Old 12-07-2012, 01:23 PM   #1
JohnG. OP
JohnG.'s Avatar
Oddometer: 2,367
Nicked a forkleg...
RH side forkleg wont stop leaking,despite new seal...then I noticed a small nick,hopeing fine wet n dry will do the trick...
Yeah,I know,the dust covers are looking a little old too
JohnG.
JohnG. is offline   Reply With Quote
Old 12-07-2012, 01:26 PM   #2
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 342
You can hit it with a fine file just to take that edge off to start with too before you sand it. Should buff out ok.
Cameron Corner - 6 Day Blast
FuTAnT is offline   Reply With Quote
Old 12-07-2012, 01:30 PM   #3
Haggs
Tigre Verde
Haggs's Avatar
Oddometer: 135
I used to get those on my WR 450. just got fine wet and dry and cut 2 to 3cm wide strip long enough to loop around the fork and hold on to with both hands and work back and forth, works a treat and no leaks!.
Haggs is offline   Reply With Quote
Old 12-07-2012, 02:06 PM   #4
JohnG. OP
JohnG.'s Avatar
Oddometer: 2,367
Ta,Thanks
JohnG.
Old 12-07-2012, 03:06 PM   #5
PBee
_
PBee's Avatar
Oddometer: 9,247
You'll be right....that'll buff right out!!!
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is offline   Reply With Quote
Old 12-07-2012, 03:20 PM   #6
dobbo
dobbo's Avatar
Oddometer: 1,007
I thought I'd seen this on another forum.
Araldite, epoxy resin, JB weld...
Hope this helps
Here's a link:
http://www.netrider.net.au/threads/a...-forks.135560/
dobbo is offline   Reply With Quote
Old 12-07-2012, 04:48 PM   #7
Joe Watson
Joe Watson's Avatar
Oddometer: 1,033
So would you sand vertically, horizontally or it wouldn't matter?
Joe Watson is offline   Reply With Quote
Old 12-08-2012, 01:05 AM   #8
JohnG. OP
JohnG.'s Avatar
Oddometer: 2,367
guessing vertically,noticed today a fine vertical line has appeared near the nick,caught grain of sand??
got distracted sorting out bent rad mounts today thou,bloody TPS died,its all happening lately...
JohnG.
Old 12-08-2012, 02:31 AM   #9
DRjoe
DRjoe's Avatar
Oddometer: 5,257
When you sand it you ideally want to sand it in a chris cross pattern so that your left with hatching.
If its deep a dab of super glue works well then sand it flush.
Old 12-08-2012, 02:16 PM   #10
BergDonk
BergDonk's Avatar
Oddometer: 3,843
I use a small fine oil stone with a circular pattern. I've had success with epoxy steel if its deep. You can only try.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 12-08-2012, 11:08 PM   #11
Paves
Beetrt/liver sausage
Paves's Avatar
Oddometer: 1,663
How would you repair a small chip in a fork tube...
...that is causing oil to leak past the seal?
I've seen a couple of posts that say use a 2 pack araldite but I've also seen posts that say it doesn't work for long. It's my son's 2011 KX65 that I bought for him a couple of months ago and he will race next season, so I'm hoping someone has a long term solution so I don't have to buy a new tube.
What's that you have in your eye?
Oohh! it's nothing but a sparkle
"All the freaky people make the beauty in the world" - Michael Franty. Weird, odd and proud of it
Paves is offline   Reply With Quote
Old 12-08-2012, 11:23 PM   #12
bbjay
Oddometer: 425
There is a thread going at the moment called nicked a forkleg
bb
bbjay is offline   Reply With Quote
Old 12-08-2012, 11:47 PM   #13
hoss18
hoss18's Avatar
Oddometer: 123
Dispite looking trying a dozen different ways I havent found a real way to make a permanent DIY repair. If its a slight nick sometimes a small bit of smoothing helps so that it doesnt leak too much. For deeper nicks/holes I tried most epoxies - sometimes a lot of work for something that lasted a very short time. One thing that seemed to hold in for a while was the 'super glue - steel filler' version to fill the nick/scratch and then slow patient gentle use of wet/dry (I used 600/800 grade gently). I suppose its not too expensive to try - mainly just time so I would give something like this ago before thinking of more expensive options. Let us know how you get on.
BMW - a love hate relationship
hoss18 is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
