Old 11-28-2012, 09:49 PM   #1
xjon OP
Pedantic Bastard
xjon's Avatar
Oddometer: 381
Send a message via Yahoo to xjon
New leak...final drive
Just realized after a ride to the store a quarter sized oil spill. Sure enough it's from the final drive. Did the wheel shake test and it seems solid. Took wheel off and checked where its leaking from and both sides were dry. The boot however was wet. Looked up the swing arm and the shaft was dry, so it's not the tranny seal.
So I'm thinking its just the front seal of the final drive. Never taken a final drive apart before so I'm not sure what to expect so any suggestions, tips, would be appreciated.
Asked the dealer over the phone and they said $375 and parts...Thinking of tackling the job myself so the kids can have a merrier Christmas.
06 with 50k miles
06 1200GS (since day 1)
13 CRF250L (3/2013)
xjon is offline   Reply With Quote
Old 11-28-2012, 11:44 PM   #2
aGremlin
aGremlin's Avatar
Oddometer: 395
Usually it's just the final drive seal, should be a simple quick job. I've had mine replaced a few times (the latest a couple of weekends ago failed immediately and I had to return to the shop for another).
Got a pic?
Warning: My post quality varies according to my mood. If I sound sane give it a few minutes and I'll be back to normal
aGremlin is offline   Reply With Quote
Old 11-29-2012, 03:18 AM   #3
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,377
Hopefully that labor cost includes them removing and replacing the FD from your bike, should be much less if you carry just the FD in to them.
Sorry I can't be of any help as I've never had to replace that input seal, but unless lots of special tools are required I'd think it should be a fairly easy do-it-yourself job. Good luck.
'07 R1200GS Adv. & '00 DRZ400S
Step-by-Step R1200GSA Gearbox Removal and Clutch Spline Lube Process
Another 100,000 Mile R1200GS Adv.
R.I.P., my faithful dog Ripley (ref. my avatar). April 2001 - April 2013
jdub is offline   Reply With Quote
Old 11-29-2012, 04:33 AM   #4
Disco Dean
Disco Dean's Avatar
Oddometer: 1,135
That price seems fair to me. And, normally the shop will require they take the whole bike in for warranty - don't ask me why but you can always ask.
IF it is the side seal (which you hint it is not) it is very easy to do and can be done without removing anything but the plastic cover. Jim VB has a tutorial on it I think.
IF it is the pinion seal from inside the boot you will need specialized tools to do it - a machined socket to remove the collar on the pinion, air tools, heat and proper pullers - most likely going to have to fabricate some work-holding tools.
I have done it twice now - it gets easier but is not a simple job at all and you will spend more time machining the proper tools (it took me two days to machine the socket) and or buying them from BMW than the 375 is worth in my opinion.
It is a big job - really and if you are going to do that then you might as well replace the small pinion bearing or all of them at the same time as that bearing is the one that fails - then you are doing the shims and, and, and.... back lash and contact pattern/patch...
I have an 06, 120GS with 100,000 on it.
D
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 11-29-2012, 07:07 AM   #5
WoodButcher
WoodButcher's Avatar
Oddometer: 1,644
Send a message via AIM to WoodButcher
Sure it isn't the shock leaking and running back to the rear boot?
I'd check that just to make sure.
Rusty
2009 BMW R1200GS Adventure
1999 DR650
2007 DR200
WoodButcher is offline   Reply With Quote
Old 11-29-2012, 08:49 AM   #6
roadtrip22
roadtrip22's Avatar
Oddometer: 307
I just had that replaced on my old 06 R1200GS. I didn't have the tools to do it nor did the dealer. Plus the dealer didn't even want to touch it. Found a Independant BMW bike shop and had them replace it for around $250 including parts. but I took the FD off myself and brought it to him.
I replaced numbers 2,3,5 and 6 in the diagram. When I looked at the old parts. looked like the crush washer got a little dirt on it and killed it making it leak. and get past the seal where the dirt came in..
http://www.realoem.com/bmw/showparts...26&hg=33&fg=10
But if you don't know what your doing. I'm told i wouldn't mess with it and let someone else who does know deal with it..
roadtrip22 is offline   Reply With Quote
Old 11-29-2012, 08:57 AM   #7
xjon OP
Pedantic Bastard
xjon's Avatar
Oddometer: 381
Check out this video on YouTube:
http://youtu.be/QGLrZPjGGmY
Shock is dry.
13 CRF250L (3/2013)
Old 11-29-2012, 09:10 AM   #8
def
I have little to say
def's Avatar
Oddometer: 6,300
Send a message via Skype™ to def
If he will do it, send it to Anton for a thorough repair. I know of nobody who is as detail oriented.
def is offline   Reply With Quote
Old 11-29-2012, 10:26 AM   #9
xjon OP
Pedantic Bastard
xjon's Avatar
Oddometer: 381
And who is this Anton you speak of, and how do I get a hold of him?
13 CRF250L (3/2013)
Old 11-29-2012, 10:32 AM   #10
def
def's Avatar
Oddometer: 6,300
Anton frequents this site from time to time. He is considered by many herein as a BMW driveline expert.
http://www.largiader.com/
Old 11-29-2012, 01:36 PM   #11
Disco Dean
Disco Dean's Avatar
Oddometer: 1,135
+1 Def... Anton helped me the first time around - very good and cost effective.
Dean
youmoveyou
Old 11-29-2012, 03:34 PM   #12
WoodButcher
Oddometer: 1,644
Shock is dry.
Which is good news. Shock can be more than the FD seal fix.
Rusty
1999 DR650
2007 DR200
Times are GMT -7.   It's 03:44 PM.
