Old 12-05-2012, 08:44 AM   #1
longwaytim OP
longwaytim's Avatar
Oddometer: 511
1150 GSA luggage question
Can anyone tell me if the bmw 1150 adventure aluminum top case/mount will fit on a regular 1150 GS?
"...clean, dirty, clean, dirty.. all this has happened before & will happen again..."
longwaytim is offline   Reply With Quote
Old 12-06-2012, 01:23 AM   #2
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,801
Not readily fitted
GS
GSA
None
dirtsurfer screwed with this post 12-06-2012 at 01:28 AM
dirtsurfer is offline   Reply With Quote
Old 12-06-2012, 03:51 AM   #3
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
no. Since the saddles and the luggage carriers are so different, it isn't a bolt on. You CAN swap the GS saddle set up for the GSA saddle set, it has been done and the reverse has been done many times here. I think somewhere there will be a thread listing the parts needed or you might find a GSA owner looking to swap with you.
Mounting a top case on the GS luggage carrier isn't the best idea-- they tend to break and crack. I have an extra carrier along with my spare final drive ready to ship just in case. If you do use one-- keep it light.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 12-06-2012, 07:28 AM   #4
longwaytim OP
longwaytim's Avatar
Oddometer: 511
Thanks guy's...
Times are GMT -7.   It's 06:11 PM.
