Old 02-17-2013, 06:05 PM   #31
motor-ray OP
FNG
motor-ray's Avatar
Oddometer: 68
Part 2 of ? (AKA about dang time!)
Rear brake pressure switch
The brake light switch install is pretty straightforward as long as you feel comfortable bleeding brakes. First, use a 6mm allen bit to break the bolt free. Do this before you loosen the rear master cylinder bolts as it is on there pretty tight! I then loosened the master cylinder so I could have more room to work and installed the switch. I am still not really happy with my wire routing as it is close to the exhaust and makes a sharp bend (worried about chaffing) to go to the middle harness.
Second, I bled the brakes. I highly suggest doing the bleeding with a small loop of line as shown in the picture. This is way easier and less messy than trying to push the brake down, crack the bleeder, close the bleeder, let the brake pedal return, and then repeat. With this method you simply push the pedal down, crack the bleeder, and start pumping the brake until no more bubbles come out. Just don’t let the tiny brake reservoir run dry!
No excuses, No regrets, Never give up!
motor-ray is offline   Reply With Quote
Old 02-18-2013, 05:19 AM   #32
Gundy
Oddometer: 948
Originally Posted by motor-ray View Post
Having owned a WR250x (the street motard version) I would be very tempted to go that way again. They have good power and the gearing is pretty good. What most people don't realize is the WR250R will run (or outrun) a DRZ400. I really just like putting these bikes together so I went with the 450.
Interesting perspective. I had a fully modded 250R/X as well as a DRZ. There are a few of these new 450s around here and they have been marked down to almost the same price as a new 250 or 400. I'm not a power junkie but it would be nice to start with a bike that has all the power anyone needs with quality suspension. Spending a couple hundred on a street legal kit seems cheaper than 500 on suspension, 700 on a exhaust + programmer, gearing changes, dirt tires and so on....
What kind of valve check intervals are in the manual for the 450?
Also curious how much you weigh, and gear you carry on the bike? I'm about 210 sitting on the bike and my 250R had i guess enough power, but definitely coud have had more torque/snap for aggressive offroad riding, especially in the sandy stuff around here.
BTW, that is a great tip for brake bleeding!
'12 Sertao, '00 KDX220R '12 Tenere, '04 Tiger, '09 WRR, '06 DRZ, '06 TW, '01 250 EXC, '09 KLR
Gundy is online now   Reply With Quote
Old 02-18-2013, 08:01 AM   #33
motor-ray OP
FNG
motor-ray's Avatar
Oddometer: 68
I guess it depends on the type of riding you are doing and where you are doing it. If you are doing primarily dirt (more than 70%) I would go with the 450. the points you make are very valid. If you are primarily riding the bike around town and occasionally doing dirt I would go with the 250R simply for maintenance and streetability. I agree the extra power of the 450 would be very handy in sand and also at elevation. I live at sea level but plan on doing the TAT eventually and that was another reason I went with the 450. I have over $500 in the Baja Designs kit, mirrors, LED signals, and competition ECU and I have not yet bought the GYTR Power Tuner programmer ($280). So you will still have more than a few bucks in getting the bike on the street. But, that being said, WR450's can be bought at a very good price (as you mentioned).
The valve inspection interval for the 450 is every third race or 500 kilometers. Huge difference compared to the 250! And the cams have to come out to do the valves. But, I also know from experience on my 2006 YZ that you could go much longer between adjustments if you aren't beating it all the time.
I weigh around 230lbs with gear on. I plan on putting some Kriega bags (http://www.kriega.us/overlander-30-m...annier-system/) on the bike for carrying gear on longer trips but I have not done that yet. I have just been using an old tail bag for the time being.
On a side note, I am getting the Power Tuner (http://www.yamaha-motor.com/sport/ac.../0/detail.aspx) for the bike because I want to program more "snap" off the bottom because of my weight. The Power Tuner lets you change the entire powerband to cater to your specific needs. It adjusts much more than just fuel delivery.
I learned to bleed brakes in this manner a couple years ago when I had to do the brakes on a car by myself. It is much easier than even using a vacuum pump in my opinion (at least on motorcycles where it is really easy to run the small reservoirs dry). Another little trick I learned when I put a new front master cylinder on my my old 450 motard is to depress the brake all the way and use a zip tie or strap to hold the brake that way (in or down) and leave it over night. (do this after you have done your initial bleeding). It really helps if the brake feels a little "wooden" and doesn't have good feel. If I would have bench bled the new master cylinder (like the instructions said ) I probably wouldn't have had to do this.
Thanks for your comments. You brought up some good points.
Old 02-18-2013, 02:22 PM   #34
Davidjohnson
Oddometer: 79
Sorry for the slow reply. Yesterday is the first day in over a month that I have been on ADV due to me being a slacker!
1. The gray wire mod is not neccessary (as far as I know) as the competition ECU handles most of the uncorking.
2. I have not tried the insert. Removing the stock insert helps but I would consider a performance exhaust as the outlet is still pretty small. Obviously you would need to adjust the fuel mixture with the GYTR tuner if you did this.
3. The plastic is ok for what I do. I may still go to aluminum once I get some more time on the bike.
4. I can go about 75 miles before the light comes on (it is pretty pessimistic). I really don't have the bike broken in yet so I am not sure what the final fuel mileage is going to look like. If you are thinking about doing 90% road I would consider a different bike. If its 90% dirt you're looking at this would be right up your alley!
To clarify, I am 10 pavement, 90 dirt (including a sprinkle of high speed dirt fire roads)
Mine is set up similar to yours. Do you have any recommended maps?
I have the gytr exhaust insert, but if I had to do over again, I would buy the full gytr FM can. I probably will end up doing so; I rode one with it and you can tell the difference.
David Johnson
Davidjohnson is offline   Reply With Quote
Old 04-03-2013, 10:25 AM   #35
DuncR6
Oddometer: 3
Just an FYI, the 2012 and 2013 models are identical.
This is curious to me. I've seen the 2013 with a fuel tank rating of 2.7 gallons and the 2012 with 2.1 gallons. Yamaha's website now has them matching.
1.) Can you confirm that the tank is actually 2.1 or 2.7 gallons?
2.) What is the difference between your TCI ignition the 2012 CDI ignition? Is one necessarily better than the other?
3.) How much louder is the bike without that plug in the exhaust?
DuncR6 is offline   Reply With Quote
Old 04-03-2013, 11:11 AM   #36
cross-country
cross-country's Avatar
Oddometer: 1,679
Nice thread! I hope you don't mind me dropping in some tidbits and asking some questions in your here..?
I am racing the Mexican 1000 on a 2012 WR450. Love the bike, I'm pretty impressed with the handling. It had a 45 tooth sprocket and at 5000' it seemed like it could get away with much taller gearing so some 42 teeth sprockets are on their way. The GYTR FMF megabomb system was a bit louder than I would like but I would complain about the power. I thought it was pretty cool that FMF had welded in brackets to reattach the stock guard.
The bike did have issue with flame outs and hard starting. I'm hoping the dealer can work that out for us. I'm guessing it is just a TPS adjustment. The other issue that came up was a "clanking" noise developed in the forks. I first noticed they were feeling a bit harsh and then on some bigger g-outs I could hear the metalic clank. When I stopped to check things out there was fluid leaking out around the caps.
Mounted the Nav Tower and Broke in the engine this weekend, I used a HighwayDirtbikes.com Nav Tower/Fairing and handguards, Garmin Montana 650t GPS and F2R Roadbook holder.
I made a baseplate out of a sheet of HDPE, and rewired a KTM thumb switch to work the Yamaha computer. The stock computer will get moved over and replaced by an ICO before the race. I made notes so if anyone wants a diagram of how to with in switches to control the stock computer PM me.
Does anyone know of a replacement wheel spacer that will allow for removal of the mechanical odo drive, I have looked around and have had zero luck so far.
cross-country screwed with this post 04-03-2013 at 01:50 PM
cross-country is offline   Reply With Quote
Old 04-05-2013, 06:42 AM   #37
PTRadam
Oddometer: 504
I'd imagine something from the YZ line would fit but maybe entire hub is different?
PTRadam is offline   Reply With Quote
Old 04-05-2013, 09:05 AM   #38
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 540
In the past I have used a plug and left it.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 08-04-2013, 12:36 PM   #39
rensho
Oddometer: 182
odo wheel cap and spacer
http://flatlandracing.com/Merchant2/...er+Eliminators
rensho is offline   Reply With Quote
Old 08-06-2013, 05:13 AM   #40
DirtViking
SKOL!
DirtViking's Avatar
Oddometer: 372
flame-outs
Cross-country...
I own a '12 450 and have been around and around trying to figure out the proper restarting procedure (one that works). They may have fixed this issue on the '13 models... I don't know.
Anyhow, here's what works for me. I really can't explain why. On a flame out, open the throttle to full and press the start button for a few turns. Completely close the throttle and then start. I'm gonna say that will work 90% of the time. I don't know why, can't explain it. Bike has been stupid easy to kick start, will go on 1st or 2nd kick every time, hot or cold. E-start is another story... I also upgraded my battery to more cca. I think it's 220 where the stock was 160. Don't quote me on those numbers.
Other than the starting issue, I absolutely love the bike. Not sure a 6th gear is needed for this machine. I seem to be humming along quite nicely at 65-70 without any issue. It's surprisingly smooth at those speeds. Suspension has been good for me, wouldn't change a thing. I did get the Baja designs kit, like the op. Also, have a seat concepts seat to replace stock... what an upgrade. Highly recommended.
Look forward to seeing these projects. Both look pretty awesome.
Jon
2011 1200 GSA
2012 WR450F
1970 Triumph Bonneville
DirtViking is offline   Reply With Quote
Old 08-06-2013, 06:12 AM   #41
focallength
You're Welcome
focallength's Avatar
Oddometer: 5,086
Get rid of those signals and get some good flush mounts, those signals break far too easily.
what was the greatest thing, before sliced bread?
focallength is offline   Reply With Quote
Old 08-06-2013, 05:00 PM   #42
SMIFFXC
SMIFFXC's Avatar
Oddometer: 137
+1 to that. Very first ride out one of the rear signals was gone! Flush nounts look better too!
SMIFFXC is offline   Reply With Quote
Old 08-07-2013, 06:32 PM   #43
Natemx42
Oddometer: 1
I signed up for ADVrider just to reply to this post. Jason Raines makes the sickest ODO spacer I've seen. Don't forget to order up a seal from your local dealer, or use the old one out of the odo pick-up...
http://www.rainesracing.com/ProductD...9/Default.aspx
I've got a '13 that I turned into a motocrosser, feel free to follow up with any questions! I'll try and get around to pictures.
Thanks,
Nate
Natemx42 is offline   Reply With Quote
Old 08-08-2013, 12:56 AM   #44
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,111
removable indicator
Check out this great Aussie solution. http://www.clicknride.com.au/
I put them on my WR after wasting time and money on small LED's. Pull them off and shove them in your bum bag ( fanny pack to Seppos )
Rider 101 is offline   Reply With Quote
Old 09-16-2013, 05:03 PM   #45
Chet Punisher
Chet Punisher's Avatar
Oddometer: 88
Lets see some updated pics!!!!
Chet Punisher is offline   Reply With Quote
Times are GMT -7.   It's 07:50 PM.
