Old 12-04-2012, 11:01 AM   #16
SourKraut
Oddometer: 7,196
Put a new set of tires, fill them properly and it will transform the bike. I'm always amazed at the difference when I get a new set of tires.
SourKraut is offline   Reply With Quote
Old 12-04-2012, 11:39 AM   #17
Lensgrinder
Oddometer: 1,323
+1 on this.
Also the tires that come stock are not known for lasting very long, so you are probably due anyway.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Old 12-04-2012, 08:43 PM   #18
vagueout
vagueout's Avatar
Oddometer: 1,680
Originally Posted by motorbikeman View Post
Filled air. 38psi front and 42psi rear. The bike seems much more agile now. Great advise from ADV members as usual. My rear tyre seems to have squared off a bit though.
What I don't understand is how did the workshop guys filled 32psi front and 36psi rear right from the start and even after my first service!
Arrghhh! Please take this personal, what were you thinking relying on the "workshop guys" to pump your tyres??? I concur fully with lhendrik, even if your experience is none to minimal start NOW, and tyre pressures are a basic operator responsibility. Buy a cheap plug in compressor, a good gage in psi and you are laughing. Get yourself a good compact puncture kit (string type), learn to use it and you have built in reliance and reliability. We all start from some point and never stop learning.
i just seek clarity
vagueout is offline   Reply With Quote
Old 12-04-2012, 09:27 PM   #19
motorbikeman OP
Oddometer: 16
I always carry a puncture kit and a mini compressor. But I always used to rely on 2.2 bar for the front and 2.5 bar for the rear as prescribed in the manual! As long as my TPM showed that reading I was okay. In fact, the minute it dropped below those numbers I used to fill it up. I guess it was just a confusion which has been cleared now. 38psi front and 42psi rear is what I'm gonna follow now.
Thanks again guys!
motorbikeman is offline   Reply With Quote
Old 12-05-2012, 01:19 AM   #20
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Sorry to jump on your advice, but these have ball-joints instead of conventional steering head bearings, and i've yet to hear of one of these failing other than due to crash damage.
No offence taken
Just to make sure we are talking about the same thing - I am referring to the "angular contact bearing" in the yoke - not the ball joints in the telever. I don't think these are conventional bearings either; however they will cause problems from water ingress, accident damage and poor servicing (I have had a problem after an RM2 damper was fitted that caused low speed handling issues).
Tyre pressures never really affected the handling of my bike to the extent of what the OP talked about - I continuously change pressures from 20 (min, front) to 42 (max, rear), depending on what surface I am riding on and what load I am carrying. Tyre wear will change the handling a bit, but again depends on the type.
However, having said all that - if a change in tyre pressures fixes the problem then all's good.
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 12-05-2012, 03:36 AM   #21
tommyvdv
tommyvdv's Avatar
Oddometer: 417
My workshop guy also does this. He prefers the minimal pressure and loves to keep it below that.
Every time i visit, my tires are flat.
When i confront him he says; lower tire pressure gives more grip.
The way i see it, lower tire pressure increases wear and chances of cupping the tires.
In other words, he's trying to sell me more tires.
But let's say the workshop guys are looking out for your safety in stead. Sounds nice doesn't it?
tommyvdv is offline   Reply With Quote
Old 12-05-2012, 07:06 AM   #22
WoodButcher
WoodButcher's Avatar
Oddometer: 2,078
The reason the shop fills it to 32 front and 36 rear is that is what BMW calls for in the manual. Some people like to run slightly higher (2 extra psi), like me, and others like it much higher. Don't blame the service guys for following specs.
I find that everything works just fine at the spec pressure, but you need to check tire pressure at least weekly. So it you were running spec from the shop and don't check often then they will get lower than you want. If you are running a little higher then you have some margin if you don't check often.
And yes, riding in a straight line will square off the tire and affect how it steers.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 12-05-2012, 01:15 PM   #23
simoneau
Biker/Adventurer/Retiree
simoneau's Avatar
Oddometer: 202
Also check the preload on the rear shock. If the preload adjusment device has lost fluid, the shock may be at too low a preload for your weight and luggage. The original shock spring is sized for a 180 lb load any more than that then you should add preload to the shock. This will bring the back of the bike up to the design level and quicken the steering back to standard feel.
Randy
2014 BMW R1200GSA (OLIVE)
Ride it like you stole it, care for it like you'll keep it, never let it cool down and it'll last forever!
simoneau is offline   Reply With Quote
Old 12-05-2012, 04:56 PM   #24
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
^^^ Wot he said
32/36 is my normal one-up tar riding tyre pressure
viz
Old 12-06-2012, 04:55 PM   #25
bobbybob
Oddometer: 654
Originally Posted by tommyvdv View Post
....When i confront him he says; lower tire pressure gives more grip.
Lower tire pressure *will* increase the contact patch but at the expense of introducing more tread "squirm", less feedback, slower handling, and increased effort required to move the handlebars. I was really feeling the above in my 10 GS after the first 5K or so and raised the pressures to 36/42. The difference was shocking. Although the ride was a tad harsher, the handling was SO much better it completely negates it. And the cornering grip feels unchanged. I also think the extra pressure adds a little curve to the "flat-center" after 5K miles of wear and helps the turn-in.
bobbybob screwed with this post 12-06-2012 at 05:01 PM
bobbybob is offline   Reply With Quote
Old 12-06-2012, 09:02 PM   #26
Willie B
Oddometer: 236
I loaned my GS to a buddy to ride earlier this year. I rode my Multistrada for a while, and when I got back on the GS, I felt like molasses on a cold winter day. I first attributed the slow steering to the differing front rake of the Ducati, but once I checked the tire pressures, realized the tires were under inflated. My friend had taken the bike to the dealer for a service after using the bike and they had obviously deflated the tires. Once I pumped them up, the bike rode fine.
Willie B is offline   Reply With Quote
Old 12-07-2012, 06:53 PM   #27
Pickup man
Location: People's Socialist Republic of Ontario, Toronto
Oddometer: 286
I keep my Tourances at 2.4 front and 2.8 rear. Better handling and better wear. Fuel
economy is optimal pumped up as well.
Pickup man is offline   Reply With Quote
Times are GMT -7.   It's 10:23 PM.
