Old 12-02-2012, 01:30 PM   #1
mpatch OP
Oddometer: 902
filling up empty space in saddlebags?
with my typical 2-3 day load I have quite a bit of unused space in my bags and when the pavement ends stuff bounces around way too much. the main thing is my tool roll. I am running soft bags FWIW. I have thought about moving my tools to my top rack but would rather keep the weight as low as possible. I am thinking something inflatable that could be adjusted according to how full the bags are.
mpatch is offline   Reply With Quote
Old 12-02-2012, 01:38 PM   #2
Craneguy
British Hooligan
Craneguy's Avatar
Oddometer: 1,027
$2 kids arm floats from Walmart?
Young enough to think I can. Old enough to know I shouldn't. Stupid enough to do it anyway
'13 Duc Multi GT, '10 Vstrom 1k, '10 705cc KLR
Craneguy is offline   Reply With Quote
Old 12-02-2012, 01:41 PM   #3
Medic
Window licker
Medic's Avatar
Oddometer: 597
A couple of inflatable pillows, and you can use them to rest yer head on at night.
Why carry something that is only used to take up space, make sure it can be useful as well.
www.auskawasakiriders.com
FarRider #332.
Medic is offline   Reply With Quote
Old 12-02-2012, 01:43 PM   #4
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,171
Inflatable camp pillow?
Pack more stuff?
I never seem to have this particular problem.
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Old 12-02-2012, 02:02 PM   #5
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 890
What kind of bags are they? Are you against sewing a compression strap to them? My saddle bags have a compression strap that allows me to cinch them down tight even when they are nearly empty, keeping the load stable even at speed offroad.
I would think that anything inflatable would just be a pain in the butt being that it is vulnerable to being popped wether by crash/drop or possibly even just snagging it, not to mention that you have to deal with inflating and deflating depending on the load.
The Letter J is offline   Reply With Quote
Old 12-02-2012, 02:30 PM   #6
mpatch OP
Oddometer: 902
Ortliebs, I did run a Rok strap under the plastic stiffening insert that works for lighter things just not a heavy tool roll
Old 12-02-2012, 03:18 PM   #7
kubiak
Oddometer: 4,810
i made cardboard inserts to keep the bags shape when empty and used to use smaller bags inside the main bag and some old t shirts to keep things from bouncing around and to keep things together.
Old 12-02-2012, 06:59 PM   #8
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
I run Ortleibs too and they are typically mostly empty. I haven't had the issue you have, but I keep my tools in my Pelican topcase. Unfortunately, I don't have a good spot for a tooltube but if you do, you may want to put the heavy stuff.
The stuff that typically is in the bags year-round are things like jacket liner, FroggToggs, tube(s), warmer/colder glove depending on the season.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 12-04-2012, 07:47 AM   #9
achtung3
achtung3's Avatar
Oddometer: 979
What a good problem to have- extra space!
SNACKS, anyone can use some extra of that!
achtung3 is offline   Reply With Quote
Old 12-04-2012, 08:41 AM   #10
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
As others have said, it's best from a mass centralisation point of view to have bags that cinch down to deal with being partly full. Failing that, some sort of compression straps (Rok Straps are good) to squish the bag small.
If you're not able to do that with your current setup, expanding existing stuff you're carrying is the way to go; undo compression straps on sleeping bags and any stuff sacks, inflate your camp pillow, etc.
It's inevitable you will sometimes need to carry additional stuff aside from what you pack in your bags normally that will be used up and leave some surplus. For example, firewood, food, cans of beer, etc. I carry a bungee net rolled up under my rear-seat. This way, I can avoid carrying these sort of things inside my bags and instead just lash them to the outside for the brief time I need the extra capacity).
HTH
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Times are GMT -7.   It's 11:52 AM.
