Old 12-01-2012, 09:27 AM   #16
docsherlock
docsherlock's Avatar
Oddometer: 465
Originally Posted by Girthy Knobkers View Post
let me know, I got a look at an oem replacement and it seems nothing goes in that hole that I was curious about. The pump over heating makes sense as well as the fuel filter being dirty. If there is a filter that can be wedged in there that would be sweet
I think what happens is that the fuel filter gets blocked so the pump has to work harder to pressurize the fuel and is then prone to overheating - drive any electric motor too hard and it will overheat.
So I agree that replacing the pump and filter assembly will probably fix the problem but if you can get a separate new filter that is likely the root cause.
docsherlock is offline   Reply With Quote
Old 12-01-2012, 02:13 PM   #17
C5!
Oddometer: 275
You can just replace the filter by an external one like here http://www.advrider.com/forums/showthread.php?t=834239
I also did that and it worked for me...
C5! is offline   Reply With Quote
Old 12-01-2012, 08:38 PM   #18
njoytheride
NJOYN' THE JOURNEY
Oddometer: 942
The Highflow after market pump has a hole in the same location and it looks like that is fitted in from the back side. Maybe a pressure relief valve ? Not sure. It appears to be ported. hmmm??
njoytheride is offline   Reply With Quote
Old 12-01-2012, 10:26 PM   #19
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,371
You got to have a blow off for excessive pressure back to tank. So that makes sense.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 12-03-2012, 09:53 AM   #20
Girthy Knobkers OP
Girthy Knobkers's Avatar
Oddometer: 540
I have decided to go with the external filter route. Does anyone have a part number for a filter that is 10 micron rated I can pick up at a local auto parts store?
Girthy Knobkers is offline   Reply With Quote
Old 12-03-2012, 03:13 PM   #21
Girthy Knobkers OP
Oddometer: 540
Welp, this is what I came up with for now. Extra filter I had laying around for my old 1100. Will test this week sometime and let ya'll know how goes it.
Times are GMT -7.   It's 09:30 AM.
