Go Back   ADVrider > Riding > Regional forums > Latin America
Old 12-01-2012, 03:01 PM   #1
Two Moto Kiwis OP
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,982
Front Tyre Choice For 950 SE
So when we head south (again ) from Phoenix we will be two up on Maya (pronounced Miya) our new KTM 950 SE steed.
So it is a choice between the TKC 80 and Heidenau K60, they are my two but anyone else got some good suggestions for likely road conditions from here on in and which maybe more suitable feel free to chime in, usual combo of tar and gravel, will try and stay out of sandpits two up.
We had the K60 on the DR's and were not unhappy with them although the new tread depth is not great.
Will be running K60 on the back, sorted!!
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 12-02-2012, 10:03 AM   #2
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,800
I've been enjoying the MT21 up front. It lasts about as long as a TKC but handles the dirt much better.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 12-02-2012, 12:25 PM   #3
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,190
I've never liked TKCs, they wear out fast and the side walls are weak.
The MT21 can be found all over in LA and is better option imo.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 12-02-2012, 12:49 PM   #4
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,982
Metzeler MCE Karoo 2 ?
http://www.motorcycle-superstore.com...ront-Tire.aspx
Never had one, looks ok for our compromise??
Side wall strength? want something semi knobbly but no too knobbly for the road and a little longer life.
Old 12-02-2012, 01:20 PM   #5
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,781
I just mounted K60s on my SE. They seem fine and will probably last forever by looking at the tread; very deep. One thing I can tell you about the TKC is if you ever have a flat front at speed, you're going to lose complete control. As MG stated the sidewall is completely flimsy and it is a safety concern IMO.
Guero from Texas
COHVCO
AMA
PAPA
SJTR
jimmex is offline   Reply With Quote
Old 12-03-2012, 06:59 AM   #6
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
The reality of the situation is that you're going to be on pavement 90% of the time riding 2-up and what gravel you do won't be terribly gnarly. I'd get something more road oriented that will last longer. A distanzia or a tourance or something. With that mixture of weight and HP, you'll blow through rears, so I'd get the longest lasting tire I could find.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-03-2012, 01:20 PM   #7
GuateRider
Oddometer: 1,408
Like Airhead said , you will not see any dirt roads for a long ,long time . And the raining season is about to be over in Central America , so no mud neither .
In Guatemala I always use the Tourance , they are great on pavement and handle the eventual dry offroad pretty well .
Stay away from knobbies until you get much further down south !
Guatemala-Alaska-Guatemala
GuateRider is offline   Reply With Quote
Old 12-03-2012, 01:48 PM   #8
Misery Goat
Oddometer: 75,190
There's plenty of dirt to be found in MX and CA. If the OP just wants to blast the Pan Am then he can disregard.
The SE likes a good knobbie up front and you can still drag the pegs on the asphalt with it. The additional mileage you may get with a DS tire is negligible in my experience.
Same as it ever was
My Wanderlust
Old 12-03-2012, 02:06 PM   #9
GuateRider
Oddometer: 1,408
Originally Posted by Misery Goat View Post
There's plenty of dirt to be found in MX and CA. If the OP just wants to blast the Pan Am then he can disregard..
Plenty of dirt to be found yes , if you want to look for it riding 2up on a overloaded bike ...???
And there are lots of small and scenic paved roads besides the Pan American in MX and CA
Old 12-03-2012, 02:25 PM   #10
Misery Goat
Oddometer: 75,190
The SE is one of the most capable big twins offroad regardless of load. A knobbie up front keeps the options open and the performance concerns re asphalt are negligible.
And I never said the paved roads are not scenic.
Same as it ever was
My Wanderlust
Old 12-04-2012, 07:53 AM   #11
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,982
Reality is 80 - 90 % tar while two up, we will at times drop gear and go for a non tarmac look around like we did at Batopilas, I want some TKC80/Karro above, little better than maybe K60 front but not as knobby as the current front.
Anyone KNOW the sidewall strength of the Karoo? .... if not I will test and come back here with the real oil.
Old 12-04-2012, 08:26 AM   #12
Throttlemeister
Oddometer: 3,871
I'm a true believer in the MT 21 on front, just be sure and flip it back and fourth to get the longest wear, the rear doesn't matter so much just as long as you can steer your way through, you will have more than enough hp to turn and burn whatever rear tire you put on the big twin I'd personally go with a MT21 up front and a Scorpion, the Pirellis are good imho
Karoo rubber compound suck imho I run the tkcs long before the karoo
www.throttlemeister.net
Throttlemeister is offline   Reply With Quote
Old 12-04-2012, 10:34 AM   #13
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,291
I'm partial to the MT-21 front as well. My front of choice on the 990. Good dry pavement manners for a knobby, bites way better than a TKC, and has a stiffer sidewall. The front MT-90 has a pretty soft sidewall as well. Didnt get hardly an front flats running the MT-21.
Both Julio and the Goat are correct. You dont need knobbies, but at times you are happy to have them, and you can push it way harder in the dirt. The rear sliding around is no big deal, but front wash-outs tend to hurt kinda bad. Because of that, I always preferred to have a healthy amount of bite up front.
I run a little slower when its wet, but it didnt slow me down too much on the pavement as opposed to running a street tire. All depends on what you want to ride. But when you get down towards Peru and Bolivia, I would recommend putting on an MT-21.
As far as the rear Scorp is concerned, I got way more mileage out of the 150 than the 140. The 140 is Brazilian made, the 150 is German made, so different compounds I reckon. Its tough to find the 150's down there anyway and they are way more expensive when you do find them. I ran the rear 140 and 150 Scorp most of the time during my Latin America travels, but I put on a rear MT-21 for Bolivia, and glad I did.
Bad day to not have knobbies. I was running MT-90's front and rear, but I did make it through, just a little harder work.
Not essential, but way better to have knobs for this stuff.
Heck, for just starting again from the States, you might even consider a rear Conti Trail attack, guys have been getting crazy mileage out of those on the 9X0's. Given the mileage accounts, that tire ought to get you well into South America. There's a thread on the OC about them, but I have not tried one myself, just not dirt oriented enough for me.
One thing about riding the SE, you'll be constantly looking for rear tires.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster screwed with this post 12-04-2012 at 11:10 AM
crashmaster is offline   Reply With Quote
Old 12-05-2012, 05:53 PM   #14
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,982
Hmmmm opened a tin of worms
Back in the US now so time to make some orders.
Back tire we will run the 150/70 - 18 K60, keen to see what actual milage we get outa that.
Front ... bugga me, not sure now, always had TKC 80 in NZ and loved it, prolly ok on a lighter bike.
Kenda K784F Big Block Front Tire?
Metzeler Enduro 3 Sahara Front Tire? ... similar to the Heidenau
Throttlemeister what is sucky aboy the Karoo?
Old 12-05-2012, 08:32 PM   #15
crashmaster
ow, my balls!
Oddometer: 5,291
The Sahara 3 is similar to the MT-60, you will find both in Latin America as well. An OK compromise tire I guess if you're 80 to 90% tar, but I would still rather run the MT-21.
One buddy of mine ran the Kenda big block and complained that it wore down pretty quickly, but had really nice pavement manners. I dont have first hand experience with that tire though.
Havent tried a Karoo front, but the rear I ran lasted less than 500 miles then most all the knobs were chuncked off or smoothed out. The tire was trashed in one day of dirt road riding in Nicaragua. Granted I was spinning the shit out of it, but its an absolutely crappy compound IMO. We pulled into Puerto Cabezas and Mario looked at the rear tire and commented, "Well Vicente, we were wondering, but now we know the Karoo is an absolute pice of shit."
Once you get down south the most common 21" choices that you will see will be random Chinese dirt bike knobbies, mixed with MT-21, MT-60, MT-90, some Sahara 3's as well IIRC. MT-60 being the most common of the Pirellis from what I saw.
Buen viaje!
crashmaster screwed with this post 12-05-2012 at 09:00 PM
Times are GMT -7.   It's 08:02 AM.
