Old 01-06-2013, 08:27 PM   #166
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,205
I have a Shorai in the Husaberg and it has started up first or second push every time.. down into the low 30's... sat for the last 3 weeks in my garage and fired up this morning first push.. didnt even pull out the cold start button.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 01-07-2013, 01:17 PM   #167
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,275
Originally Posted by RhodeHazard View Post
I have not had luck with any Lithium battery holding a good charge in the cold.
That has been the discussion on the DR650 thread lately. People say you have to turn on your headlite for 2 minutes to "warm" up the battery.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-07-2013, 01:41 PM   #168
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,772
Lithium does hold a charge a lot better than lead acid though. I haven't used mine enough to really give a decent review though. It hasn't caught on fire though, I can say that much.
akarob is online now   Reply With Quote
Old 01-07-2013, 05:38 PM   #169
Drewha
Thunderbirds Are Go
Drewha's Avatar
Oddometer: 595
Do you guys use battery tenders? Everytime the bikes come into the garage, the tender goes on , reguardless of time of year. Never have had a battery issue. Just my 2cents.
08 Husqvarna TE 610
04 Ducati ST3
Drewha is offline   Reply With Quote
Old 01-08-2013, 08:08 AM   #170
lester3
Oddometer: 136
i have a Battery Tender JR. it works great. plug it in .. when the light turns green .it is charged. its that easy
lester3 is offline   Reply With Quote
Old 01-08-2013, 10:41 AM   #171
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,205
I have three bikes and four battery tenders.. including an expensive high speed one for the Shorai.. I can tell you with 100% certainty that not one is plugged in as I type this I need to work on that.
Old 01-08-2013, 04:39 PM   #172
Drewha
Thunderbirds Are Go
Drewha's Avatar
Oddometer: 595
08 Husqvarna TE 610
04 Ducati ST3
Old 01-08-2013, 08:04 PM   #173
Turtledub
Turtledub's Avatar
Oddometer: 319
I've got two from Harbor Freight for about $9. The one in the garage put the voltage up to 14.7 with out turning off so I just charge each bike once a week (if I don't ride it) for 3 or 4 hours. Seems to be all they need.
Turtledub is offline   Reply With Quote
Old 01-09-2013, 05:36 AM   #174
Stan Dalone
Gotta get somma dat
Stan Dalone's Avatar
Oddometer: 1,311
Attention to detail?
My ride report from 8 months and 18000 miles on an old C-10
(soon to be updated)
Wish I was a headlight.
The Blog from our adventure ride
Stan Dalone is offline   Reply With Quote
Old 01-09-2013, 04:16 PM   #175
stromper
Oddometer: 358
Lithiums just set the Dreamliner on fire
Where's Minnesota Upper Yuasa
I also sprung for a Yuasa Battery Keeper as a cheapy Walmart Schlumber cooked
2 of my batteries
stromper is offline   Reply With Quote
Old 01-09-2013, 05:07 PM   #176
MATPOC
MATPOC's Avatar
Oddometer: 1,032
I rarely have issues with batteries, this one however is not my bike... so I ordered an AGM, cheap and should get the job done
still need to get carb sorted out, it leaks gas, even on the bench when I hook it up to remote tank, opened it 3 times now but float, needle and seat appear to be fine.... one suspect is the rubber o-ring on the needle set is to blame, looks dried up, can't find anything else,...
MATPOC is offline   Reply With Quote
Old 01-09-2013, 05:21 PM   #177
alcontrast OP
at least I'm trying
alcontrast's Avatar
Oddometer: 1,599
I call bullshit!! Your hands are too clean to have been working on a bike!
I have no idea what the inside of your float bowl looks like but I had this problem on my 72 cb350 that took me a while to find. The brass tube is the overflow drain tube; just below the domed top there is a small hole for fuel to drain out if the level gets too high.. The long crack in the side of the tube is not supposed to be there but with my not so great eyesight I couldn't even see the crack; that tube is thinner than it looks in the photo. Fuel would constantly drip out the drain tube until the bowl was almost empty..
When in doubt, gas it. It will either fix the problem, or at the very least end the suspense.
07 650GS / 05 DRZ400S / 72 CB350 (that hasn't run since shortly after I bought it)
alcontrast screwed with this post 01-09-2013 at 05:32 PM
alcontrast is offline   Reply With Quote
Old 01-09-2013, 05:24 PM   #178
MATPOC
MATPOC's Avatar
Oddometer: 1,032
got one word for you GLOVES!
Old 01-09-2013, 05:27 PM   #179
DariusFriedel
Slicker than an M59
DariusFriedel's Avatar
Oddometer: 1,752
My carb leaks gas into the engine, especially when I twist the throttle. Still trying to figure out why.
Darius
'12 KTM 250 XC
If it wasn't for all the rocks, roots, trees, hills, mud, ruts, logs, sand, and lack of tar, I'd be a damn good off-road rider!
Darius on Dirt
DariusFriedel is offline   Reply With Quote
Old 01-09-2013, 06:43 PM   #180
cheesebot
I cheesebot
cheesebot's Avatar
Oddometer: 399
I have these damn cracks on almost every CB350 float bowl overflow tube I have (six at last count)
cheesebot is online now   Reply With Quote
Times are GMT -7.   It's 06:30 AM.
