Old 11-29-2012, 10:55 PM   #1
SCflyer OP
SCflyer's Avatar
Oddometer: 1,632
Skid plates and water in electrics
Working on setting up my 12 990R and have a question on potential elecrical problems and skid plate design. New to the 990s so excuse me if it's been covered.
Though I haven't read anything yet as to it being an issue...are there potential problems (and if so what are the solutions) to the wiring n such down front and to the rt side of the battery being more exposed with the aftermarket plates? I just put a BDCW plate on and while I'm sure it'll take a beating, leaves the wiring exposed vs the stocker.
Is this an issue or is the stock wiring "hardened"/insulated enough to be fine? Add dielectric grease?
Anyone drilled drain holes in the plates to help reduce water pooling in the plate?
Any problem of drilling a hole to access the oil drain? Not too big a deal to drop the front, but if I don't have to...
Thanks all
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 11-30-2012, 02:26 AM   #2
BykBoy
Meshuganeh
BykBoy's Avatar
Oddometer: 557
I was thinking of drilling a hole for the oil plug on my Black Dog skid plat too.
Looks like this guy drilled a hole in his stock plate:
Also, this plate comes with the hole already drilled.
Save $5 when you open a SmugMug account. Use the following coupon: 4l1hicJzWvYNE
BykBoy is offline   Reply With Quote
Old 11-30-2012, 03:35 AM   #3
Sacal
Sacal's Avatar
Oddometer: 132
I used the stock plate for the first 6 or 8 months through the first winter of ownership, I have a feeling this wast part of the cause of the starter relay, wiring and connectors furring up and rotting because of condensation build up. I live in England and its always damp and wet, I'm no scientist but after having the loom replaced I got to thinking that the stock plate keeps condensation inside more than an open plate that allows air to circulate after the engine is switched off and the damp to evaporate. I use a GIT bash plate now an just to be on the safe side I also now use ACF50 all year round and all the connectors look almost as good as new, a lot easier to apply that dielectric grease and no where near as messy, it's great stuff to use on the whole bike as it also neutralizes salt and corrosion. I don't often recommend products, but i'll put my name by this one as something worth buying for sure!
http://www.acf-50.co.uk/motorcycle.htm
ad astra per alia porci
Sacal is offline   Reply With Quote
Old 11-30-2012, 04:23 AM   #4
R&R4adv
R&R4adv's Avatar
Oddometer: 339
Adding a hole in the bottom of a bash plate is a joke, if you drain the oil you would replace the oil filter so the plate has to come off, as long as the plate has a open back so the the water can't pool the first crack of the throttle would see any water run out. I have made many bash plates and alway left the bottoms of them solid so nothing can get forced up through the hole into the motor but have aways made the sides with holes in them to allow the air to get in and around the motor for extra cooling and to dry them out quicker.
R&R4adv aka Reon
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure 99 XR400
R&R4adv is online now   Reply With Quote
Old 11-30-2012, 04:30 AM   #5
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,971
Who uses the OIL drain hole in skid plates???
If you are draining oil you "should" be changing the paper and cleaning side sump filter also.
Why not just pull the extra 2 bolts (4 total bolts = 3 minutes) required the Remove the skid plate and do a proper job.
Drain holes in skid plates always make me laugh.... Really, I'm suppose to fish the drain bolt out of this and oil should run out perfectly. Never does. Just makes a mess in the pan of the skid plate. Then that needs to be cleaned, or you start collecting dirt on the oil mess you created.
I have never heard of a service shop doing an oil change with the skid plate installed, just to much of a pain.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 11-30-2012, 07:26 AM   #6
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,831
You need to pull the plate to access the oil drain hose anyway
2012 wr250r
You don't know what you don't know
findLadukebob
Ladukebob is offline   Reply With Quote
Old 11-30-2012, 08:13 AM   #7
SCflyer OP
SCflyer's Avatar
Oddometer: 1,632
Okay, new bike so unfamiliar with the process at the moment but thanks for the info so far.
How about the wiring and keeping it good with the potential water access? Any other suggestions/tricks. I'm sure I'll learn more as I go and do but having some preventive info is always helpful.
Thanks all
Old 11-30-2012, 08:45 AM   #8
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,865
Oil Change How Too
http://advrider.com/forums/showthread.php?t=371723
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 11-30-2012, 11:04 PM   #9
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,317
Originally Posted by SCflyer View Post
How about the wiring and keeping it good with the potential water access? ...
I have the Weld86 plate with no extra holes drilled, nor have I made any changes to protect the wiring.
Although I am not much for water crossings, I do ride in the rain, and do hit the occasional puddle.
I have had no problems with water fouling the wiring.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 12-01-2012, 02:53 PM   #10
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
I've swiss cheesed the hell out of my weld 86.
I like the air flow over the R/R.
I've had no issues with the low mounted electrial
but I go through all the electrical connectors on the
bike and use Corrosion X , on everything.
Google it up.
Or use dielectric grease.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 12-02-2012, 01:07 PM   #11
stickysidedown
stickysidedown's Avatar
Oddometer: 661
I had all manner of problems from electrics that were submerged on the starter solenoid, its a design fault and not unique to the KTM (had to repair wiring on an xtz660 teneres reg/rec for the same reason)
I use a product called contralube a worthy preventative on all the electrical connectors as I work on the bike
www.contralube.com
I actually fitted spades into the solenoid and sealed with silicone before soldering the wires and sealing with a heatshrink that also epoxies the joint.
not had any problems since and now have a fair degree of trust in the bike
stickysidedown is offline   Reply With Quote
Times are GMT -7.   It's 08:37 PM.
