Old 06-09-2014, 10:42 PM   #1
bananaman OP
transcontimental
Oddometer: 7,296
R1150GS Final Drive Ratio Change
Today I rode a 2000 1150GS. I liked it but 1st gear was too tall. How easy is it to change to a rear end with more grunt?
I am Charlie.
bananaman is offline   Reply With Quote
Old 06-09-2014, 11:09 PM   #2
Zoul
No Comment
Zoul's Avatar
Oddometer: 1,045
I had an 01 R1150GS and I felt the same way. I remedied that by installing a final drive from an R850R.
You shift a bit more and you lose some top end, but I liked it.
Zoul is offline   Reply With Quote
Old 06-10-2014, 12:42 AM   #3
Parrothead
Cu Dubh
Parrothead's Avatar
Oddometer: 461
R850r
I actually shift less, much less, especially on the mountain roads. I do miss the overdrive nature in 6th but have gladly traded it for the roll on power ability in 6th. 1st is great, especially off road and/or two up. Gas mileage kinda sucks but worth it to me.
Parrothead is offline   Reply With Quote
Old 06-10-2014, 03:29 AM   #4
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,636
Very easy if you can find a final drive from an 1100GS in good condition.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 06-10-2014, 04:28 AM   #5
Major Kong
Oddometer: 59
That was precisely the reason that I bought a used 1100GS and not a new 1150GS.
Major Kong is offline   Reply With Quote
Old 06-10-2014, 06:47 AM   #6
bananaman OP
transcontimental
Oddometer: 7,296
So I could swap in the final drive from my wrecked 1100GS...
Thanks.
I am Charlie.
Old 06-10-2014, 09:45 AM   #7
liviob
liviob's Avatar
Oddometer: 702
Yes it will bolt right on. Make sure is at least a 33/11 ratio. You can find the ratio stamped on the housing next to the vent. I have a 33/11 on my 01 1150 GS. First gear is much more useful but still a little tall and over drive still feels like overdrive. I have two other FD's that I plan to try out a 34/11 and a 32/10. Considering these are dual sport adventure bikes I don't understand BMW's design logic with regards to many aspects of the bikes usefulness. I feel they failed in many design areas.
Current road bike 2001 BMW R1150GS
liviob is offline   Reply With Quote
Old 06-10-2014, 11:07 AM   #8
Mr.JAJA
Mr.JAJA's Avatar
Oddometer: 406
33/11
I just got a 33/11 (3:1)for my 1150 Adv. with low 1st gear and I will install it later this year. Original is 2.8:1. on the 2004 1150 Adv, it will make it easier to ride off road and loaded.
Mr.JAJA
Mr.JAJA is offline   Reply With Quote
Old 06-10-2014, 11:55 AM   #9
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,567
I've never ever noticed the difference between the two gearboxes available. And i've ridden both off road and on road. And seeing as the off road riding is such a small percentage of my riding i prefer the higher top geared box.
With a 32 litre tank fitted It saves me 6 for the same mileage compared to the lower top gear box on every fill up.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 06-10-2014, 01:36 PM   #10
liviob
liviob's Avatar
Oddometer: 702
I don't think the 33/11 ratio will cause a loss of fuel economy. At 70mph my engine rpm is 3450. Last road trip I did I got 44mpg. Seems like that is about what most people are reporting for the 1150GS.
Old 10-05-2014, 08:14 AM   #11
lasvegasrider
Scotty, I need more power
lasvegasrider's Avatar
Oddometer: 2,091
Question 34/11 3.09 gearset in hand ` move into gs abs housing
02 1150gs was swell w/ my 96's 1100gs final drive 33/11 but just a bit more wanted so I scored a rare 1994 34/11 1100rs final.
the gearset rests in a non abs housing, so need to migrate pinion and crown to a spare abs mud flap bossed gs housing.. probably a job for bruno ...
or how hard is it to position the pinion/crown gear interface.... can't find much on it...
2up on our 1150GS beats RVing anyday.
lasvegasrider is offline   Reply With Quote
Old 10-05-2014, 01:40 PM   #12
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
I have a 33/11 as well, Probably the best compromise, I reckon.
Not only is 1st lower for dirt road and nose picken' through the green lanes but it's a lot easier to take off two up and loaded, especially on a hill.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 10-05-2014, 02:17 PM   #13
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,416
Very easy to do yourself, you just need a FD with higher numerical ratio. Donors can be found here and there... look or post in Flea Market, or try the dealers.
My own 2000 GS has a taller FD, and it made a big difference, especially grunting up steep freeway on-ramps in congested traffic.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 10-05-2014, 03:24 PM   #14
Ken Fritz
Oddometer: 1,017
Thumb Best ratio 3:1
I changed my stock 2.82:1 for a 3:1 about 40,000 miles ago and won't go back. Yes, fuel economy is down a bit and it's not quite as fast on the top end, but the acceleration is greater and the 6th gear is actually more friendly now - less downshifting when pulling a big hill and better cruising at anything less than 75mph. I ride two up and loaded most of the time and the extra grunt off the line and slower idle speed is superior to the stock ratio. With a corrected speedometer (swap out the front wheel speedo drive for one from an R1150RT) that now reads exactly what speed I'm travelling, I can see that I can actually use 6th gear at 55mph.
MPG dropped from 46-48 to 40-42, but it's worth the flexibility; accelerate from 2600 rpm in gears 1-5 easily.
I kept the stock FD as a spare, but haven't need it. The change was probably the best thing I did on this bike and it's well farkled.
Ken Fritz is online now   Reply With Quote
Old 10-06-2014, 02:40 AM   #15
stefan1150
Oddometer: 40
I am also happy with the 33:11 gear ratio for my 1150 gs. It takes off much easier and if you don't use it predominantly on highways i don't see how it can lower the gas mileage. It's not a big difference but you can definitely notice it.
I wouldn't be very confident in swapping gears from one fd to another. Apart from the shim of the crown bearing which should be recalculated anyway when changing the bearing, you have to re-shim the small gear that drives the crown so that they align perfectly.
stefan1150 is offline   Reply With Quote
Times are GMT -7.   It's 11:56 PM.
