Old 12-03-2012, 10:20 PM   #1
mrfortynine OP
Oddometer: 66
How to disconnect neutral switch wire from left handle unit on 92 R100R?
I need to replace the left handle unit housing, which requires me to disconnect clutch lever, clutch cable and neutral switch wire. But I couldn't figure out how to disconnect the neutral switch wire, which seems require a special wrench to reach the recessed part of the cable in order to untighten it.
The cable in question is part #6 in this image.
Any suggestion? Thanks a lot.
jia
mrfortynine screwed with this post 12-03-2012 at 10:35 PM
mrfortynine is offline   Reply With Quote
Old 12-03-2012, 10:29 PM   #2
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 724
I have managed to unscrew mine with a pair of long nose pliers, it was a bit of a fiddle though.
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is offline   Reply With Quote
Old 12-04-2012, 03:07 PM   #3
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 984
It's actually the clutch cut out switch so you can start the bike in gear with the clutch pulled in.
Freakin' hard to get out. If the switch is bad, cut off the wire and use a deep socket to remove.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 12-04-2012, 03:12 PM   #4
mrfortynine OP
Oddometer: 66
Thanks for the correct, Beemerguru.
If cutting the wire the best way to get it out, what’s the recommended method to connect new wire then?
Old 12-04-2012, 04:38 PM   #5
boxerkuh
Oddometer: 230
I would not cut it, that means that you will have to replace it. If you need to replace it anyway then it is okay to cut it. It is one of those task that is fiddly, a pain in the a**, one that I had to walk away from a time or two. Using a open end wrench helps and once loose you may find it easier to do with your fingers. Patience on that job, but it will come out. Good luck.
boxerkuh is offline   Reply With Quote
Old 12-04-2012, 05:20 PM   #6
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,272
Yup, a job I need to do now because I have a broken clutch perch, from a heavy crash last week. I've seen that the switch is threaded (you can see this in the new perch), & the switch has a hex end to allow this to be tightened.
Follow the clutch switch wiring to the junction under the tank, disconnect this, loosen the clutch perch housing clamp, & then slide the perch off the handlebar. You should have a little more room then
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Times are GMT -7.   It's 09:15 PM.
