Old 11-28-2012, 01:26 PM   #1
ACP OP
ACP's Avatar
Oddometer: 79
Spragged off!!!
Anyone know anything about the starter freewheel (sprag)?
My 04 950S (only 17k miles) has been having trouble starting when hot. All the symptoms and noises, going by the experience and threads of others here seem to point to the starter freewheel (sprag clutch) being the culprit.
BUT, I've taken the thing apart, and all the components look in good nick and as I think they should, not all mangled with major scraping between components and flat spots etc. as seen on TB0554 and here
So, what I want really is confirmation that these components are indeed shagged before I go and spend 450 on a new assembly which includes an ignition rotor I don't need! Can anyone confirm for me that these components are OK or not?
Here are the:
freewheel hub
sprag clutch
starter freewheel
It's definitely NOT a clacking torque limiter prob as it doesn't have one! The only other suspects I can think of are the starter solenoid which I've checked for corrosion / poor contacts and is fine. The bike has a new and well charged battery. Is there any chance that the starter motor itself may be at fault and not spinning up fast enough to engage the sprag?
T.I.A.
Andy
950 GO!!!!!!!
690 Enduro R
ACP is offline   Reply With Quote
Old 11-28-2012, 01:43 PM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
I had the sprag fail on me.
The little beans looked flat one one side. The problem appeared as hissing sound and the motor would not start, draining the battery.
In case you move on to replacing the sprag, you can buy the sprag for the 640 and use the little beans, replacing the old ones.
However very unlikely on your almost new bike.
Maybe you need to check if your freewheel is spinning on the cranckshaft. You probably do not have a woodruf key installed as later models. Could this be your problem?
Cheers.
gefr screwed with this post 11-28-2012 at 02:06 PM
Old 11-28-2012, 01:53 PM   #3
ACP OP
ACP's Avatar
Oddometer: 79
Originally Posted by gefr View Post
The little beans looked flat one one side. The problem was a hissing sound and the motor woul not start, exausting the battery.
In case you move on to replacing the sprag, you can buy the sprag for the 640 and remove the little beans, replacing the old ones.
Maybe you need to check your freweel is not spinning on the cranckshaft. You probably do not have a woodruf key installed. Could be this your problem?
Cheers.
Thanks, I'm aware of the 640 bean swap replacement. I think I must have read your posts on it. The ones in the sprag now don't appear that worn. Do you think it'll help in this case?
It's defo not the flywheel spinning on the crank. It is indeed keyed thank feck
950 GO!!!!!!!
690 Enduro R
Old 11-28-2012, 02:10 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
Can you check your motor is spinning?
That would be the first step.
Old 11-28-2012, 07:02 PM   #5
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,101
I could be wrong, but on Aprilias (they are similar) there is a long thin spring that goes around the outside. If stretched it causes problems. Some have shortened it and cured certain problems.
rossguzzi is offline   Reply With Quote
Old 11-28-2012, 10:32 PM   #6
TcRulz
Oddometer: 289
I'm with Gefr. My 03 950A doesn't have a woodruff key that stops the rotor from spinning on the crank. Seeing as how the freewheel locks the starter to the rotor, my guess is the rotor is spinning on the crank. Needs to be really tight as it's only a tapered fit.
Just replaced my freewheel at 73000km only because it was apart....in comparison yours is new.
TcRulz is offline   Reply With Quote
Old 11-29-2012, 11:04 AM   #7
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,541
Originally Posted by ACP View Post
...before I go and spend 450 on a new assembly which includes an ignition rotor....
If you have an un-keyed flywheel, and are interested in used parts, send me a PM.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 11-29-2012, 01:51 PM   #8
ACP OP
ACP's Avatar
Oddometer: 79
Thanks guys
the spring looks in excellent condition all the way around.
It DOES have a Woodruff key so it's not the flywheel spinning on the crank. Thanks for the offer
950 GO!!!!!!!
690 Enduro R
Old 11-29-2012, 01:55 PM   #9
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 700
In my experience, difficulty turning over the engine when hot indicates a worn starter motor.
uraberg is offline   Reply With Quote
Old 12-02-2012, 03:36 AM   #10
charlie264
charlie264's Avatar
Oddometer: 8,508
The sprag bearing should grip instantly in its non rotational direction; even if the starter motor is lazy it should transfer the torque of engine to motor. Check the sprag bearing by hand holding it in a vice, I’ve not taken the starter system out of the LC8 but if the starter motor is still turning and the sprag is good, only two possibilities, gear is slipping on the starter motor shaft or its spinning in the wrong direction.
If you need a new sprag bearing try AR bearings first http://www.arbearings.co.uk
Old 12-03-2012, 02:00 PM   #11
ACP OP
ACP's Avatar
Oddometer: 79
Cheers Charlie,
I'm going to put it back together and see what happens. If it keeps doing it I may try replacing the sprag bearings followed by new parts (last resort)....
Just need to wait for the Loctite 648 to turn up!
950 GO!!!!!!!
690 Enduro R
Old 12-03-2012, 02:23 PM   #12
MortimerSickle
Semi-Adventurer
Oddometer: 12,541
If you can't find 648, Permatex High Temperature Sleeve Retainer should do the trick. IIRC, it specs out even stronger than 648.
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 12-03-2012 at 02:30 PM
Times are GMT -7.   It's 12:36 PM.
