Old 12-07-2012, 05:51 PM   #16
Ninthlord OP
Cadmium Enriched
Ninthlord's Avatar
Oddometer: 278
Narrowed down...
I'm looking at these mods:
- Diode board/solid mounts. I'd like to install the whole Omega charging system, but it's a bit pricey. I can afford the Thunderchild diode mod and the VR.
- Final drive. Can I just replace the stock ujoint with a serviceable one, or does the entire shaft ass'y need replacing? Sounds expensive. I carry a fire extinguisher.
- Tranny output shaft. I did the research, mine is circlip-free. Doesn't sound terribly expensive, except in labor terms. Cuanto es esto?
These are my top three priorities, as they can all be stranders, and I like to ride this bike. I just can't do 'em all at once.
After I get these done I'll consider chopping it into a naked dirt cafe racer.
-CG
Ninthlord screwed with this post 12-07-2012 at 06:12 PM
Ninthlord is offline   Reply With Quote
Old 12-08-2012, 04:03 AM   #17
akabeton
akabeton's Avatar
Oddometer: 181
Originally Posted by smorgasgeorge View Post
Of all the things I've done so far to my GSPD, there's only one I think is an absolute no-brainer: enduralast alternator.
+1
I'm doing this to mine this winter.
1995 R100 GSPD
akabeton is offline   Reply With Quote
Old 12-08-2012, 06:54 PM   #18
Ninthlord OP
Cadmium Enriched
Ninthlord's Avatar
Oddometer: 278
Of all the things I've done so far to my GSPD.
Herein lies the rub.
-CG
Old 12-08-2012, 09:01 PM   #19
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 2,950
yep..
got to get it on the good foot
camgregus is offline   Reply With Quote
Old 12-09-2012, 04:58 AM   #20
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 148
I am currently restoring my 1989 R100GS-Paris Dakar and this is what I altered so far. Once she's back on the road, I'll see what if anything else needs doing -
1. Change front brake caliper for one of the modded R1100 Brembos as mentioned earlier.
2. Fit braided stainless steel front brake pipe.
3. Fitted a floating front brake disc. All of these mods brought the front brake performance from 'poor' to 'slightly better'. I shall check the entire front system through, replacing seals, etc, to try to get it better.
3. Fitted a Secdem front screen although the American Parabellum looks much better.
4. Fitted Touratech 'Zega' rear panniers and their brackets, much stronger than the originals.
5. Replaced the pig ugly front mudguard with the lower one.
Other mods in the pipeline -
6. Jim Cray twin plugged cylinder heads.
7. Alloy top box.
8. Better (bigger & wider) footrests.
9. Remove oil cooler from the crash bars and mount this on the frame.
10. Replace rusty spokes with stainless.
11. Replace all fasteners with stainless (in spite of what some might say)
Other than that, I shall leave her well alone as she'll be just the bike that'll suit me.
Paul_Rochdale is offline   Reply With Quote
Old 12-09-2012, 06:29 PM   #21
cameron110
cameron110's Avatar
Oddometer: 339
Modify the odometer to read something north of 100k, while there are a few ways this could be done I recommend going after it by enjoying a great all around bike. I'm working on that with my PD and will be there some time in the next couple months.
On a more serious note, shelving the stock solo seat for a corbin is big bonus on the days when you want hit double digit hours in the saddle.
As for your top three list of ideal mods, they are all decent ideas if money were no object. I would keep riding it and do them when you have the time and money. If you are careful not to lug the tranny it can last forever in stock form. As for charging system unless you need more power to run lights/heated gear or spares for a major trip to the third world you can probably table that for now.
Resurrection of a: Mongrel /5
Ride Report: West Africa How to: DRZ400e tail bag using Wolfman Lg Expd Tank Bag '76 CT360 project: Poll & build thread
Good behavior is the last refuge of mediocrity.
cameron110 screwed with this post 12-09-2012 at 06:37 PM
cameron110 is offline   Reply With Quote
Old 12-11-2012, 04:29 AM   #22
bikerfish
flyfishandride
Oddometer: 993
make it into a cafe racer!!
JUST KIDDING! awesome original example, do tasteful, usefull upgrades and ride the wheels off that thing!
bikerfish is offline   Reply With Quote
Old 12-21-2012, 04:42 PM   #23
Ninthlord OP
Cadmium Enriched
Ninthlord's Avatar
Oddometer: 278
$135
For the tow. I was burning fuel in prep of pulling the tank, about 25 miles from home. Tach dropped out, hit the passing lamp and got a quick engine cutout. Death followed at the next stop. Is it the battery (1.5 yrs.) or the aforementioned charging sys mods (not done)? A few mins on the trickle and she fired right up. I rode this bike to the MOA last July with no issues.
-CG
Old 12-21-2012, 05:07 PM   #24
akabeton
akabeton's Avatar
Oddometer: 181
Rotor?
Had a similar experience earlier this year, turned out to be the rotor.
The fix was quick, it was the diagnostic procedure that took the time.
With ignition on does your charge bulb light up ?
1995 R100 GSPD
Old 12-21-2012, 06:28 PM   #25
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,497
Send a message via AIM to bajaburro
mods
light weight wrist pins,cheap should you do the work yourself.tall 5th gear,that you'll have the dealer do.makes the bike much smoother at speed.
ancient adventurer
bajaburro is offline   Reply With Quote
Old 12-21-2012, 08:00 PM   #26
matteo
HPM
matteo's Avatar
Oddometer: 488
A virgin GSPD that is working flawlessly.... I would preserve it. It's only original once.
I wanted to get a GS to mod so I got a good but not so perfect '89. I then modded the snot out of it.
matteo is offline   Reply With Quote
Old 12-21-2012, 10:21 PM   #27
WacoDirtryder
WacoDirtryder's Avatar
Oddometer: 287
Thumbs down
Save the money on the Corbin just clamp a 2X12 on the frame and sit on it i think it would be more comfortable.
WacoDirtryder is offline   Reply With Quote
Old 12-22-2012, 04:10 PM   #28
jackd
Oddometer: 2,385
I run the stock seat on my GS - I actually don't mind it. The seat that I usually run is my dual Corbin - that one is much more comfortable for long distance riding days.
Old 01-27-2013, 02:46 PM   #29
Ninthlord OP
Cadmium Enriched
Ninthlord's Avatar
Oddometer: 278
Flawless since the stranding
She's run perfectly for several weeks now. I'm liking that rotor option, not knowing what else it could be.
-CG
Old 01-27-2013, 03:39 PM   #30
WacoDirtryder
Oddometer: 287
Man where did you get those bags off a RoadKing?
Times are GMT -7.   It's 07:46 PM.
