Old 11-28-2012, 06:08 PM   #1
firstwordisee OP
Oddometer: 20
Mounting a tool box
New to the forum, thanks for all the helpful information the regulars post here. I am thinking about mounting a tool box behind my license plate on my '12, 1200GS. I got the idea on the forum and have seen a couple of pictures here however the search engine makes it difficult to find more info. I have the standard BMW luggage so there is not really enough room to mount anything behind the luggage (think about this when buying the BMW luggage!)
I was looking at these boxes http://www.pelicancases.com/1150-p/1150.htm.
Any feedback would be appreciated, it looks pretty easy to do but not sure if there is a better option, if box is a good size, if there are problems others have experienced etc.
Thanks.
firstwordisee is offline   Reply With Quote
Old 11-29-2012, 02:41 PM   #2
LaurelPerryOnLand
Oddometer: 3,482
"100 Threads..."
http://advrider.com/forums/showthread.php?t=836736
Item #44
More for GSA's but perhaps some ideas...??
LaurelPerryOnLand is offline   Reply With Quote
Old 11-29-2012, 03:19 PM   #3
norcal1
Cameron Park, CA.
norcal1's Avatar
Oddometer: 217
If you find the thread let me know. All I can find is the GSA behind the luggage rack. I would like to see the one you are talking about behind the lic. plate.
norcal1 is offline   Reply With Quote
Old 11-29-2012, 05:24 PM   #4
firstwordisee OP
Oddometer: 20
Originally Posted by LaurelPerryOnLand View Post
"100 Threads..."
Item #44
Yea, already checked those out, not enough room behind the standard Vario Luggage mounts for any of those as far as I can tell.
Old 11-29-2012, 05:52 PM   #5
LaurelPerryOnLand
Oddometer: 3,482
Correct-a-mundo!
Old 11-29-2012, 06:46 PM   #6
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,411
There's this one.
And I made one of these.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 11-30-2012, 02:52 AM   #7
klondike1
Nobody in particular
klondike1's Avatar
Oddometer: 482
OK there is this
http://www.advrider.com/forums/showt...hlight=pelican
this
and this
http://www.advrider.com/forums/showthread.php?t=681075
I know some are not what you wanted but may get you going in right direction. I will say the pelican on the inside of GSA cases is a pain in the butt to get at. Nice and out of the way mind you but not very easy access. Tubes are accessible all the time. I may put my tubes back on in the spring.
My 2 cents anyway.
If you don't know where you're going
any road will get you there!
2009 BMW R1200GSA(Grey Boy)
2007 BMW F800ST(Blue Boy)
www.danieljenkins.ca
klondike1 is offline   Reply With Quote
Old 11-30-2012, 05:05 AM   #8
Spaggy
Spaggy's Avatar
Oddometer: 999
Here's how I did mine on the 1150. Used for a first aid kit. Gotta like Pelican, indestructible and water/dust proof.
Spaggy is offline   Reply With Quote
Old 11-30-2012, 10:52 AM   #9
terryckdbf
Oddometer: 1,081
These are mine:
Terry
terryckdbf is offline   Reply With Quote
Old 11-30-2012, 03:21 PM   #10
klondike1
klondike1's Avatar
Oddometer: 482
After seeing these past post i will be moving my pelican in the spring!!
Old 11-30-2012, 03:45 PM   #11
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,478
If you go solo, and don't have the GSA luggage mounts (I have Micatechs, so no frames), you can always do something like this...it's mine, I have it mounted on a pillion deck plate:
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 11-30-2012, 08:02 PM   #12
firstwordisee OP
Oddometer: 20
Terry and Rockmuncher
The pelican behind the plate is excactly what I had in mind. Ater using it how do you like this type of mount, is there anything you would suggest? Can you fit a decent tool kit in it? Is that the "small" 1150 pelican?
Old 11-30-2012, 08:05 PM   #13
firstwordisee OP
Oddometer: 20
Desert Skies
Very nice work! I wish I had the means to fabricate something like that.
Old 12-01-2012, 03:00 AM   #14
DDT Rider
Oddometer: 473
Originally Posted by terryckdbf View Post
These are mine:
Terry
Cool!
A couple Qs:
- I see you have the pelican 1120 on the side...it the back unit also the 1120?
- If you fill that up with tools, does the extra weight move that back fender/attachment point much?
Many thanks!
DDT Rider is offline   Reply With Quote
Old 12-01-2012, 05:48 AM   #15
Spaggy
Spaggy's Avatar
Oddometer: 999
I think mine is the 1150. It's the perfect place for something light like a first aid kit. If you're using it for a tool kit, with more weight, I would brace it from behind just so it doesn't shake back and forth and break loose of the fender. I'm going to brace mine now that I've changed luggage and have a side to side brace behind it now.
Here's the interior dimensions of the 1150, 8.18" x 5.68" x 3.62".
The only concerns I would have about using it for tools is when you open it, will they all fall out? Also, if they are wet at all when you put them away, they might rust bad being a waterproof box.
Worst case scenario, you use it for something else.
Times are GMT -7.   It's 09:27 PM.
