Old 12-04-2012, 08:18 AM   #1
syzygy9 OP
syzygy9's Avatar
Oddometer: 298
Happy Trails Cascade or Jesse Odyssey 2 for KTM 990
I have been using soft luggage (Andy Strapz) and would like to supplement with some hard luggage. Prime requirement is narrowness so wiiiiide Touratechs won't cut it. The HT Cascades (7.5 inch, 38.5 L) and the Jesse Odyssey 2 (8 inch, 40 L) both run at about 91 cm total width and seem the obvious choice.
Both seem equally good, similarly priced and about the same volumes. Jesse's angular shape could be a pain to bang out in the event of a fall (I fall a lot, though mostly low speed drops in sand) but being able to move them forward is appealing. The HT's seem to be good honest straightforward panniers.
Any insights pointing one way or another from the wise people here on advrider.
__________________________
bikeless no longer! welcome home, 2011 KTM 990 Adventure!
syzygy9 is offline   Reply With Quote
Old 12-04-2012, 10:12 AM   #2
OlyRider
Oddometer: 1,260
Here's a current thread.
http://advrider.com/forums/showthread.php?t=843671
Having owned both, I would go Jesse's all the way.
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 12-04-2012, 04:57 PM   #3
syzygy9 OP
syzygy9's Avatar
Oddometer: 298
Thanks for the pointer but I was hoping to get some real life reviews of both. I have scanned all the threads on advrider and elsewhere but solid info seems a bit thin.
The fact that you had both bags and preferred the Jesses is exactly the sort of insight I am seeking. Any reason you preferred the Jesses so strongly?
Old 12-04-2012, 06:52 PM   #4
OlyRider
Oddometer: 1,260
If the price is close at all, there is no comparison in quality, IMHO. Having owned both, I would only purchase the Happy Trails if I couldn't afford something better. And all the others are *better* in my experience. As noted by many others, HT doesn't pay particular attention to build specs. They tell customers to use a big hammer to beat the frame into submission. And they have told more than one customer that it is the manufacurers (such as BMW) making bent frames....not a problem with their boxes. That's what they told me.
My Jesses were on my 1200GS through Baja and Copper Canyon. Exceptional fit, build quality and strength. After the 1200, I had Touratechs on an 1150GS. They are also well-made, and probably lighter, but I'm not sure. I like the look of the TTs a little more.
Be happy to add anything else you need.
Olyrider
Ob-la-di...Ob-la-da
Old 12-04-2012, 09:22 PM   #5
hyperboarder
Potato Farmer
hyperboarder's Avatar
Oddometer: 1,024
I've had both too, Jesse's on my KLR (odd combo, I know) and HT Cascades on my current Strom. I had no complaints with the Jesse's and don't much mind the HT's either. I got the HT's on a scratch and dent sale, roughly half the price of the Jesse's. They're not perfect, the holes required a bit of elongation to fit right but I like the simplicity and the loops on the lid. The racks aren't perfect, but they aren't bad, sturdy enough to haul the ass end of the bike around as needed and the "bumper" on the back seems handy.
Anyway, the choice is yours, if you can afford the Jesse's and really want em, buy em. If you're ok with compromising a bit, get the HT's and save the leftover money for hookers and drugs :).
Current: 08 Yamaha WR250R, 05 Suzuki DL1000, 92 Ford E250 Motohauler
Gone but not forgotten: 2008 KLR650, 2000 GSXR1000, 1999 ZX6R, 2000 GSXF600, 2004 Ural Tourist, 99 Suzuki DR650
Quarter Life Crisis 2011 Ural National Rally
hyperboarder is online now   Reply With Quote
Old 12-05-2012, 08:02 AM   #6
Rick West
Function not Farkles
Oddometer: 1,222
I have the Jesse Odyssey on both my KTM 990s and the 9" Safari 2 on my Triumph 800. Also have a set of Happy Trail boxes on my KLR.
The Happy Trail boxes are inferior in every way when compared to the Jesses. Design, construction, finish and the mounting system. If cost is a major factor in picking luggage then sure, the HT boxes are the way to go. But like everything else, you get what you pay for and you must be willing to compromise in all aspects for the money you saved.
KTM 990 - The only real "dual" sport in the big Adventure bike class
Rick West is offline   Reply With Quote
Old 12-05-2012, 04:57 PM   #7
syzygy9 OP
syzygy9's Avatar
Oddometer: 298
Hi Rick,
I am looking at the 8inch Jesses or 7.5inch HTs also on a KTM 990. Can you tell me what the width and the volume of the Jesses are on your KTM. A bit hard to determine, I have read contradictory specs but seems to be around 40L and 90cm? Also how heavy are these boxes?
Old 12-05-2012, 11:49 PM   #8
roostar
roostar's Avatar
Oddometer: 149
I've had both. Currently running with HT's and like em just fine. I'm not one of those guys that needs the very best of everything. I like the basic design of the HT's as well as the price. After all, I'm not driving a Lexus, it's an adventure bike.
roostar is offline   Reply With Quote
Old 12-06-2012, 07:30 AM   #9
Rick West
Oddometer: 1,222
Hi Rick,
I have not done any checking to see if the volume quoted is exact, but yes they are rated at 41L each and are 90cm wide. I have not put them on a scale, but would guess the set weights about 25lbs mounted. Each bag is about 8lbs.
I did a test pack to see if I could get everything on the bike for the 45 day Trans Canada Adventure Trail that I will be doing next summer and everything fit easily into the two Jesses and a medium sized duffle bag. Based on that, I doubt many riders will need more capacity than these bags offer.
Old 12-06-2012, 07:39 AM   #10
syzygy9 OP
syzygy9's Avatar
Oddometer: 298
Thanks for the update. On my last trip I ran 2x 20L soft bags but had a large 50L bag on the rear rack. Made the bike too top heavy and want to get everything into two panniers, low and centered, and everything off the rear rack. I figure I could get pretty much everything into the panniers.
Old 09-02-2014, 05:01 PM   #11
fxbonneville
Hopeless kid
fxbonneville's Avatar
Oddometer: 12
Jesse Bags are great
I love my Jesse Bags. They are narrow, watertight and solid!
http://fxrtw.com/2014/04/26/bike-comfort-upgrades/
Soon riding a trail next to you!
--- www.fxrtw.com ---
2010 KTM 990 ADV R
fxbonneville is offline   Reply With Quote
Old 09-02-2014, 07:40 PM   #12
JR356
JR356's Avatar
Oddometer: 3,721
Another option to consider is Caribou luggage,based on Pelican and similar boxes.
They make a nice 990 setup.
I have riding buddies with past Caribou setups,and they were happy with the bags.
They are in the running for cases I'll get for my new GSA,if I get hard bags.
http://cariboucases.com/What-Fits-My...990-Adventure/
JR356
JR356 is online now   Reply With Quote
Times are GMT -7.   It's 10:40 AM.
