Old 02-03-2013, 04:06 PM   #211
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,531
Originally Posted by COXR650L View Post
Bummer, how'd that happen? Any serious damage?
Don't let him fool you, he'll have it running like a well tuned F-15
Chris
VIDEOS
RideFreak is offline   Reply With Quote
Old 02-03-2013, 05:14 PM   #212
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 1,439
Originally Posted by AKASY View Post
Intake valves tuliped into the head:
Now if my memory of where everything goes can hold until I get the head back--I will be good to go
I've got the Husky TE510 in the background but it gets 38mpg with a 2 gallon tank--if I had to take it I would need a tow!
I performed the same repair to my CRF last fall. You could cut grass with how sharp the valves were, so much was worn out.
I did the valves and a new piston and rings while it was apart. Runs like a raped ape, just as before. I did two valve adjusts before pulling the head, then it was time.
If you have parts left over after you button it up, those are not needed. Just like KTM to over-engineer things.
Better it get fixed now than later for sure. Good luck with the reassembly.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 02-03-2013, 05:22 PM   #213
AtomicXRer
Wild Feral BRP
AtomicXRer's Avatar
Oddometer: 3,382
Wow...that was made in Austria! Temperamental.
I'll take the geisha.
Ok how many days do I have to try and figure this out Hey Assfault--you bringing a tow rope
2005 XR650R - plated
2003 KDX220 - plated
2003 KX250 - plated
AtomicXRer screwed with this post 02-03-2013 at 05:28 PM
AtomicXRer is online now   Reply With Quote
Old 02-03-2013, 08:01 PM   #214
COXR650L OP
COXR650L's Avatar
Oddometer: 825
So with all the bike work going on I guess I need to get started so I have something to ride I crashed my TE last June and it has not moved from the garage since then
On thing I want to add is a better luggage set up and I think I'd like to try a soft pannier system so I need to weld up some racks. Where in the Denver area can I get some decent prices on a stick of maybe 1in round something or another and 1in square tubing?
Any one have any suggestions?
Dubinky.com Enduro, Trail, Dual-Sport and Adventure Riding Apparel.
Westfest 2013
Canyonlands Adventure Ride
COXR650L is offline   Reply With Quote
Old 02-03-2013, 08:10 PM   #215
AKASY
Noob
Oddometer: 1,739
Racks
On a TE I went with a Giant Loop setup--works great on both my TE and the KTM--I've got the original one
http://www.giantloopmoto.com/product...te-saddlebag-1
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Old 02-03-2013, 08:14 PM   #216
AKASY
Noob
Oddometer: 1,739
Geisha
Oh you mean the one that you have to KICK to get it to move
I'll take valve adjustments and the red button
Old 02-03-2013, 08:24 PM   #217
COXR650L OP
COXR650L's Avatar
Oddometer: 825
I made a giant loop clone that I used last year and I felt really cramped on the bike with it and did not feel like I could move back much when riding aggressive and fully loaded. On a true dirt-bike the GL is a great set up, but there is no reason I cant do racks on the TE with some subframe modification.
My goal is to get the majority of the bulk of the luggage bellow the seat and moved further back, so I can have full range of motion while riding (or close to it) and it seems a soft pannier set up will do that better then a GL.
Westfest 2013
Old 02-03-2013, 08:31 PM   #218
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,531
Ben, I just picked up some wolfman e-12s for this ride (along with another bike) They are really nice, well thought out. Very secure and plenty of options for strapping stuff on them. Best of all no hardware reqd
Chris
VIDEOS
Old 02-03-2013, 08:47 PM   #219
COXR650L OP
COXR650L's Avatar
Oddometer: 825
Chris,
I actually have some of those already and really liked them. If I cant work something out in time I will probably use them again, but for overnight I'd like just a little more room.
These are kind of what Id like to get......
http://www.wolfmanluggage.com/Expedi...Dry_Saddle.jpg
Have you guys used a set up similar to this? Any issues?
Westfest 2013
Old 02-03-2013, 10:29 PM   #220
rinoman
Let's ride
rinoman's Avatar
Oddometer: 82
Ben, Try DENCOL steel.
http://www.dencol.com/steel.html
COHVCO
rinoman is offline   Reply With Quote
Old 02-04-2013, 06:19 AM   #221
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,531
Geo will eventually succumb to the button, probably won't be orange but it's just a matter of time
Sy, perfect time for a 570 kit, XR650 torque, KTM weight and handling, I rode behind Gordon's 570 and had to replace my new camera lens, they will definatey roost ya. My 525 is in pieces at the moment, it's getting freaked out
Chris
VIDEOS
RideFreak screwed with this post 02-04-2013 at 06:25 AM
Old 02-04-2013, 06:54 AM   #222
AKASY
Noob
Oddometer: 1,739
525
Nope sticking with stock--the older I get the less I like to "modify" em.
I just ordered a flywheel puller so don't get one--you can use mine.
Check your lower shock heim joint.
Get a clutch slave master cover and knock down bar.
Find your 13mm wrenches
Old 02-04-2013, 06:56 AM   #223
BuilderScott
BuilderScott's Avatar
Oddometer: 658
Chris,
Ben - I plan to use the same set up. I just installed them yesterday to try them out and see how it all works.
BuilderScott is offline   Reply With Quote
Old 02-04-2013, 07:52 AM   #224
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,531
Chris,
those are nice bags, good for multi day unsupported rides which has it's appeal - 1000 mi of Utah
Chris
VIDEOS
Old 02-04-2013, 08:34 AM   #225
burque magoo
master of disaster....
burque magoo's Avatar
Oddometer: 3,649
Chris, did you get the Wolfman duffle bag to go with the E-12s?
-Baja survivor NMOHVA/RMARiders.org/COHVCO/BRC/AMA/USA-ALL
I'm not a Gynecologist... But I'll have a Look...
2006 KTM450EXC/2003 Suzuki DRZ400S/2001 Honda XR650L
burque magoo is offline   Reply With Quote
Times are GMT -7.   It's 02:07 PM.
