonz's Avatar
Oddometer: 2,477
Replacing 950SE oil sight glass
Howdy gang,
I sheared off one of the bolts supporting the oil tank. In trying to remove that broken bolt, I broke off an extractor in the bolt . I sent it to a machinist who used a water jet to remove those parts. The water jet hit one of the interior baffles which deflected it into the sight glass and blew it out.
I have another sight glass now and wondered if there is any trick to putting it in the oil tank? Or do you just push it in?
BTW, the machinist made a tapered seat and matching aluminum plug where the bolt had been, and then welded it into place. Drill and tap, and I'm back in business. And yes, I spent a half hour or so rinsing and rinsing and rinsing and rinsing out any metal debris left in the tank. Also, I know EDM machining would have been the ideal way to go (at least, so I've been told) but I had a time crunch and this was immediately available.
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is offline   Reply With Quote
Old 11-28-2012, 06:41 AM   #2
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,155
Not sure about the sightglass, but the waterjet near me uses a mixture of water and garnet to cut. Make sure you rinse that tank really well.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 11-28-2012, 06:52 AM   #3
jonz OP
Miles are my mantra
jonz's Avatar
Oddometer: 2,477
The water jet used silica with the water. So yes, i rinsed and squirted alot. I also swabbed wherever I could reach with Qtips and haven't been able to find any grit. I'm gonna run some cheap oil up to operating temp. and drain that and change the filter too.
Sent from my DROID X2 using Tapatalk 2
JONZ
STOC #326 IBA #217
Old 11-30-2012, 03:11 AM   #4
ata
expat in the jungle
ata's Avatar
Oddometer: 2,294
no trick
be careful when fitting and that´s all
if you feel better put a little bit of seal silicone
Youth is wasted on the young
Need some help<<<<<<>>>>>>> wet wanderings
ata is offline   Reply With Quote
Old 11-30-2012, 10:25 AM   #5
jonz OP
Miles are my mantra
jonz's Avatar
Oddometer: 2,477
The parts manual showed using locktite so that's what I did. I found a socket with the same diameter and used that to push it in until I could get the snap ring in its groove. So far, so good.
JONZ
STOC #326 IBA #217
Times are GMT -7.   It's 09:07 AM.
