Old 11-30-2012, 07:54 PM   #1
SlowJoefromBako OP
Aint livin long like
Oddometer: 41
Bent front rim what to do??
Well it was bound to happen. Last weekend la-bastow-vegas day two I hit a boulder in the dust. So the rim is done. I read a couple of threads on adv about 1.85 DID dirt star from the super enduro would lace up to the stock spokes. So I orderd one, it got here today and third spoke is not pointing the right way. Is there something Im missing or did the internet lie to me? If this wont work whats my next best opption? I would like to run a 1.85 rim. 2011 990R Thanks
SlowJoefromBako is offline   Reply With Quote
Old 11-30-2012, 08:11 PM   #2
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 873
I think you need to un do it and flip the rim and start over. If that makes sense.
dogsslober is online now   Reply With Quote
Old 11-30-2012, 09:06 PM   #3
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,447
WWW in Denver
Give Woody's Wheel Works a call, great guys w/ their service & general help.
Wolfgang55 is offline   Reply With Quote
Old 11-30-2012, 11:06 PM   #4
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,630
+1 on Woody's
Go for the Super Lace three-cross lacing for extra strength. He might even give you some credit for the spokes you have already.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is online now   Reply With Quote
Old 12-01-2012, 12:35 AM   #5
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,099
Originally Posted by MotoTex View Post
+1 on Woody's
+3 on woodys
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 12-01-2012, 01:58 AM   #6
LukasM
Oddometer: 5,415
Woody builds super nice wheels but the Dirt Star rim on the stock hub with the stock oversize spokes is a great value.
If you ordered the KTM rim for the SE it should fit 100%, you just have to lace it up the same as the old one. Hard to tell what you are doing wrong but try to find some close up pics of a stock wheel and copy that.
Old 12-01-2012, 02:34 AM   #7
Idle
Oddometer: 719
Your rim might be drilled for a Japanese bike? Or reverse European? check old vs new rim and see if they match.
You may be able to get spokes made that will work. Or not, and you'll have to send the rim back.
Good luck!
Idle is offline   Reply With Quote
Old 12-01-2012, 08:23 AM   #8
whitewater18
funhog
whitewater18's Avatar
Oddometer: 471
+ 4 on Woody's Simply the best....
KTM 990A (gone)
KTM 1190 Adv R
whitewater18 is offline   Reply With Quote
Old 12-01-2012, 08:52 AM   #9
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Did you order the right rim? Sounds like you got a Jap indexed version. Flipping it over is bad advice, it'll only waste your time. Good on ya for taking the inititive to do it yourself, learning something useful and not joining the rest of these geespot wankers who can't wipe their own ass without calling in help.
Send it back, get the right one. Its specifically indexed for the KTM hub. Only place I know where to get it is from RAD or KTM. You're absolutely correct for doing it this way. No better rim and for the price it cannot be beat.
Sporting Wood is online now   Reply With Quote
Old 12-01-2012, 08:59 AM   #10
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,499
Laconic is offline   Reply With Quote
Old 12-01-2012, 09:00 AM   #11
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,527
Woody does nice work, however doing yourself has a certain amount of satisfaction and you'll learn something most are afraid of.. I was until I laced up my SE wheel on the ADV hub. since then Ive done two more..
The se wheel will work, double check everything, there are a few utube vids out there that helped me.. Good luck!!
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 12-01-2012, 09:05 AM   #12
Sporting Wood
Oddometer: 896
Old 12-01-2012, 06:09 PM   #13
SlowJoefromBako OP
Oddometer: 41
I tried to get a half decent pic.the top half the rim is perfect. the bottom crosses or off. The red string is the top spokes, lines up perfect. the orange wire is the bottom the angle is off. Is this something simple that I dont understand.
Old 12-01-2012, 06:13 PM   #14
SlowJoefromBako OP
Oddometer: 41
SlowJoefromBako screwed with this post 12-01-2012 at 06:26 PM
Old 12-01-2012, 07:35 PM   #15
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 546
take all spokes out separate into 4 equal groups clean and lube the threads put a dab of lub in all divots for the nipples start with a spoke and point it at the most likely hole in rim the go to the next hole in hub of the same direction skip 3 holes in rim and so on tell that direction is complete then start the opposite direction you should repeat this 4 times you'll get the hing of it shortly the straight pull spokes wait tell you try an older husky or ktm with 4 different length and bends like a rubik's cube
slidewayes is offline   Reply With Quote
Times are GMT -7.   It's 05:07 PM.
