Old 12-11-2012, 12:18 PM   #16
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,397
Bazinga!
Uncle Pollo is offline   Reply With Quote
Old 12-11-2012, 01:46 PM   #17
mrbindc OP
Oddometer: 75
I have the 32mm VM kit from RPC. After reading the manual online, I guess I shouldn't call it a choke even thought the word "choke" is stamped on the lever. They call it a starting system. Very fancy!
mrbindc is offline   Reply With Quote
Old 12-11-2012, 02:02 PM   #18
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,016
If the starting system restricts the flow of air to make the fuel mix richer then it is a choke.
---Albert Einstein
Old 12-11-2012, 05:07 PM   #19
Uncle Pollo
happy cachiporra
Oddometer: 48,397
I throttle myself everytime I read "choke" on the lever.
Old 12-12-2012, 02:45 PM   #20
mrbindc OP
Oddometer: 75
"I throttle myself everytime I read "choke" on the lever."
oh brother...
Old 12-12-2012, 03:03 PM   #21
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,805
An enriching insight!
Old 12-12-2012, 03:50 PM   #22
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,541
GAS(p)!
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is online now   Reply With Quote
Old 12-12-2012, 04:32 PM   #23
Houseoffubar
fine beer sampler
Oddometer: 1,805
Originally Posted by Beater View Post
GAS(p)!
OK knock it off, there is no reason to fuel this silliness!
Old 12-12-2012, 08:18 PM   #24
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
You've got to be choking, why stop now? This has truly been a gas.......
Kai Ju is offline   Reply With Quote
Old 12-13-2012, 07:29 AM   #25
mrbindc OP
Oddometer: 75
if y'all keep needle'n, I'm gonna jet.
Old 12-14-2012, 08:47 AM   #26
mrbindc OP
Oddometer: 75
I've been messing around with the carbs this week. They really are easy to tune and I'm just learning a lot in general about these carbs. I mentioned in an earlier post that even though the word "Choke" is stamped on the lever for the choke the manual calls it a starter system. When you push down on the lever you actually open up an airway for a independent starter jet which uses the negative pressure of the inlet to feed the fuel/air mixture. The slide and main jet aren't restricted in any way. Because of this, they recommend keeping the throttle closed during the cold start.
It was in the mid-40s yesterday and I tried a cold start without any throttle, starter system engaged, and it really does work. I was slightly amazed since I always HAD to use a lot of throttle to get the bike started with the choke on the Bings.
From the Mikuni VM Carburetor Super Tuning Manual
"Starting Device (starter system)
In place of the choke, the starter system is employed for Mikuni carburetors. In the starter type, fuel and air for starting the engine are metered with entirely independent jets. The fuel metered in the starter jet is mixed with air and is broken into tiny particles in the emulsion tube. The mixture then flows into the plunger area, mixes again with air coming from the air intake port for starting and is delivered to the engine in the optimum air-fuel ratio through the fuel discharge nozzle. The starter is opened and closed by means of the starter plunger. Since the starter type is constructer so as to utilize the negative pressure of the inlet pip, it is important that the throttle valve is closed when starting the engine. At high temperatures (approx. above 68F), the engine can be started without using the starter."
You can see the starter system routing and the starter jet in this diagram.
Old 12-14-2012, 08:48 AM   #27
mrbindc OP
Oddometer: 75
Here is the link to the Super Tuning Manual. Awesome name btw.
http://www.mikuni.com/pdf/vmmanual.pdf
Old 12-15-2012, 01:09 AM   #28
chasbmw
Oddometer: 2,349
Bings are the same, they also have aux starting circuit and with bing you also need to have the throttle closed when you
Press the starter button!
Charles
1971 Commando Fastback
Times are GMT -7.   It's 03:22 PM.
