Old 11-29-2012, 07:13 AM   #1
Aventeren OP
Oddometer: 181
In Leon, Nicaragua with slightly bent rims from Honduras roads; need advice
Howdy--
I just arrived in Leon, Nicaragua last night after leaving El Salvador yesterday morning and transiting through Honduras. I know that I'm going to take shit for this, but I was waving to a small boy in the back of a truck before I passed him when while I was waving I drove through a crater that gave me a pretty good rattle. When I got to the border, I noticed that my front rim has a little tweak--and the back rim does as well. (See photos).
I have a 2002 1150 GSA, and my question is given the minimum damage and the fact that they appear to ride fine, what should I do? Should I try and find someone to tune the spokes, head to the BMW dealer, just let 'em be or what. Clearly safety is #1, but I'm not a perfectionist, and if there is a do-nothing alternative, my preference would be that.
Thanks everyone!
What a flippin' trip.
Aventeren is offline   Reply With Quote
Old 11-29-2012, 08:18 AM   #2
Aventeren OP
Oddometer: 181
Alright, so I just read this: http://advrider.com/forums/showthread.php?t=839732. Clearly this is more science than art--and I am highly skeptical that I will be able to find anyone in Latin America to properly tune my spokes. I think I'm just going to keep and eye on this and take the do-nothing alternative. If things really start to wobble of vibrate, I'll figure something out...but at the current time, the ride last night into Leon didn't seem too bad.
Old 11-29-2012, 08:53 AM   #3
MJS
MJS's Avatar
Oddometer: 1,905
If the spoke is loose you can tighten them. You need to remove the grub screw in the center of the nipple then tighten the spoke and replace grub screw. The spokes should all sound the same. If in doubt, just tighten the loose one with enough mild tension so it doesn't rattle. Then continue to ride on.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 11-29-2012, 09:03 AM   #4
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,359
You are correct that you will likely not find anyone skilled in fixing your wheel in So. America, or anywhere else for that matter....once you are safely home, contact Woody here
http://www.woodyswheelworks.com/BMWR...00_1150GS.html
He's the only one I would trust with your BMW cross-laced spoke wheels.
def is offline   Reply With Quote
Old 11-29-2012, 11:34 AM   #5
QCRider
Oddometer: 94
Not sure if the CR dealership would be able to help in this case, but feel free to contact them to find out:
BMW Bavarian - Service: Adolfo +506-2290-9235 x111 (he speaks English).
How long are you in CR for?
QCRider is offline   Reply With Quote
Old 11-29-2012, 12:10 PM   #6
Dan-M
Dan-M's Avatar
Oddometer: 1,027
If the tire is not leaking from the bead and you are not experiencing any wobble, I would leave it alone. It does not look too bad.
Tightening random spokes will likely make matters worse.
Dan-M is offline   Reply With Quote
Old 11-29-2012, 02:47 PM   #7
LaurelPerryOnLand
Oddometer: 3,481
Steps for recuperation
1. Ship your wheels to Woody.
2. Find a nice cantina...serves cerveza.
2a. Repeat step 2 until beer cooler is empty.
3. Wait 2 weeks until Woody returns wheels.
4. Continue on trip.
5. Forget this ever happened.
LaurelPerryOnLand is offline   Reply With Quote
Old 11-29-2012, 02:51 PM   #8
def
def's Avatar
Oddometer: 10,359
speaking of wheels
I would not recommend parking behind the car shown in your third photo...note the wheel chock....the guy likely has no brakes....stay clear!
Old 11-30-2012, 03:08 AM   #9
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
+1 !! The spokes in the vicinity of the ding will not be bearing the correct load now. You should at least tighten them to ring true as MJS says, so they can carry their share of the load. Then ride on and forget the little boys
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 11-30-2012, 03:38 AM   #10
aGremlin
aGremlin's Avatar
Oddometer: 517
Check to see if there are any spokes that are tightened differently to those around them, otherwise, as said, if the tyres are holding air, keep going until you can find someone with the correct skills.
Try to avoid pot holes in the future aye?
Warning: My post quality varies according to my mood. If I sound sane give it a few minutes and I'll be back to normal
aGremlin is offline   Reply With Quote
Old 11-30-2012, 09:53 AM   #11
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,962
I wouldn't sweat it.
If there are no loose spokes chances are they are bent too!
They are pretty heavy spokes.
Maybe a wobble will show at higher speeds.
Ride accordingly.
I've ridden through Baja with a VERY dented rim without dire consequences.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 11-30-2012, 11:08 AM   #12
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,286
Those dings are not bad at all. The spokes in the area of the dings could be be slightly lose. Check to make sure the spokes are all at approximately the same tension in the area of the dings and you are good to go.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 11-30-2012, 12:41 PM   #13
jachard
Oddometer: 603
Beer in Nica is terrible....Keep going to Patagonia where the beer is much better, then deal with the wheel issue:)
Kidding aside, I wouldn't sweat those dents too much, just leave it alone but keep an eye on them.
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
http://octaneworks.wordpress.com/
jachard is offline   Reply With Quote
Old 11-30-2012, 01:18 PM   #14
yellowbirdrs
yellowbirdrs's Avatar
Oddometer: 966
Here in Mexico we have at least 3 shops where they can be fixed. I'm sure you can find someone down there LA roads make this an every day problem and the demand to fix it encourage the shops to deal with. Also here in LA the garage workers are often a craft-masters because they can afford the expensive machinery like in the far North America. Give it a try with a local shop.
yellowbirdrs is offline   Reply With Quote
Times are GMT -7.   It's 04:07 AM.
