12-04-2012, 06:00 AM
#16 |
Oddometer: 14
![]() I am using a very small Shorai battery tucked under the seat (LFX14a1-BS12) It is small enough to fit in the air filter if you wanted to. I was concerned at first if it would crank the bike on cold mornings. I live in Minnesota. It has been a champ so far. Event on those cold 30 degree mornings |
12-04-2012, 07:33 AM
#17 | |
De Jo Momma
Oddometer: 8,735
The battery is in a pocket. There is a friction component keeping the battery located within that pocket. The ONLY thing the bolts have to do is keep downward pressure on the battery and it ain't going anywhere--same as straps. Rocking the battery exerts a lifting force and only the tiniest of bending forces. Those bending loads are negligible until long after the battery has translated enough to leave the tray. It's not going anywhere. My biggest worry in that installation would be engine vibration being transmitted directly into the dangling lead plates in the battery. That's a sure-fire way to destroy a battery.
Greg |
12-04-2012, 09:30 AM
#18 | |
Jon-Lars
Oddometer: 419
Jon-Lars screwed with this post 12-04-2012 at 10:28 AM |
12-04-2012, 09:45 AM
#19 | |
Mad Scientist
Oddometer: 3,005
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
12-04-2012, 09:59 AM
#20 | |
Oddometer: 267
All corners of this aluminum plate are cracked. A good rule of thumb is to use a radius 3x aluminum thickness. At least for 6000 or 3000 T3 or T4.
http://www.halflive.hostei.com |
12-04-2012, 10:11 AM
#21 | |
De Jo Momma
Oddometer: 8,735
This is how people can have a $100K seat of Nastran and get hyper-accurate, yet incorrect results. Perhaps explain how a rubber strap over the same tray would hold the same battery in place? The rubber strap has no meaningful resistance to bending. Is it magical, non-bending rubber?
Greg |
12-04-2012, 10:20 AM
#22 |
Oddometer: 199
Love the discussion. I have spend a great deal of research on this matter. I am not wanting to subject my daily rider to early burn out so I am keeping the airbox in place. What I have done so far is shaped 2 US license plates by hammering them and enclosing the current batter box. That allowed me to remove the side covers and to have a "custom" look. The "hammering" procedure was a workout and an experience in off self, one plate I did on concrete and the other on wood. It's different. When I change the rear subframe to a /5 short I will hang the battery underneath the seat in a custom box. It will be out of the way, it will be an open look, which will work well.
Bottom line for you will be "What do YOU like" and what you can afford. Making it yourself might be the cheapest way, but all the suggestions given to you will work and are different....even the one you don't like from Boxer Metal under the frame (BTW: I considered it, but was not willing to sacrifice the centerstand). My brother runs a Lithium battery on his 2010 K 1200GT and he loves it... technology... Compromise....it is what it is.... compromise....
12-04-2012, 10:25 AM
#23 | |
Oddometer: 907
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
12-04-2012, 10:27 AM
#24 |
Mad Scientist
Oddometer: 3,005
All corners of this aluminum plate are cracked?
12-04-2012, 11:23 AM
#25 | |
Jon-Lars
Oddometer: 419
I am only concerned about the mounting of the bolt to the base. It's fixed on one end, weakened by the cut threads, and highly stressed. There is no way to alleviate the side load with the threaded end fixed that way. Jon-Lars screwed with this post 12-04-2012 at 05:32 PM |
12-04-2012, 04:48 PM
#26 |
Oddometer: 199
We live in South Carolina and have aweful Summers. My brothers bike is K bike with a full fairing and it is in the middle of the thing. I would say, that you are good to go with summer concerns. Should not be an issue....
12-04-2012, 05:14 PM
#27 |
Oddometer: 430
This is in an old BMW, I dont think the force from from the engine will rock that battery too much.
12-04-2012, 11:13 PM
#28 |
Semi-Occasional
Oddometer: 1,535
Yeah...if mine accelerates (or brakes) hard enough to snap the battery mounts off, I will be the happiest airhead around.
Those mounts aren't going anywhere. Just because you can come up with a conjectural scenario for failure doesn't mean the actual scenario will lead to failure.
'74/'70 R98/6/GS Traveling Bike (construction under way) '91 Bill Holland Steel w/Dura Ace |
12-05-2012, 04:50 AM
#29 | |
Jon-Lars
Oddometer: 419
Of course not. Poor design leads to an increased chance of failure, not a guarantee of failure. The failure mode I have in mind isn' sudden but rather eventual cracking and separation after subject to vibration and off-axis excessive loading. Jon-Lars screwed with this post 12-05-2012 at 07:33 AM |
12-05-2012, 07:42 PM
#30 |
Oddometer: 166
