Old 12-04-2012, 01:05 PM   #16
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,642
I've modified my stock skidplate to float on the crashbars, disconnecting it from the engine entirely. I've got the SW Motech bars, which have a flat crossbar under the skidplate. In a normal installation, the skidplate is mounted to the motor via the rubber isolation mounts, and the crossbar sits under that, spaced off about in inch. I removed the rubber isolation mounts and bolted the skidplate directly to the crossbar. At the back, I cut two .75" slots in the plate and use a pair of hose clamps to connect to the catylitic converter mounts. I placed a piece of heavy 1" rubber, cut to fit, between the motor and skidplate as an impact absorber. The system works pretty well, I've taken some impressive hits to the assembly and it is holding up.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 12-04-2012, 01:20 PM   #17
mrt10x OP
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,200
Well in typical fashion I threw money at the problem and simply bought the Black Dog Skidplate... wonderful folks to deal with OBTW, I had a 45 minute conversation with them on a variety of topics. I will probably just leave the snapped off bolts in there. If I do decide to sell the bike someday I will cross that bridge at that time.
T/E I just need to send you a PM ever time I screw up something, you always have a good solution.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 12-04-2012, 01:39 PM   #18
Twilight Error
Oddometer: 22,642
If I've got a good solution to a problem, its usually because I've tried every bad idea first.
Old 12-05-2012, 06:58 AM   #19
mrt10x OP
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,200
So there is the picture.. as you can see..broken off EZ out and the failed attempt to re-drill for the next larger EZ out.
Despite the fact that I have already pulled the trigger on the Black Dog skid plate, mostly because I love the design, I will still try and remedy this situation for future resale issues. As I look at the picture it occurs to me that there may be some bolt actually sticking out of the threads where the rubber and washer are.. you cant see the washer in the pic, it is between the rubber and the engine block. I will take a closer look at it this weekend.
Old 12-05-2012, 03:31 PM   #20
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,909
From the pic it looks like you simply broke the rubber bumper in half. Did you try grabbing the metal disk on the top of the bumper with a vise grip and loosening?
bemiiten is offline   Reply With Quote
Old 12-05-2012, 04:13 PM   #21
mrt10x OP
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,200
well I had to cut the bumper down to get to the bolt.. Is the metal disk hard attached to the stud on the top? I have changed the oil on the bike a half dozen times but I honestly never looked that closely at the bumper... the metal disk/washer is definitely still there... I will give it a shot.. will heat make it easier to break free?
Old 12-05-2012, 04:32 PM   #22
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,794
I thought you had already broken the disc off the threaded stud.
Typically they are constructed like this:
You should be able to grab the od of the steel disc with channel locks and turn out.
It might help to cut away as much rubber and heat with a torch flame first.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 12-05-2012, 04:42 PM   #23
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 13,693
This
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 12-05-2012, 05:03 PM   #24
Twilight Error
Oddometer: 22,642
Absolutely. If BMW put threadlocker on at the factory, heat will make all the difference in the world.
Old 12-05-2012, 05:57 PM   #25
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 968
I'm glad others posted about this already. In my mind, the skidplate mount shown is similar to window regulator mounts that are used in BMW cars. They're basically 2 studs welded to 2 washers that have a rubber cushion between them. You're lucky since it looks like you simply tore the cushion and left behind the washer/stud that's screwed into the sump. I think you're golden.
So, how much for your new (and uneeded) skid plate.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 12-05-2012, 06:06 PM   #26
EScott
Oddometer: 52
I did the same thing to one of mine when I tried to mount my new Altrider plate.. I'm not sure, but I think those bolts are set up as "sacrificial" items to prevent too much force from being transferred into the motor case.. I also believe you should be able to grab that one with some vice-grips or something similar and unscrew it from the case with some care and a bit of luck.. Replacements for these are cheap, I picked up a few extras while I was at the dealer..
EScott is offline   Reply With Quote
Old 12-05-2012, 07:56 PM   #27
tjt94
Oddometer: 594
You probably can just use some plumbers pliers on it. I wondered about if you ripped the rubber mount in half and were trying to retrieve the stud that is part of it. These are really cheap and easy to replace.
tjt94 is offline   Reply With Quote
Old 12-06-2012, 01:34 AM   #28
aGremlin
aGremlin's Avatar
Oddometer: 517
Another picture for you:
Warning: My post quality varies according to my mood. If I sound sane give it a few minutes and I'll be back to normal
aGremlin is offline   Reply With Quote
Old 12-06-2012, 08:05 AM   #29
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,794
Ha Ha, a happy ending!
Old 12-09-2012, 09:47 PM   #30
aGremlin
aGremlin's Avatar
Oddometer: 517
Eh? I'm not OP, I just posted another picture to help...
Times are GMT -7.   It's 09:21 PM.
