Old 11-29-2012, 03:26 PM   #1
Girthy Knobkers OP
Girthy Knobkers's Avatar
Oddometer: 540
What's missing?? 800GS Fuel Pump
I am of course speaking of this empty threaded hole on top of the pump here. My 800 is skipping when fuel gets around 1/3 of a tank. Pulled the pump to find that empty threaded hole...????
Girthy Knobkers is offline   Reply With Quote
Old 11-29-2012, 05:49 PM   #2
Girthy Knobkers OP
Oddometer: 540
I have also dug around the tank trying to find the culprit but no luck... I know that suggestion will come up
Old 11-30-2012, 06:05 AM   #3
JRWooden
Oddometer: 4,256
Hmmmmmmmmmmmmm
Sorry I have some pictures of the fuel pump assby. scavenged from other threads, but none show close-up of that area... I don't what it is...
Old 11-30-2012, 09:01 AM   #4
Girthy Knobkers OP
Oddometer: 540
From what I gather it is some sort of spring/valve contraption. I tried to scavenge a similar part off an old RT pump but they are two dif pieces. The only way to get that is to order a whole new pump!
Old 11-30-2012, 10:23 AM   #5
njoytheride
NJOYN' THE JOURNEY
Oddometer: 942
I purchased the after market pump off of Ebay. I will look tonight and see if it has something located in that area. I took pictures of the OEM pump assembly when I was checking the filer but no pictures showed the top of the pump.
njoytheride is offline   Reply With Quote
Old 11-30-2012, 10:29 AM   #6
Girthy Knobkers OP
Oddometer: 540
Thanks, I understand that BMW is really good at manufacturing a part that works on many bikes and that hole might be something that on another bike has something in it but the 800 never did. Knowing would help eliminate the reasons for this skipping at 1/3 of a tank or lower...
Old 11-30-2012, 10:53 AM   #7
docsherlock
docsherlock's Avatar
Oddometer: 465
Your pump is probably overheating as the fuel level drops; the fuel is also used for cooling the pump. Many references to this symptom and cause on the forums.
If there was nothing in the tank, I doubt your pump is missing anything.
docsherlock is offline   Reply With Quote
Old 11-30-2012, 10:58 AM   #8
Girthy Knobkers OP
Oddometer: 540
So replacing the pump is the only option? what is causing it to over heat?
Old 11-30-2012, 10:58 AM   #9
ebrabaek
Oddometer: 4,745
How did your fuel filter look....????? I live in the desert, with over 100 deg. on a regular basis, No issues after 12000 miles with running the tank down. It would make sense to me that if your filter had a partial blockage, then as fuel level dropped to 1/3 pump has to siphon too much, and fuel starvation occurs....imho.
Erling
Old 11-30-2012, 10:59 AM   #10
Girthy Knobkers OP
Oddometer: 540
I back flushed it and a lot of gray gas came out, now I am beginning to flush it forward and the gas looks even worse... going to keep flushing...
Old 11-30-2012, 11:11 AM   #11
JRWooden
Oddometer: 4,256
GK:
While you have that filter on the bench would you mind capturing the dimensions of it?
Diameter & height, and length and diameter of nipples?
The local NAPA parts store manager is a buddy of mine maybe he can reverse engineer something that would work...
Its a frigg'n FI-rated fuel filter damn pity that BMW won't sell us one separately..........
Old 11-30-2012, 11:26 AM   #12
Girthy Knobkers OP
Oddometer: 540
Old 11-30-2012, 02:02 PM   #13
JRWooden
Oddometer: 4,256
Old 11-30-2012, 02:28 PM   #14
Girthy Knobkers OP
Oddometer: 540
let me know, I got a look at an oem replacement and it seems nothing goes in that hole that I was curious about. The pump over heating makes sense as well as the fuel filter being dirty. If there is a filter that can be wedged in there that would be sweet
Old 11-30-2012, 06:39 PM   #15
JRWooden
Oddometer: 4,256
Will do, I'm not real optimistic, but we could get lucky....
That would be nice............
Times are GMT -7.   It's 06:10 PM.
