Old 12-07-2012, 04:11 PM   #1
dcspringer OP
Oddometer: 9
GS 17 Inch Wheel Conversion
Looking for information for converting the R1200GS 19 inch front wheel to a 17 inch. Also the rear to a wider 5.5 for a 180. I don't do off road riding so I want more yire options for the street and track.
Thanks for any help!
dcspringer is offline   Reply With Quote
Old 12-07-2012, 08:39 PM   #2
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,002
Why!
More trouble than its worth.
RED CAT is offline   Reply With Quote
Old 12-07-2012, 08:40 PM   #3
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,786
The easiest way to do this on the 1150's is to bolt up a set of RT (or R) wheels. I suspect that the 1200 is the same.
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 12-08-2012, 04:20 AM   #4
dcspringer OP
Oddometer: 9
Thanks...it is starting to sound like the R1200RT/R is a simple wheel swap. Transfer the rotors and ABS ring and bolt it on.
Old 12-08-2012, 08:37 AM   #5
DiabloADV
Semi-Occasional
Oddometer: 2,325
Search this topic in the GS forum...I think there is more to it than that. The rear needs to be offset or milled in some way, IIRC...
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 12-08-2012, 09:11 AM   #6
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,035
Sounds like the guys that want to lower 4WD SUVs.
Guess it's OK to have a lowrider contingent here.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 12-08-2012, 11:16 AM   #7
Mr. Canoehead
Taste Gunnels!
Oddometer: 1,786
I have two sets of spoked wheels (one on road with Anakees and one off road with TKCs) and the 19" front is a compromise size. I have been thinking about getting one converted to a Woody's 21" for off road/gravel travel and getting a 17" from an RT for on road touring.
The wire wheels are pretty heavy. Compared to my buddy's MS12, my rear with tire is at least 50% heavier and he has a much wider tire .
Sent from my SGH-I747M using Tapatalk 2
Times are GMT -7.   It's 04:46 AM.
