Old 11-29-2012, 11:47 PM   #1
horseman474 OP
Outback Albatross
horseman474's Avatar
Oddometer: 154
Large ADV bike handle bars
Hi all,
I'm looking for replacement handle bars for my Supertenere 1200.
I spend a lot of time off road and the stock bars are to road bikish for me.
I tried a set of Pro Taper contour fat bars off my CRF 450 but the control area of the bar is too short to bolt on clutch/ brake
before it goes down into the bar bend....
Any suggestions would be appreciated
Horseman.
horseman474 is offline   Reply With Quote
Old 11-29-2012, 11:55 PM   #2
Gryphon12
Gryphon12's Avatar
Oddometer: 1,345
Take a look at the bars WASP uses on his S-10. His build up is in his first thread, which was moved Vendors. I think that they were SW Motech, but I'm not sure. Very robust, anti-vibration, dirt-worthy configuration and lots of control space.
By the way, Pro Taper has various models of bars that vary in length of center and end sections. Their website is pretty good and has dimensions. Carmichael bend with risers might work.
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 12-02-2012, 06:55 PM   #3
rycomm
rycomm's Avatar
Oddometer: 343
I use Protaper 7/8" KX Hi on my 'Strom and DRZ. They were the widest and flatest of all of the ones I checeked. I have them mounted on risers, because they are pretty low compared to the stock bars. Many people use the ATV bars. They are a bit taller, and not too bad. I considered the ATV Mids, but am happy with the KXs.
Ryan
07 DL650, blue
07 DRZ400, also blue for sale
11 TU250X, not blue
09 WR250R, do these come in any color other than blue?
former rides:98 KLR650, 01 SV650 (another blue bike),89 KLR650, 92 Bandit 400
rycomm is offline   Reply With Quote
Old 12-03-2012, 08:24 PM   #4
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,838
Ryan
Same here. 7/8" KX Hi on my DRZ 1" risers and Contour KX Hi with 2" Rox pivoting risers on the Tenere. All the controls fit just fine on the Tenere. You will have to buy some inserts that go into the bars so you can mount up the bar end weights and hand guards.
Similar to this:
I had to get longer bolts to work with the inserts too. The stock bars have a threaded insert welded to the very end of the bar.
Anticyclone is offline   Reply With Quote
Old 12-04-2012, 04:51 AM   #5
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
I run CR Honda Hi bars and a 19mm Zeta riser on my WeeStrom which should be similar in terms of space needed. I actually prefer steel bars as a crash with a bike this heavy (and with tough bars) could easily snap the upper triple clamp or those long bolts on your bar risers. I would rather have the cheap bars bend first.
buls4evr is offline   Reply With Quote
Old 12-04-2012, 07:30 AM   #6
KMC1
There is no spoon.
Oddometer: 2,561
It's surprising how few good choices there are for the big bikes like the GS. You'd think with all the falling people do, replacing bars would be a yearly occurrence, and there would be a good aftermarket for them. I bought some protaper bars, but I don't like the bend, and they're a pita to put on, needing holes drilled in them, etc.
If I was in the business of bike parts, I would see this as an opportunity area.
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 12-04-2012, 07:46 AM   #7
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 489
Fasstco makes bars specifically for the S10:
http://www.fasstco.com/product-categ...exx-handlebars
Here is a link to some blah, blah about them:
http://www.yamahasupertenere.com/index.php?topic=5113.0
After you get the bars done all you have to worry about is working on everything below them!
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete screwed with this post 12-04-2012 at 07:53 AM
wfopete is offline   Reply With Quote
Times are GMT -7.   It's 09:49 AM.
