Old 12-04-2012, 01:05 AM   #1
digger440 OP
digger440's Avatar
Oddometer: 74
Question How much current can a electronic module handle???
In the cafe build I am doing I was looking at going COP using ford modular motor coils, specifically these:
http://www.summitracing.com/parts/acc-140032/overview/ Which have a .66 ohm primary resistance
I read here http://www.largiader.com/articles/ignition/ that 1981 on coils were 6V wired in series with .7 ohms primary resistance
Using ohms law 2 stock coils @ 12V with .7 Ohms primary resistance each, wired in series, yields an 8.7143 amp load
while the aftermarket DIS coils @12V with .66 Ohms primary resistance each, wired in series, yields a 9.09091 amp load
A 0.37661 amp difference, would any electronic guys care to chime in? I know transistors can have severely reduced service life with even just a little more load then they are supposed to have. Now I am not going cross country on this thing, but I do not want to have to keep a spare ignition module under the seat either (this is not a early 90 GM I am building)
R100 cafefighter build in progress
http://www.customfighters.com/forums...ad.php?t=85610
digger440 screwed with this post 12-04-2012 at 01:12 AM Reason: been drinking, ETA punctuation
digger440 is offline   Reply With Quote
Old 12-04-2012, 07:11 AM   #2
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
There is more to it than Ohm'sche resistance. Your 2 x 0.7 or 0.66 limits your current to the coils, so with lower resistance comes higher current and eventually higher coil charge using the same dwell time. So I would agree that from that perspective there should be enough margin to run the 6V/0.66 Ohm coils. Don't forget though, that with heat the resistance decreases and at 3000rpm + your voltage is more about 13V than 12V. So its more like 10A current.
Now as to the coil inductance: the coils discharge upon shortening the primary side to ground and that creates a strong temporary force field which in turn creates a high voltage at the spark plugs and a back EMF. The force is dependent on the inductance and charge of your coil and that could be a limiting factor. That high voltage on the output (8KV+) does create a higher voltage at the primary side as well which has the potential of damaging your ignition module when running an electronic ignition or arcing of points when running a Kettering ignition.
I have tried it with different coils, but never long enough to see any long term problem.
(Disclaimer: due to my mental state I can not be made responsible for any damage resulting from using the provided information)
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB screwed with this post 12-04-2012 at 05:37 PM
StephenB is offline   Reply With Quote
Old 12-04-2012, 09:29 AM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,348
You do realize don't you that those are COPs? That is Coil On Plug units. The coil sits directly on top of the plug. It does not have a plug wire or a plug cap in the sense of the systems we are used to. I think they will need some kind of bracket to stabilize them. I do have a Ford but mine is the vintage just before the COPS. I hear the guys with COPs complain about damage from water if they wash the engine. This might be an issue with a motorcycle's electrics out in the wind as it were.
---Albert Einstein
disston is online now   Reply With Quote
Old 12-04-2012, 09:33 AM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,625
+1. It ain't the resistance as much as it's the inductance.
--Bill
'73 R60/5 Toaster
Old 12-04-2012, 11:25 AM   #5
supershaft
because I can
Oddometer: 9,116
In my experience, not much. Run your primary resistance as high as or higher than what the ICU was designed for.
Old 12-04-2012, 04:10 PM   #6
digger440 OP
digger440's Avatar
Oddometer: 74
Thanks for the replies, especially StephenB, they are appreciated. With such a simple ignition system I may go ahead and try it. If the stock module poops the bed I will just adapt something a bit more heavy duty in its place.
and disston I am very aware these are COP coils that is in fact why I wanted to use them. I remember seeing that somewhere? Oh it was in the first line of my post, RIF and all that.
But, with all (honestly) friendly sarcasam aside the reason there are problems with these coils and water in thier factory environment is because they sit down inside a hole that is not sealed. the water goes into the spark plug well and gets drawn up the boot through steam and capillary action. if left long enough it will even draw up iron oxide from the plug base making a nice path for the spark to follow to ground outside the cumbustion chamber. People should be more liberal with Dielectric grease when changing plugs it saves a lot of headaches.
I cannot tell you how many of these I changed (or had to dry out) over the years. And yes, I am aware they require a support bracket but I have an Idearrrrrrrr
Old 12-04-2012, 07:54 PM   #7
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
That last statement kind of begs for some follow up pics when completed
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 12-04-2012, 09:07 PM   #8
digger440 OP
digger440's Avatar
Oddometer: 74
I have been a total photo-whore with this bike so trust me when I build it I will post pics. Click on the link in my sig to see what I have done and where I am going with it.
Times are GMT -7.   It's 09:53 AM.
