Old 12-03-2012, 06:44 PM   #1
bikecat OP
bikecat's Avatar
Oddometer: 1,117
Wicked Replacing BMW nuts, washers etc
Hiya,
I am thinking of replacing stock nuts and washers with stainless steel ones. Any downside to this? For example, I am thinking of replacing items 2 and 3 below
with this one-piece item:
Views?
bikecat is offline   Reply With Quote
Old 12-03-2012, 06:49 PM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
It'd probably work alright, but the wave washer acts as a lock washer. That one piece deal might back itself out. It'd probably work fine alright though.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-03-2012, 10:29 PM   #3
squish
Out of the office.
Oddometer: 6,266
The stainless nut alum head and steel stud will set up recipe for galled threads and a busted stud in the valve cover.
I'd stick with stock BMW in that area. If your worried about it looking bad get some high heat silver and black paint and just touch it up with a brush.
On vacation for a spell
squish is offline   Reply With Quote
Old 12-03-2012, 11:30 PM   #4
mikeprince
Oddometer: 19
Beside the already stated galvanic reaction problem when mixing dissimilar metals, the washer acts as a smooth surface for the nut to tighten against so the torque applied to the nut can be more accurately measured.
As an example of the opposite, what if the surface the nut was turning against had a few heavy scratches/ridges? Then the nut would feel tight to turn even though the bolt was not being stretched very much. The stretch in the bolt is what compresses/clamps whatever is between the bolt head and nut. The most common extreme example of car makers being sensitive to this is in head bolts where they specify to NOT re-use them because each use polishes the bold threads which throws off the torque to stretch ratio.
The really cool solution to this all (which no-one except some military and probably aircraft/spacecraft folks do) is to not use torque but instead nut turns past initial contact. For this you need to know the bolt material, diameter, pitch, and the length of bolt that will do the compressing (the stretched part). You then turn down the nut to make contact with the washer, and then turn the prescribed number of turns to get the desired stretch/compression. Cool stuff.
mikeprince is offline   Reply With Quote
Old 12-04-2012, 01:08 AM   #5
chasbmw
Oddometer: 2,259
Very many of the various nuts bolts and spindles on my bikes are SS, I have never suffered from any galvanic reaction and or galled threads on my bikes, I'm sure that it is possible in theory but not in practice,I do use a smear of copper grease on the threads.
There are also a variety of wave washers available in SS. It is also very possible to over think torque values in airheads, the only places I use are torque wrench are the cylinder head bolts and the swinging arm, otherwise some sympathy for the nuts bolts you are dealing with works.
Charles
1971 Commando Fastback
Old 12-04-2012, 03:24 AM   #6
rambozo
rambozo's Avatar
Oddometer: 545
+1 on what chas said
Almost everything on my /7 is stainless and iv had no problems,
from axles to carb top screws, i get mine from shaw stainless in
England, he specialises in BMW and Moto Guzzi and it's very good
quality, down to the correct waverly washers. There's a lot of poor
quality ss out there so be careful
I rarely use a torque wrench outside of an engine or gearbox, it's
down to how much experience you have too though, be sensible
with force and if you're not confident enough use a torque wrench
rambozo is offline   Reply With Quote
Old 12-04-2012, 07:39 AM   #7
squish
Out of the office.
Oddometer: 6,266
Where I live I can toss a rock and here it go splash into the ocean.
Galvanic reaction is a way of life here. The op's stated location is the tropical far east, I would think that that kind of environment would be ripe for rust, just like my own home.
Old 12-04-2012, 08:07 AM   #8
chasbmw
Oddometer: 2,259
Our roads over here are salted in the winter. I have also noticed that yachts combine SS and aluminium.
Charles
Old 12-04-2012, 01:28 PM   #9
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 150
"It is also very possible to over think torque values in airheads"
After nearly fifty years of motorcycle ownership and ten years on motorcycle forums, I do find our American friends over analyse stuff as well as an unhealthy reliance on bloody torque wrenches. We should remember that in the main, motorcycle engineering is only one step up from Lego not one step down from nuclear physics
Paul_Rochdale is offline   Reply With Quote
Old 12-04-2012, 01:57 PM   #10
supershaft
because I can
Oddometer: 9,116
Stainless is for boats.
supershaft is online now   Reply With Quote
Old 12-04-2012, 03:00 PM   #11
rambozo
rambozo's Avatar
Oddometer: 545
In my climate if it's good enough for boats it's good enough for me
Sorry to disagree supershaft, I like your posts because you seem to ride similar to me, I
rev till the engine says no, not the counter, but one thing I don't like is rust, plenty of
grease and good quality stainless is hard to beat. Paint is okay until you put a spanner to it
Good proper rated stainless is dear but if you live in a place where it rains almost constantly
and the roads are salted in the winter it's worth it
Old 12-04-2012, 04:33 PM   #12
bikecat OP
bikecat's Avatar
Oddometer: 1,117
Thanks for the views and replies.
I have decided against it because the underside of the nut has groves that will mark / wear the surface of the cylinder heads. Pity, I was really hoping to replace 2 components with one.
I had used SS bolts to replace stock ones without problem.
The washer that BMW has on this part is really thin, I wonder how useful is that and will it matter if I replace the washer with a thicker one. Does it matter if the inner diameter is slightly bigger?
Cheers
Old 12-04-2012, 04:51 PM   #13
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,541
I use the ordinary nuts but no washers on the rear side of the valve cover. I don't notice any exceptional amount of wearing of the Alumninum but I guess there may be some. Like It will be noticeable in 50 years or so.
---Albert Einstein
Old 12-04-2012, 05:04 PM   #14
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
Guilty as charged. We overcomplicate everything. During the space race NASA spent millions developing pens that would write in zero gravity. The soviets just used pencils. I try to be more russian than american with engineering problems.
Old 12-04-2012, 05:05 PM   #15
JonnyCash
turd polisher
Oddometer: 1,591
They do it ,but it causes all sorts of trouble. Anywhere you have winches or other hardware attached to an aluminum mast with stainless, it's almost guaranteed to give trouble next time you go to disassemble it. On bikes though, I've never had stainless fasteners cause trouble.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Times are GMT -7.   It's 11:50 AM.
