Old 11-12-2012, 04:29 PM   #1
webjester OP
Oddometer: 44
Tire Repair???
Long story short, my rear Metzeler has a tiny hole right in the middle of the tread. The air holds for a day or two. Brought it to the dealer who said they won't touch it because of liability and wanted to sell me a new one. Now what? So I thought I'll see what you guys have to say.
The tire has about 6k miles on it. I found the hole submerging the wheel but couldn't see anything stuck in there. Tiny bubbles.
option1: Bite the bullet and buy a new one, considering that it has maybe a third of its life left. $200 for a new one divided by 3 is about 66 bucks. If any tire place charges that amount for repair I'll already break even.
option2: Use some spray repair goo to fill the tire and hopefully clog up that tiny hole.
option3: Master Tire Repair kit. Seems to be an awfully big hole to create and then fix it
What do you guys think?
webjester is offline   Reply With Quote
Old 11-12-2012, 05:00 PM   #2
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,936
Use a string plug and your good to go.
bemiiten is offline   Reply With Quote
Old 11-12-2012, 05:12 PM   #3
W-Gator
W-Gator's Avatar
Oddometer: 31
Risked choices
1) Replace the tire. You know, safety on 2 wheels and all that stuff. You got 2/3 expected life out of the tire. That's pretty good.
2) Repair it with a mushroom plug installed from the inside.
3) Tire sealant. Be selective as some cause corrosion to your rims and leave a real mess at tire change time. Ride-on is reputed to be a good product. http://www.ride-on.com/motorcycle-formula-mot.html
W-Gator is offline   Reply With Quote
Old 11-12-2012, 05:23 PM   #4
mikegc
mikegc's Avatar
Oddometer: 1,622
Tire Repair???
I know guys that would plug it and ride until the cords are showing. I'm just the opposite. I don't mess around when it comes to tires. If they look "iffy," they are. As I only get about 6500 to 7500 out of I tire, I wouldn't even think about it.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 11-12-2012, 05:36 PM   #5
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 978
My favorite is this,
http://www.stopngo.com/categories/Tire-Pluggers/
Others prefer the ropes. I carry both, but will only use the rope as the second resort. I have used plugged tires for the duration of their tread a couple of times. I'm always leery initially and I monitor the tire until I am satisfied the repair is OK. It does help that I have TPMS on my bike.
OTOH, your tire is nearly worn out or at least no less than 2/3 whipped. I think you should just replace it.
Boy, I sure wish that I could get 6K out of a rear tire.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 11-12-2012, 07:06 PM   #6
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
Yep
JimVonBaden has a Plugging tutorial on his web site. It is easy, inexpensive and works well
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat is offline   Reply With Quote
Old 11-12-2012, 07:32 PM   #7
fastgpfred
Oddometer: 42
What's the current tread depth? If you don't have a tread depth gage they are cheep & available from most auto parts stores. I like this plug... http://www.dynaplug.com/ ... the best for small holes. You should have a kit for road emergencies anyway. I'd probably plug it but order a new one a little early. (the math on what you save)
fastgpfred is offline   Reply With Quote
Old 11-12-2012, 08:02 PM   #8
shu
Oddometer: 999
My opionion: Plug it with a sticky string and ride on it. The tire will not push the rope out (ever try to push a string?) There is no catastrophic failure mode here. The worst possible scenario is that the rope would let a little air seep- in other words, you'd be back where you are now.
I've ridden many miles with rope plugged tires, and I can watch their 'health' with my tire pressure monitors. They haven't leaked at all- not a bit. This has given me a lot of confidence in these repairs. When you finally take the tire off you'll find the string has permanently bonded in a mound to the inside of the tire.
I can't say the same for plugs, although lots of people like them. I have seen those fail several times.
.............shu
shu is offline   Reply With Quote
Old 11-12-2012, 08:19 PM   #9
LaurelPerryOnLand
Oddometer: 3,478
Can you afford $66 for peace of mind?***
Otherwise...proceed with other options.
***Let's think this through to it's illogical conclusion:
1. Tire fails.
****YOU LOSE FROM THIS POINT FORWARD****************************
2. Bike sustains damage during accident.
3. Bike is repaired by your insurance...minus your ($500?) deductible?
4. You sustain some damage (injury) during this accident.
5. Ambulance, hospital charges exceed $45,000 for your 1 week recuperation.
6. Your boss fired you since you were really needed at work.
7. You injure somebody else and they end up suing you for their personal injury and damage to their car.
8. You're convicted of careless operation of a motor vehicle and serve 60 days in jail.
9. Your boss REALLY doesn't want to know about you...particularly now.
10. Since you have no income for 2 months...you miss a couple mortgage payments...bank forecloses on your home.
11. All your credit cards increase your rate since you defaulted on your mortgage payments.
12. Your FICO score drops to the low 500's.
13. It takes you 4 more months (I'm being generous)...in this BAD economy...to find another job comparable to what you had.
14. You exhaust your 2 months of 'savings' and are forced to BORROW from your wife's family...you didn't have the nerve to tell YOUR family.
I think you can see where this COULD be headed...worst case scenario.
Back to my original question:
HOPE SO...otherwise park it until you have the $66.
PS..."No" I don't sell insurance...nor TIRES.
LaurelPerryOnLand screwed with this post 11-12-2012 at 08:42 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 11-12-2012, 08:25 PM   #10
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,629
Mushroom plugs suck. Use a sticky string and it will last longer than the tire will. Some lawyer types will tell you how this is so wrong and all that. It's your prerogative.
Not to be wishy washy but now that I reflect further, if the tire has 6000 miles on it it's probably about shot anyway, so I would maybe lean more toward getting a new one unless you are in the middle of a trip or something.
AviatorTroy is offline   Reply With Quote
Old 11-12-2012, 08:27 PM   #11
AviatorTroy
Oddometer: 1,629
1. Tire fails.
And dude, if you are really so afraid of life should you even be riding a motorcycle in the first place?..
Old 11-12-2012, 09:17 PM   #12
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,256
Originally Posted by Mudcat View Post
Yep
http://www.jimvonbaden.com/Tire_Plugging.html
String plug and ride! So long as it is in the tread, and not a rip, it will work just fine.
On the other hand, if you are the worrying type, just replace it. You will never be happy if you do not.
Jim
Old 11-12-2012, 09:47 PM   #13
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 978
[QUOTE=AviatorTroy;20031339]Mushroom plugs suck. [QUOTE]
Uh, no. They are a more elegant repair than the rope and don't leak when used correctly. I've run a shop where we installed ropes routinely. Ropes will leak because they don't conform to the hole very well because they are stiff, comparitively. They don't seal the bore of the hole every time either. Water can get between the plies as it leaks into the hole from the tread.
The mushroom types are softer and will conform to the hole more successfully. Mushrooms, however, won't work in less regularly shaped hole bores as well as ropes. That's the reason I carry ropes, too.
BTW! I don't think anyone would call you wishy washy.
Old 11-12-2012, 10:27 PM   #14
aGremlin
aGremlin's Avatar
Oddometer: 517
Depends on the life left...
Not much, stuff it, replace the tyre.
Worth it? Mushroom plug (properly installed, my dealer did it) tyre comes off, sealed up etc, had no problems for the rest of the tyres life.
Warning: My post quality varies according to my mood. If I sound sane give it a few minutes and I'll be back to normal
aGremlin is offline   Reply With Quote
Old 11-12-2012, 11:48 PM   #15
KSKLR
Oddometer: 22
I have had no problems with the rope plugs in more than ten thousand miles and would not hesitate to use one again if the hole size is appropriate. The last one that I had on my GSA was in Alexandria, LA when I was on a trip and finished up with over 2,000 miles on that trip alone plus several thousand more before changing that tire.
Went to James Bay Quebec with some FJR 1300 Yamaha guys and one of them had three plugs in his rear tire. He went several hundred miles at well over 100 mph with no problems.
Do start off easy and monitor the pressure. I have taken off tires with rope plugs that I installed and the rope from the inside appears to be fused and is not going to come out.
All things being equal I would rather start off on a trip with a fresh set of tires but these are what my experiences have been and for me I have no qualms.
KSKLR is offline   Reply With Quote
Times are GMT -7.   It's 10:06 AM.
